32 #include <dtkCoreSupport/dtkGlobal.h>
   35 #include <vtkArrowSource.h>
   36 #include <vtkCommand.h>
   37 #include <vtkContourFilter.h>
   38 #include <vtkDataSetMapper.h>
   39 #include <vtkCellData.h>
   40 #include <vtkGlyph3D.h>
   41 #include <vtkHedgeHog.h>
   42 #include <vtkObjectFactory.h>
   43 #include <vtkPointData.h>
   44 #include <vtkPolyDataMapper.h>
   45 #include <vtkRenderWindowInteractor.h>
   46 #include <vtkSmartPointer.h>
   47 #include <vtkSphere.h>
   48 #include <vtkSphereRepresentation.h>
   49 #include <vtkSphereSource.h>
   50 #include <vtkSphereWidget2.h>
   51 #include <vtkStreamTracer.h>
   52 #include <vtkTubeFilter.h>
   53 #include <vtkPolyData.h>
   54 #include <vtkUnstructuredGrid.h>
   56 #include <vtkDataArray.h>
   57 #include <vtkFloatArray.h>
   58 #include <vtkIntArray.h>
   59 #include <vtkDoubleArray.h>
   61 #include <vtkExtractUnstructuredGrid.h>
   75     virtual void Execute(vtkObject *caller,
unsigned long event,
void *)
   98 class axlActorFieldParametricPrivate
  106     bool scalar_display_as_iso;
  107     int scalar_iso_count;
  108     double scalar_iso_range[2];
  109     vtkSmartPointer<vtkTubeFilter> scalar_iso_tube_filter;
  111     vtkSmartPointer<vtkContourFilter> scalar_iso;
  112     vtkSmartPointer<vtkPolyDataMapper> scalar_iso_mapper;
  113     vtkSmartPointer<vtkActor> scalar_iso_actor;
  115     vtkSmartPointer<vtkPolyDataMapper> scalar_iso_color_mapper;
  116     vtkSmartPointer<vtkActor> scalar_iso_color_actor;
  118     vtkSmartPointer<vtkScalarBarActor> scalar_bar_actor;
  120     double scalar_color_range[2];
  121     vtkSmartPointer<vtkDataSetMapper> scalar_color_mapper;
  122     vtkSmartPointer<vtkActor> scalar_color_actor;
  124     vtkSmartPointer<vtkHedgeHog> vector_hedgehog;
  125     vtkSmartPointer<vtkPolyDataMapper> vector_hedgehog_mapper;
  126     vtkSmartPointer<vtkActor> vector_hedgehog_actor;
  128     vtkSmartPointer<vtkArrowSource> vector_glyph_source;
  129     vtkSmartPointer<vtkGlyph3D> vector_glyph;
  130     vtkSmartPointer<vtkPolyDataMapper> vector_glyph_mapper;
  131     vtkSmartPointer<vtkActor> vector_glyph_actor;
  133     vtkSmartPointer<vtkSphereWidget2> vector_stream_widget;
  134     vtkSmartPointer<vtkSphereRepresentation> vector_stream_widget_representation;
  135     vtkSmartPointer<vtkPolyData> vector_stream_widget_data;
  136     vtkSmartPointer<vtkStreamTracer> vector_stream_tracer;
  137     vtkSmartPointer<vtkTubeFilter> vector_stream_filter;
  138     vtkSmartPointer<vtkPolyDataMapper> vector_stream_mapper;
  139     vtkSmartPointer<vtkActor> vector_stream_actor;
  140     vtkSmartPointer<axlActorFieldParametricStreamObserver> vector_stream_observer;
  142     vtkSmartPointer<vtkRenderWindowInteractor> interactor;
  149 #if (VTK_MAJOR_VERSION <= 5)
  170     if(d->mesh->fields().contains(QString(
"%1 magnitude").arg(d->field->objectName())))
  173     QString field_magnitude_name = QString(
"%1 magnitude").arg(d->field->objectName());
  177     double size = d->field->size();
  190     for(
int i = 0; i < size; i++){
  194     return field_magnitude;
  205     return d->scalar_bar_actor;
  211     return d->scalar_color_range[0];
  216     return d->scalar_color_range[1];
  221     return d->scalar_iso->GetNumberOfContours();
  226     return d->scalar_iso_range[0];
  231     return d->scalar_iso_range[1];
  236     return d->vector_glyph->GetScaleFactor();
  241     return d->vector_stream_filter->GetRadius();
  246     d->interactor =
static_cast<vtkRenderWindowInteractor *
>(interactor);
  253     size = d->field->size();
  255     d->array->SetNumberOfTuples(size);
  257     if(!d->mesh->getUnstructuredGrid() && !d->mesh->getPolyData()){
  258         if(dynamic_cast<axlActorDataDynamic *>(d->mesh)){
  260             d->mesh->setPolyData(dynamic_cast<axlActor *>(actorDD->
outputActor())->getMapper()->GetInput());
  262             d->mesh->setPolyData(d->mesh->getMapper()->GetInput());
  270     if(dynamic_cast<axlAbstractFieldParametricCurve *>(d->field)){
  274         double start_u = fieldSurface->
start_u();
  275         double end_u = fieldSurface->
end_u();
  281         double step_u = (end_u - start_u)/(n_u);
  286         for(
int i = 0; i < n_u - 1; i++)
  290                 d->array->SetTuple1( i, fieldSurface->
scalar(u));
  291                 d->array->Modified();
  293                 d->array->SetTuple( i, fieldSurface->
vector(u));
  294                 d->array->Modified();
  296                 d->array->SetTuple( i, fieldSurface->
tensor(u));
  297                 d->array->Modified();
  307     else if(dynamic_cast<axlAbstractFieldParametricSurface *>(d->field)){
  311         double start_u = fieldSurface->
start_u();
  312         double start_v = fieldSurface->
