Class axlFieldDiscrete defines an API for arrays of numeric data. More...
#include <axlFieldDiscrete.h>
 | Public Slots | |
| virtual void | update (void) |
|  Public Slots inherited from axlAbstractFieldDiscrete | |
|  Public Slots inherited from axlAbstractField | |
|  Public Slots inherited from axlAbstractData | |
| void | touchGeometry (void) |
| void | touchProperty (void) |
| void | touchStructure (void) |
| virtual void | touchField (void) |
| void | setColor (const QColor &color) |
| void | setOpacity (const double &opacity) |
| void | setSize (const double &size) |
| void | setShader (const QString &shader) |
| void | setEditable (bool edit) |
| Signals | |
| void | updated (void) |
|  Signals inherited from axlAbstractFieldDiscrete | |
|  Signals inherited from axlAbstractField | |
|  Signals inherited from axlAbstractData | |
| void | modifiedGeometry (void) |
| void | modifiedStructure (void) |
| void | modifiedField (void) |
| void | modifiedProperty (void) |
| Public Member Functions | |
| axlFieldDiscrete () | |
| axlFieldDiscrete (QString name, Type type, Kind kind, Support support, int size) | |
| virtual | ~axlFieldDiscrete (void) |
| Destroys the discrete field.  More... | |
| virtual void | setScalar (int index, double v1) |
| virtual void | setVector (int index, double v1, double v2, double v3) |
| virtual void | setTensor (int index, double v1, double v2, double v3, double v4, double v5, double v6, double v7, double v8, double v9) |
| virtual int | size (void) |
| virtual void | setSize (int size) |
| virtual double | scalar (int index) |
| Returns the value at index location of the scalar array.  More... | |
| virtual double * | vector (int index) |
| Returns the value at index location of the vector array.  More... | |
| virtual double * | tensor (int index) |
| Returns the value at index location of the tensor array.  More... | |
| QString | description (void) const |
| Returns the description of the field.  More... | |
| QString | identifier (void) const |
| Returns the identifier "axlFieldDiscrete".  More... | |
|  Public Member Functions inherited from axlAbstractFieldDiscrete | |
| axlAbstractFieldDiscrete () | |
| axlAbstractFieldDiscrete (QString name, Type type, Kind kind, Support support, int size) | |
| axlAbstractFieldDiscrete (void *array) | |
| Constructs a discrete field from an array of underlying vtkDataArray type.  More... | |
| virtual | ~axlAbstractFieldDiscrete (void) |
|  Public Member Functions inherited from axlAbstractField | |
| axlAbstractField () | |
| axlAbstractField (QString name, Type type, Kind kind, Support support) | |
| virtual | ~axlAbstractField (void) |
| Destroys the field.  More... | |
| virtual void | setType (Type type) |
| Sets the type of the field which can be either int, float or double.  More... | |
| virtual void | setKind (Kind kind) |
| Sets the kind of the field which can be either scalar, vector or tensor.  More... | |
| virtual void | setSupport (Support support) |
| virtual Type | type (void) |
| virtual Kind | kind (void) |
| virtual Support | support (void) |
| virtual void | setMin (double mini) |
| Sets the minimum value of the field.  More... | |
| virtual double | minValue (void) |
| Returns the minimum value of the field.  More... | |
| virtual void | setMax (double maxi) |
| Sets the maximum value of the field..  More... | |
| virtual double | maxValue (void) |
| Returns the maximum value of the field.  More... | |
|  Public Member Functions inherited from axlAbstractData | |
| axlAbstractData (axlAbstractData *parent=NULL) | |
| axlAbstractData (const axlAbstractData &data) | |
| virtual | ~axlAbstractData (void) |
| const QColor & | color (void) const |
| const double & | opacity (void) const |
| const double & | size (void) const |
| const QString & | shader (void) const |
| const bool & | editable (void) |
| const bool & | updateView (void) |
| void | setColor (double r, double g, double b) |
| void | addField (axlAbstractField *field) |
| Add a field to the field list of the object.  More... | |
| bool | updateFieldList (QString nameField) |
| Check if a field with the same name is already applied on the object.  More... | |
| QString | changeFieldName (QString fieldName) |
| axlMesh * | mesh (void) |
| Return the mesh of that object is computed.  More... | |
| void | setMesh (axlMesh *mesh) |
| Set a corresponding mesh for that object.  More... | |
| virtual QVariantList | convertDataToQVariant (void) const |
| Convert an axlAbstractData into a QVariantList that specifies all properties of the axlAbstractData.  More... | |
| virtual int | convertQVariantToData (const QVariantList &data) |
| Modify properties and geometry variables of the axlAbstractData. Return 1 if the modification was sucessfully made. Otherwise return 0.  More... | |
| void | setUpdateView (bool updateView) |
| QList< axlAbstractField * > | fields (void) |
| Static Public Member Functions | |
| static bool | registered (void) |
| Additional Inherited Members | |
|  Public Types inherited from axlAbstractField | |
| enum | Type { Int = 0x001, Float = 0x002, Double = 0x004 } |
| enum | Kind { Scalar = 0x001, Vector = 0x002, Tensor = 0x004 } |
| enum | Support { Point = 0x001, Cell = 0x002, Custom = 0x004 } |
|  Properties inherited from axlAbstractData | |
| QColor | color |
| double | opacity |
| double | size |
| QString | shader |
! Returns a void pointer to the underlying vtkDataArray object. *!
This class, based on a wrapping of vtkDataArray class, enables to deal with different type (int, float or double) and different kind (scalar, vector, tensor) of data.
Definition at line 31 of file axlFieldDiscrete.h.
| axlFieldDiscrete::axlFieldDiscrete | ( | ) |
Definition at line 46 of file axlFieldDiscrete.cpp.
| axlFieldDiscrete::axlFieldDiscrete | ( | QString | name, |
| Type | type, | ||
| Kind | kind, | ||
| Support | support, | ||
| int | size | ||
Definition at line 55 of file axlFieldDiscrete.cpp.
 | virtual |
Definition at line 68 of file axlFieldDiscrete.cpp.
| QString axlFieldDiscrete::description | ( | void | ) | const |
! Returns the name the field. *! ! Returns the name the field. *!
Definition at line 428 of file axlFieldDiscrete.cpp.
 | virtual |
Reimplemented from axlAbstractField.
Definition at line 501 of file axlFieldDiscrete.cpp.
 | static |
Definition at line 75 of file axlFieldDiscrete.cpp.
 | virtual |
Reimplemented from axlAbstractFieldDiscrete.
Definition at line 296 of file axlFieldDiscrete.cpp.
 | virtual |
Set a scalar element v