start_v();
  313         double end_u = fieldSurface->
end_u();
  314         double end_v = fieldSurface->
end_v();
  322         double step_u = (end_u - start_u)/(n_u);
  323         double step_v = (end_v - start_v)/(n_v);
  327         for(
int j = 0; j < n_v - 1; j++)
  329             for(
  333                     d->array->SetTuple1(j * n_u + i, fieldSurface->
scalar(u,v));
  334                     d->array->Modified();
  336                     d->array->SetTuple(j * n_u + i, fieldSurface->
vector(u,v) );
  337                     d->array->Modified();
  339                     d->array->SetTuple(j * n_u + i, fieldSurface->
tensor(u,v));
  340                     d->array->Modified();
  348                 d->array->SetTuple1(j * n_u +  n_u - 1 , fieldSurface->
scalar(end_u,v));
  349                 d->array->Modified();
  351                 d->array->SetTuple(j * n_u +  n_u - 1 , fieldSurface->
vector(end_u,v));
  352                 d->array->Modified();
  354                 d->array->SetTuple(j * n_u +  n_u - 1 , fieldSurface->
tensor(end_u,v));
  355                 d->array->Modified();
  362         for(
  365                 d->array->SetTuple1((n_v - 1) * n_u + i,  fieldSurface->
scalar(u,end_v));
  366                 d->array->Modified();
  368                 d->array->SetTuple((n_v - 1) * n_u + i,  fieldSurface->
vector(u,end_v));
  369                 d->array->Modified();
  371                 d->array->SetTuple((n_v - 1) * n_u + i,  fieldSurface->
tensor(u,end_v));
  372                 d->array->Modified();
  379             d->array->SetTuple1(n_v * n_u - 1,fieldSurface->
scalar(end_u,end_v));
  380             d->array->Modified();
  382             d->array->SetTuple(n_v * n_u - 1,fieldSurface->
vector(end_u,end_v));
  383             d->array->Modified();
  385             d->array->SetTuple(n_v * n_u - 1,fieldSurface->
tensor(end_u,end_v));
  386             d->array->Modified();
  391     else if(dynamic_cast<axlAbstractFieldParametricVolume *>(d->field)){
  394         double start_u = fieldVolume->
start_u();
  395         double start_v = fieldVolume->
start_v();
  396         double start_w = fieldVolume->
start_w();
  397         double end_u = fieldVolume->
end_u();
  398         double end_v = fieldVolume->
end_v();
  399         double end_w = fieldVolume->
end_w();
  409         double step_u = (end_u - start_u)/(n_u);
  410         double step_v = (end_v - start_v)/(n_v);
  411         double step_w = (end_w - start_w)/(n_w);
  416         for(
int k = 0; k < n_w - 1; k++)
  418             ind1 = k * n_u * n_v;
  419             for(
int i = 0; i < n_v - 1; i++)
  422                 for(
int j = 0; j < n_u - 1; j++)
  424                     ind3 = ind1 + ind2 +j;
  426                         d->array->SetTuple1(ind3,fieldVolume->
scalar(u, v,w));
  427                         d->array->Modified();
  431                         d->array->Modified();
  433                         d->array->SetTuple(ind3,fieldVolume->
vector(u, v,w));
  435                         d->array->SetTuple(ind3,fieldVolume->
tensor(u, v,w));
  436                         d->array->Modified();
  440                 ind3 = ind1 + ind2 + (n_u - 1);
  442                     d->array->SetTuple1(ind3,fieldVolume->
scalar(end_u, v, w));
  443                     d->array->Modified();
  445                     d->array->SetTuple(ind3,fieldVolume->
vector(end_u, v, w));
  446                     d->array->Modified();
  448                     d->array->SetTuple(ind3,fieldVolume->
tensor(end_u, v, w));
  449                     d->array->Modified();
  455             ind3 = ind1 + (n_v -1)* n_u + (n_u - 1);
  457                 d->array->SetTuple1(ind3,fieldVolume->
scalar(end_u, end_v, w));
  458                 d->array->Modified();
  460                 d->array->SetTuple(ind3,fieldVolume->
vector(end_u, end_v, w));
  461                 d->array->Modified();
  463                 d->array->SetTuple(ind3,fieldVolume->
tensor(end_u, end_v, w));
  464                 d->array->Modified();
  474         ind1 = n_u * n_v * (n_w - 1);
  475         for(
  478             for(
  480                 ind3 = ind1 + ind2 + i;
  482                     d->array->SetTuple1(ind3, fieldVolume->
scalar(u, v, end_w));
  483                     d->array->Modified();
  485                     d->array->SetTuple(ind3, fieldVolume->
vector(u, v, end_w));
  486                     d->array->Modified();
  488                     d->array->SetTuple(ind3, fieldVolume->
tensor(u, v, end_w));
  489                     d->array->Modified();
  494             ind3 = ind1 + ind2 + (n_u -1);
  496                 d->array->SetTuple1(ind3,fieldVolume->
scalar(end_u, v, end_w));
  497                 d->array->Modified();
  499                 d->array->SetTuple(ind3,fieldVolume->
vector(end_u, v, end_w));
  500                 d->array->Modified();
  502                 d->array->SetTuple(ind3,fieldVolume->
tensor(end_u, v, end_w));
  503                 d->array->Modified();
  511         ind2 = (n_v-1) * n_u;
  513         for(
int k = 0; k < n_w ; k++)
  515             ind1 = n_u * n_v * k;
  516             for(
  518                 ind3 = ind1 + ind2 + i;
  520                     d->array->SetTuple1(ind3,fieldVolume->
scalar(u, end_v, w));
  521                     d->array->Modified();
  523                     d->array->SetTuple(ind3,fieldVolume->
vector(u, end_v, w));
  524                     d->array->Modified();
  526                     d->array->SetTuple(ind3,fieldVolume->
tensor(u, end_v, w));
  527                     d->array->Modified();
  533             ind3 = ind2 + ind1 + (n_u-1);
  539             d->array->SetTuple1(n_u * n_v * n_w -1,fieldVolume->
scalar(end_u, end_v, end_w));
  540             d->array->Modified();
  542             d->array->SetTuple(n_u * n_v * n_w -1,fieldVolume->
vector(end_u, end_v, end_w));
  543             d->array->Modified();
  545             d->array->SetTuple(n_u * n_v * n_w -1,fieldVolume->
tensor(end_u, end_v, end_w));
  546             d->array->Modified();
  555     if(d->scalar_color_range && d->scalar_color_mapper){
  570             connect(parentData, SIGNAL(modifiedGeometry()),
this, SLOT(
update()));
  573         connect(axlData, SIGNAL(modifiedGeometry()),
this, SLOT(
update()));
  576             d->array = vtkIntArray::New();
  578             d->array = vtkFloatArray::New();
  580             d->array = vtkDoubleArray::New();
  587             d->array->SetNumberOfComponents(1);
  590             d->array->SetNumberOfComponents(3);
  593             d->array->SetNumberOfComponents(9);
  596             qDebug() <<
"Unsupported field kind";
  599         QString name = d->field->objectName();
  600         d->array->SetName(qPrintable(name));
  610     d->mesh =
>(actorfield);
  617     d->scalar_color_range[0] = min;
  618     d->scalar_color_mapper->SetScalarRange(d->scalar_color_range);
  619     d->scalar_color_mapper->Update();
  624     d->scalar_color_range[1] = max;
  625     d->scalar_color_mapper->SetScalarRange(d->scalar_color_range);
  626     d->scalar_color_mapper->Update();
  631     d->scalar_iso_count = count;
  632     d->scalar_iso->GenerateValues(d->scalar_iso_count, d->scalar_iso_range[0], d->scalar_iso_range[1]);
  633     d->scalar_iso->Update();
  638     d->scalar_iso_range[0] = min;
  639     d->scalar_iso->GenerateValues(d->scalar_iso_count, d->scalar_iso_range[0], d->scalar_iso_range[1]);
  640     d->scalar_iso->Update();
  641     d->scalar_iso_color_mapper->SetScalarRange(d->scalar_iso_range);
  642     d->scalar_iso_color_mapper->Update();
  647     d->scalar_iso_range[1] = max;
  648     d->scalar_iso->GenerateValues(d->scalar_iso_count, d->scalar_iso_range[0], d->scalar_iso_range[1]);
  649     d->scalar_iso->Update();
  650     d->scalar_iso_color_mapper->SetScalarRange(d->scalar_iso_range);
  651     d->scalar_iso_color_mapper->Update();
  657     double bounds[6]; d->mesh->GetBounds(bounds);
  658     double side = qAbs(bounds[1]-bounds[0]);
  659     side += qAbs(bounds[3]-bounds[2]);
  660     side += qAbs(bounds[5]-bounds[4]);
  666     d->vector_glyph->SetScaleFactor(scale * side);
  667     d->vector_hedgehog->SetScaleFactor(scale * side * 0.1);
  672     d->vector_stream_tracer->SetMaximumPropagation(propagation);
  673     d->vector_stream_tracer->Update();
  678     d->vector_stream_filter->SetRadius(radius);
  679     d->vector_stream_filter->Update();
  686         d->vector_stream_tracer->SetIntegrationDirectionToForward();
  689         d->vector_stream_tracer->SetIntegrationDirectionToBackward();
  692         d->vector_stream_tracer->SetIntegrationDirectionToBoth();
  698     d->vector_stream_tracer->Update();
  703     if (d->mesh->getUnstructuredGrid()) {
  704         d->mesh->getDataSetMapper()->ScalarVisibilityOn();
  706         d->mesh->getMapper()->ScalarVisibilityOn();
  713         if(d->mesh->getUnstructuredGrid()){
  714             static_cast<vtkUnstructuredGrid *
>(d->mesh->getUnstructuredGrid())->GetPointData()->SetActiveScalars(qPrintable(d->field->objectName()));
  716             static_cast<vtkPolyData *
>(d->mesh->getPolyData())->GetPointData()->SetActiveScalars(qPrintable(d->field->objectName()));
  720         if(d->mesh->getUnstructuredGrid()){
  721             static_cast<vtkUnstructuredGrid *
>(d->mesh->getUnstructuredGrid())->GetCellData()->SetActiveScalars(qPrintable(d->field->objectName()));
  723             static_cast<vtkPolyData *
>(d->mesh->getPolyData())->GetCellData()->SetActiveScalars(qPrintable(d->field->objectName()));
  727     d->scalar_color_actor->SetVisibility(1);
  728     d->scalar_iso_actor->SetVisibility(0);
  729     d->scalar_iso_color_actor->SetVisibility(0);
  730     d->scalar_display_as_iso =
false;
  731     d->scalar_bar_actor->SetVisibility(1);
  737     if(d->scalar_color_actor)
  739         d->scalar_color_actor->SetVisibility(0);
  740         d->scalar_iso_actor->SetVisibility(0);
  741         d->scalar_iso_color_actor->SetVisibility(0);
  742         d->scalar_display_as_iso =
false;
  743         d->scalar_bar_actor->SetVisibility(0);
  745     if(d->mesh->getUnstructuredGrid()){
  746         d->mesh->getDataSetMapper()->ScalarVisibilityOn();
  749         d->mesh->getMapper()->ScalarVisibilityOn();
  752         if(d->mesh->getUnstructuredGrid()){
  753             static_cast<vtkUnstructuredGrid *
"mapperCollorArrayDefaultField");
  755             static_cast<vtkPolyData *
  766         if (d->mesh->getUnstructuredGrid()) {
  767             static_cast<vtkUnstructuredGrid *
  769             static_cast<vtkPolyData *
  774         if(d->mesh->getUnstructuredGrid()){
  775             static_cast<vtkUnstructuredGrid *
  778             static_cast<vtkPolyData *
  783         if(d->mesh->getUnstructuredGrid()){
  784             d->mesh->getDataSetMapper()->ScalarVisibilityOff();
  787             d->mesh->getMapper()->ScalarVisibilityOff();
  791     d->scalar_color_actor->SetVisibility(0);
  792     d->scalar_iso_actor->SetVisibility(1);
  793     d->scalar_iso_color_actor->SetVisibility(0);
  794     d->scalar_display_as_iso =
true;
  795     d->scalar_bar_actor->SetVisibility(0);
  802         d->vector_hedgehog_actor->SetVisibility(0);
  803         d->vector_glyph_actor->SetVisibility(0);
  804         d->vector_stream_actor->SetVisibility(0);
  805         d->vector_stream_widget->Off();
  813         d->vector_hedgehog_actor->SetVisibility(1);
  814         d->vector_glyph_actor->SetVisibility(0);
  815         d->vector_stream_actor->SetVisibility(0);
  816         d->vector_stream_widget->Off();
  824         d->vector_hedgehog_actor->SetVisibility(0);
  825         d->vector_glyph_actor->SetVisibility(1);
  826         d->vector_stream_actor->SetVisibility(0);
  827         d->vector_stream_widget->Off();
  835         d->vector_hedgehog_actor->SetVisibility(0);
  836         d->vector_glyph_actor->SetVisibility(0);
  837         d->vector_stream_actor->SetVisibility(1);
  838         d->vector_stream_widget->On();
  849     if(d->mesh->getUnstructuredGrid()){
  850         d->mesh->getUnstructuredGrid()->Modified();
  851 #if (VTK_MAJOR_VERSION <= 5)
  852         d->mesh->getUnstructuredGrid()->Update();
  855         d->mesh->getPolyData()->Modified();
  856 #if (VTK_MAJOR_VERSION <= 5)
  857         d->mesh->getPolyData()->Update();
  867         if(d->mesh->getUnstructuredGrid()){
  868             static_cast<vtkUnstructuredGrid *
>(d->mesh->getUnstructuredGrid())->GetPointData()->RemoveArray(d->array->GetName());
  869             static_cast<vtkUnstructuredGrid *
>(d->mesh->getUnstructuredGrid())->GetPointData()->AddArray(d->array);
  871             static_cast<vtkPolyData *
>(d->mesh->getPolyData())->GetPointData()->RemoveArray(d->array->GetName());
  872             static_cast<vtkPolyData *
>(d->mesh->getPolyData())->GetPointData()->AddArray(d->array);
  876             d->scalar_iso_actor->SetOrientation(d->mesh->getActor()->GetOrientation());
  877             d->scalar_iso_actor->SetPosition(d->mesh->getActor()->GetPosition());
  878             d->scalar_iso_color_actor->SetOrientation(d->mesh->getActor()->GetOrientation());
  879             d->scalar_iso_color_actor->SetPosition(d->mesh->getActor()->GetPosition());
  880             d->scalar_color_actor->SetOrientation(d->mesh->getActor()->GetOrientation());
  881             d->scalar_color_actor->SetPosition(d->mesh->getActor()->GetPosition());
  883             if(d->mesh->getUnstructuredGrid()){
  884                 static_cast<vtkUnstructuredGrid *
>(d->mesh->getUnstructuredGrid())->GetPointData()->SetActiveScalars(d->array->GetName());
  886                 static_cast<vtkPolyData *
>(d->mesh->getPolyData())->GetPointData()->SetActiveScalars(d->array->GetName());
  890             d->vector_glyph_actor->SetOrientation(d->mesh->getActor()->GetOrientation());
  891             d->vector_glyph_actor->SetPosition(d->mesh->getActor()->GetPosition());
  892             d->vector_hedgehog_actor->SetOrientation(d->mesh->getActor()->GetOrientation());
  893             d->vector_hedgehog_actor->SetPosition(d->mesh->getActor()->GetPosition());
  894             d->vector_stream_actor->SetOrientation(d->mesh->getActor()->GetOrientation());
  895             d->vector_stream_actor->SetPosition(d->mesh->getActor()->GetPosition());
  897             if(d->mesh->getUnstructuredGrid()){
  898                 static_cast<vtkUnstructuredGrid *
>(d->mesh->getUnstructuredGrid())->GetPointData()->SetActiveVectors(d->array->GetName());
  900                 static_cast<vtkPolyData *
>(d->mesh->getPolyData())->GetPointData()->SetActiveVectors(d->array->GetName());
  903             if(d->mesh->getUnstructuredGrid()){
  904                 static_cast<vtkUnstructuredGrid *
>(d->mesh->getUnstructuredGrid())->GetPointData()->SetActiveTensors(d->array->GetName());
  906                 static_cast<vtkPolyData *
>(d->mesh->getPolyData())->GetPointData()->SetActiveTensors(d->array->GetName());
  916         static_cast<vtkPolyData *
>(d->mesh->getPolyData())->GetCellData()->RemoveArray(d->array->GetName());
  917         static_cast<vtkPolyData *
>(d->mesh->getPolyData())->GetCellData()->AddArray(d->array);
  919             static_cast<vtkPolyData *>(d->mesh->getPolyData())->GetCellData()->SetActiveScalars(d->array->GetName());
  921             static_cast<vtkPolyData *>(d->mesh->getPolyData())->GetCellData()->SetActiveVectors(d->array->GetName());
  923             static_cast<vtkPolyData *>(d->mesh->getPolyData())->GetCellData()->SetActiveTensors(d->array->GetName());
  932     if(d->mesh && d->field)
  935                 if(d->mesh->getUnstructuredGrid()){
  936                     static_cast<vtkUnstructuredGrid *
  938                     static_cast<vtkPolyData *
  941                 if(d->mesh->getUnstructuredGrid()){
  942                     static_cast<vtkUnstructuredGrid *
>(d->mesh->getUnstructuredGrid())->GetPointData()->SetActiveVectors(qPrintable(d->field->objectName()));
  944                     static_cast<vtkPolyData *
>(d->mesh->getPolyData())->GetPointData()->SetActiveVectors(qPrintable(d->field->objectName()));
  948                 if(d->mesh->getUnstructuredGrid()){
  949                     static_cast<vtkUnstructuredGrid *
>(d->mesh->getUnstructuredGrid())->GetPointData()->SetActiveTensors(qPrintable(d->field->objectName()));
  951                     static_cast<vtkPolyData *
>(d->mesh->getPolyData())->GetPointData()->SetActiveTensors(qPrintable(d->field->objectName()));
  957     if(d->mesh && d->field)
  960                 static_cast<vtkPolyData *>(d->mesh->getPolyData())->GetCellData()->SetActiveScalars(qPrintable(d->field->objectName()));
  962                 static_cast<vtkPolyData *>(d->mesh->getPolyData())->GetCellData()->SetActiveVectors(qPrintable(d->field->objectName()));
  964                 static_cast<vtkPolyData *>(d->mesh->getPolyData())->GetCellData()->SetActiveTensors(qPrintable(d->field->objectName()));
  971     return d->scalar_color_mapper;
  996         qDebug() << DTK_PRETTY_FUNCTION <<
"No field.";
 1010         if(d->scalar_color_mapper && d->scalar_color_actor && d->scalar_iso_color_actor)
 1015             if(d->mesh->getPolyData()){
 1016                 static_cast<vtkPolyData *
 1017                 static_cast<vtkPolyData *
 1018                 static_cast<vtkPolyData *
 1020             if(d->mesh->getUnstructuredGrid()){
 1021                 static_cast<vtkUnstructuredGrid *
 1022                 static_cast<vtkUnstructuredGrid *
 1023                 static_cast<vtkUnstructuredGrid *
 1029             static_cast<vtkPolyData *
 1030             static_cast<vtkPolyData *
 1031             static_cast<vtkPolyData *
 1037         d->scalar_display_as_iso =
false;
 1038         d->scalar_iso_count = 10;
 1039         d->array->GetRange(d->scalar_iso_range);
 1041         d->scalar_iso = vtkSmartPointer<vtkContourFilter>::New();
 1042         if(d->mesh->getUnstructuredGrid()){
 1043 #if (VTK_MAJOR_VERSION <= 5)
 1044             d->scalar_iso->SetInput(static_cast<vtkUnstructuredGrid *>(d->mesh->getUnstructuredGrid()));
 1046             d->scalar_iso->SetInputData(static_cast<vtkUnstructuredGrid *>(d->mesh->getUnstructuredGrid()));
 1049 #if (VTK_MAJOR_VERSION <= 5)
 1050             d->scalar_iso->SetInput(static_cast<vtkPolyData *>(d->mesh->getPolyData()));
 1052             d->scalar_iso->SetInputData(static_cast<vtkPolyData *>(d->mesh->getPolyData()));
 1055         d->scalar_iso->GenerateValues(d->scalar_iso_count, d->scalar_iso_range[0], d->scalar_iso_range[1]);
 1057         d->scalar_iso_tube_filter = vtkSmartPointer<vtkTubeFilter>::New();
 1058         d->scalar_iso_tube_filter->SetRadius(d->isoRadius);
 1059         d->scalar_iso_tube_filter->SetNumberOfSides(8);
 1060 #if (VTK_MAJOR_VERSION <= 5)
 1061         d->scalar_iso_tube_filter->SetInput(d->scalar_iso->GetOutput());
 1063         d->scalar_iso_tube_filter->SetInputData(d->scalar_iso->GetOutput());
 1065         d->scalar_iso_mapper = vtkSmartPointer<vtkPolyDataMapper>::New();
 1066 #if (VTK_MAJOR_VERSION <= 5)
 1067         d->scalar_iso_mapper->SetInput(d->scalar_iso_tube_filter->GetOutput());
 1069         d->scalar_iso_mapper->SetInputData(d->scalar_iso_tube_filter->GetOutput());
 1072         d->scalar_iso_actor = vtkSmartPointer<vtkActor>::New();
 1073         d->scalar_iso_actor->SetOrientation(d->mesh->getActor()->GetOrientation());
 1074         d->scalar_iso_actor->SetPosition(d->mesh->getActor()->GetPosition());
 1075         d->scalar_iso_actor->SetMapper(d->scalar_iso_mapper);
 1076         d->scalar_iso_actor->SetVisibility(0);
 1078         this->AddPart(d->scalar_iso_actor);
 1082         d->scalar_iso_color_mapper = vtkPolyDataMapper::New();
 1083 #if (VTK_MAJOR_VERSION <= 5)
 1084         d->scalar_iso_color_mapper->SetInput(d->scalar_iso->GetOutput());
 1086         d->scalar_iso_color_mapper->SetInputData(d->scalar_iso->GetOutput());
 1088         d->scalar_iso_color_mapper->SetColorModeToMapScalars();
 1091             d->scalar_iso_color_mapper->SetScalarModeToUsePointData();
 1094             d->scalar_iso_color_mapper->SetScalarModeToUseCellData();
 1096         d->scalar_iso_color_mapper->SelectColorArray(d->array->GetName());
 1097         d->scalar_iso_color_mapper->SetScalarVisibility(
true);
 1098         d->scalar_iso_color_mapper->SetScalarRange(d->scalar_iso_range);
 1100         d->scalar_iso_color_actor = vtkSmartPointer<vtkActor>::New();
 1101         d->scalar_iso_color_actor->SetOrientation(d->mesh->getActor()->GetOrientation());
 1102         d->scalar_iso_color_actor->SetPosition(d->mesh->getActor()->GetPosition());
 1103         d->scalar_iso_color_actor->SetMapper(d->scalar_iso_color_mapper);
 1104         d->scalar_iso_color_actor->SetVisibility(0);
 1106         this->AddPart(d->scalar_iso_color_actor);
 1110         d->array->GetRange(d->scalar_color_range);
 1112         d->scalar_color_mapper = vtkDataSetMapper::New();
 1113 #if (VTK_MAJOR_VERSION <= 5)
 1114         if(d->mesh->getUnstructuredGrid())
 1115             d->scalar_color_mapper->SetInput(static_cast<vtkUnstructuredGrid *>(d->mesh->getUnstructuredGrid()));
 1117             d->scalar_color_mapper->SetInput(static_cast<vtkPolyData *>(d->mesh->getPolyData()));
 1119         if(d->mesh->getUnstructuredGrid())
 1120             d->scalar_color_mapper->SetInputData(static_cast<vtkUnstructuredGrid *>(d->mesh->getUnstructuredGrid()));
 1122             d->scalar_color_mapper->SetInputData(static_cast<vtkPolyData *>(d->mesh->getPolyData()));
 1125         d->scalar_color_mapper->SetColorModeToMapScalars();
 1128             d->scalar_color_mapper->SetScalarModeToUsePointData();
 1131             d->scalar_color_mapper->SetScalarModeToUseCellData();
 1133         d->scalar_color_mapper->SelectColorArray(d->array->GetName());
 1134         d->scalar_color_mapper->SetScalarVisibility(
true);
 1135         d->scalar_color_mapper->SetScalarRange(d->scalar_color_range);
 1137         d->scalar_color_actor = vtkSmartPointer<vtkActor>::New();
 1138         d->scalar_color_actor->SetOrientation(d->mesh->getActor()->GetOrientation());
 1139         d->scalar_color_actor->SetPosition(d->mesh->getActor()->GetPosition());
 1140         d->scalar_color_actor->SetMapper(d->scalar_color_mapper);
 1141         d->scalar_color_actor->SetVisibility(0);
 1143         this->AddPart(d->scalar_color_actor);
 1146         d->scalar_bar_actor = vtkSmartPointer<vtkScalarBarActor>::New();
 1147         d->scalar_bar_actor ->SetLookupTable(d->scalar_color_mapper->GetLookupTable());
 1148         d->scalar_bar_actor ->SetTitle(qPrintable(d->field->name()));
 1149         d->scalar_bar_actor ->SetNumberOfLabels(4);
 1150         d->scalar_bar_actor->SetVisibility(0);
 1165             if(d->mesh->getPolyData()){
 1166                 static_cast<vtkPolyData *
 1167                 static_cast<vtkPolyData *
 1168                 static_cast<vtkPolyData *
 1170             if(d->mesh->getUnstructuredGrid()){
 1171                 static_cast<vtkUnstructuredGrid *
 1172                 static_cast<vtkUnstructuredGrid *
 1173                 static_cast<vtkUnstructuredGrid *
 1178             static_cast<vtkPolyData *
 1179             static_cast<vtkPolyData *
 1180             static_cast<vtkPolyData *
 1187         d->vector_hedgehog = vtkSmartPointer<vtkHedgeHog>::New();
 1188 #if (VTK_MAJOR_VERSION <= 5)
 1189         if(d->mesh->getPolyData())
 1190             d->vector_hedgehog->SetInput(static_cast<vtkPolyData *>(d->mesh->getPolyData()));
 1192             d->vector_hedgehog->SetInput(static_cast<vtkUnstructuredGrid *>(d->mesh->getUnstructuredGrid()));
 1194         if(d->mesh->getPolyData())
 1195             d->vector_hedgehog->SetInputData(static_cast<vtkPolyData *>(d->mesh->getPolyData()));
 1197             d->vector_hedgehog->SetInputData(static_cast<vtkUnstructuredGrid *>(d->mesh->getUnstructuredGrid()));
 1199         d->vector_hedgehog->SetVectorModeToUseVector();
 1202         d->vector_hedgehog_mapper = vtkSmartPointer<vtkPolyDataMapper>::New();
 1203         d->vector_hedgehog_mapper->SetInputConnection(d->vector_hedgehog->GetOutputPort());
 1204         d->vector_hedgehog_mapper->ScalarVisibilityOn();
 1206         d->vector_hedgehog_actor = vtkSmartPointer<vtkActor>::New();
 1207         d->vector_hedgehog_actor->SetOrientation(d->mesh->getActor()->GetOrientation());
 1208         d->vector_hedgehog_actor->SetPosition(d->mesh->getActor()->GetPosition());
 1209         d->vector_hedgehog_actor->SetMapper(d->vector_hedgehog_mapper);
 1210         d->vector_hedgehog_actor->SetVisibility(0);
 1212         this->AddPart(d->vector_hedgehog_actor);
 1216         d->vector_glyph_source = vtkArrowSource::New();
 1218         d->vector_glyph = vtkSmartPointer<vtkGlyph3D>::New();
 1219 #if (VTK_MAJOR_VERSION <= 5)
 1220         if(d->mesh->getPolyData())
 1221             d->vector_glyph->SetInput(static_cast<vtkPolyData *>(d->mesh->getPolyData()));
 1223             d->vector_glyph->SetInput(static_cast<vtkUnstructuredGrid *>(d->mesh->getUnstructuredGrid()));
 1224         d->vector_glyph->SetSource(d->vector_glyph_source->GetOutput());
 1226         if(d->mesh->getPolyData())
 1227             d->vector_glyph->SetInputData(static_cast<vtkPolyData *>(d->mesh->getPolyData()));
 1229             d->vector_glyph->SetInputData(static_cast<vtkUnstructuredGrid *>(d->mesh->getUnstructuredGrid()));
 1230         d->vector_glyph->SetSourceData(d->vector_glyph_source->GetOutput());
 1233         d->vector_glyph->SetColorModeToColorByVector();
 1234         d->vector_glyph->SetVectorModeToUseVector();
 1236         d->vector_glyph->SetScaleModeToDataScalingOff();
 1239         d->vector_glyph->OrientOn();
 1240         d->vector_glyph->Update();
 1242         d->vector_glyph_mapper = vtkSmartPointer<vtkPolyDataMapper>::New();
 1243         d->vector_glyph_mapper->SetInputConnection(d->vector_glyph->GetOutputPort());
 1254         d->vector_glyph_actor = vtkSmartPointer<vtkActor>::New();
 1255         d->vector_glyph_actor->SetOrientation(d->mesh->getActor()->GetOrientation());
 1256         d->vector_glyph_actor->SetPosition(d->mesh->getActor()->GetPosition());
 1257         d->vector_glyph_actor->SetMapper(d->vector_glyph_mapper);
 1259         d->vector_glyph_actor->SetVisibility(0);
 1261         this->AddPart(d->vector_glyph_actor);
 1266         d->vector_stream_widget = vtkSmartPointer<vtkSphereWidget2>::New();
 1267         d->vector_stream_widget->SetInteractor(d->interactor);
 1268         d->vector_stream_widget->CreateDefaultRepresentation();
 1269         d->vector_stream_widget->SetTranslationEnabled(
true);
 1270         d->vector_stream_widget->SetScalingEnabled(
true);
 1271         d->vector_stream_widget->Off();
 1273         d->vector_stream_widget_data = vtkPolyData::New();
 1275         d->vector_stream_widget_representation = vtkSphereRepresentation::SafeDownCast(d->vector_stream_widget->GetRepresentation());
 1276         d->vector_stream_widget_representation->HandleVisibilityOff();
 1277         d->vector_stream_widget_representation->HandleTextOff();
 1278         d->vector_stream_widget_representation->RadialLineOff();
 1279         d->vector_stream_widget_representation->SetPhiResolution(64);
 1280         d->vector_stream_widget_representation->SetThetaResolution(64);
 1281         d->vector_stream_widget_representation->GetPolyData(d->vector_stream_widget_data);
 1283         d->vector_stream_tracer = vtkStreamTracer::New();
 1284 #if (VTK_MAJOR_VERSION <= 5)
 1285         d->vector_stream_tracer->SetInput(static_cast<vtkPolyData *>(d->mesh->getPolyData()));
 1286         d->vector_stream_tracer->SetSource(d->vector_stream_widget_data);
 1288         d->vector_stream_tracer->SetInputData(static_cast<vtkPolyData *>(d->mesh->getPolyData()));
 1289         d->vector_stream_tracer->SetSourceData(d->vector_stream_widget_data);
 1291         d->vector_stream_tracer->SetMaximumPropagation(100);
 1292         d->vector_stream_tracer->SetMinimumIntegrationStep(1.0e-4);
 1293         d->vector_stream_tracer->SetMaximumIntegrationStep(100.0);
 1294         d->vector_stream_tracer->SetIntegrationDirectionToBoth();
 1296         d->vector_stream_filter = vtkTubeFilter::New();
 1297 #if (VTK_MAJOR_VERSION <= 5)
 1298         d->vector_stream_filter->SetInput(d->vector_stream_tracer->GetOutput());
 1300         d->vector_stream_filter->SetInputData(d->vector_stream_tracer->GetOutput());
 1302         d->vector_stream_filter->SetRadius(0.01);
 1303         d->vector_stream_filter->SetNumberOfSides(8);
 1305         d->vector_stream_mapper = vtkSmartPointer<vtkPolyDataMapper>::New();
 1306         d->vector_stream_mapper->SetInputConnection(d->vector_stream_filter->GetOutputPort());
 1307         d->vector_stream_mapper->ScalarVisibilityOn();
 1309         d->vector_stream_actor = vtkSmartPointer<vtkActor>::New();
 1310         d->vector_stream_actor->SetOrientation(d->mesh->getActor()->GetOrientation());
 1311         d->vector_stream_actor->SetPosition(d->mesh->getActor()->GetPosition());
 1312         d->vector_stream_actor->SetMapper(d->vector_stream_mapper);
 1313         d->vector_stream_actor->SetVisibility(0);
 1316         d->vector_stream_observer->vector_stream_widget_representation = d->vector_stream_widget_representation;
 1317         d->vector_stream_observer->vector_stream_widget_data = d->vector_stream_widget_data;
 1318         d->vector_stream_observer->vector_stream_tracer = d->vector_stream_tracer;
 1319         d->vector_stream_widget->AddObserver(vtkCommand::InteractionEvent, d->vector_stream_observer);
 1321         this->AddPart(d->vector_stream_actor);
 1329     double field_range[2];d->array->GetRange(field_range);
 1330     return field_range[0];
 1335     double field_range[2];d->array->GetRange(field_range);
 1337     return field_range[1];
 1342     d->isoRadius = radius;
 1343     d->scalar_iso_tube_filter->SetRadius(radius);
 1344     d->scalar_iso_tube_filter->Update();
Class axlAbstractFieldParametric defines an API for parametric field.
void setIsoRangeMin(double min)
virtual double start_u(void)
Returns the first u-value parameter.
dtkAbstractData * data(void)
virtual double scalar(double u, double v=0, double w=0)
Returns the value of the parametric field at the parameters values in input.
vtkCxxRevisionMacro(axlActorFieldParametric,"$Revision: 0.0.1 $")
virtual double end_u(void)
Returns the last u-value parameter.
void setActiveFieldKind(void)
void setStreamRadius(double radius)
virtual double * tensor(double u, double v=0, double w=0)
Returns the value of the spatial field at the coordinates point entered.
virtual void Execute(vtkObject *caller, unsigned long event, void *)
void displayAsGlyph(void)
virtual double * tensor(double u, double v, double w)
virtual double scalar(double u, double v, double w=0)
virtual double numbersample_u(void)
Returns the number of u-parameters.
void * scalarColorMapper(void)
Class axlAbstractFieldParametricCurve defines an API for parametric field.
virtual double numbersample_v(void)
Returns the number of v-parameters.
virtual double start_v(void)
Returns the first v-value parameter.
virtual double end_w(void)
Returns the last w-value parameter.
vtkSmartPointer< vtkStreamTracer > vector_stream_tracer
void setActorField(axlAbstractActor *actor)
virtual double * vector(double u, double v, double w)
Returns the value of the parametric field evaluated at the parameters in input.
void setInteractor(void *interactor)
virtual double * tensor(double u, double v, double w=0)
axlAbstractActor * outputActor(void)
void onIsoRadiusChanged(double radius)
axlAbstractField * magnitude(void)
virtual double end_v(void)
Returns the last v-value parameter.
void setIsoRangeMax(double max)
vtkSmartPointer< vtkSphereRepresentation > vector_stream_widget_representation
axlAbstractActor * actorField(void)
virtual double * vector(double u, double v, double w=0)
void displayAsColor(void)
vtkScalarBarActor * scalarBar(void)
void setColRangeMax(double max)
vtkSmartPointer< vtkPolyData > vector_stream_widget_data
Class axlAbstractField defines an API for arrays of numeric data.
void setStreamPropagation(double propagation)
Class axlFieldDiscrete defines an API for arrays of numeric data.
virtual double numbersample_w(void)
Returns the number of w-parameters.
Class axlAbstractFieldParametricVolume defines an API for parametric field.
void displayAsNoneScalar(void)
void setColRangeMin(double min)
void setStreamDirection(int direction)
static axlActorFieldParametricStreamObserver * New(void)
axlAbstractField * field(void)
void displayAsHedge(void)
Class axlAbstractFieldParametricSurface defines an API for parametric field.
virtual void setData(dtkAbstractData *field)
~axlActorFieldParametric(void)
void displayAsStream(void)
void setGlyphScale(double scale)
virtual double start_w(void)
Returns the first w-value parameter.
Class axlAbstractData defines an API for all type of axel data.
void displayAsNoneVector(void)
void setIsoCount(int count)
double streamRadius(void)
virtual double scalar(double u, double v, double w)
virtual double * vector(double u, double v=0, double w=0)
vtkStandardNewMacro(axlActorFieldParametric)
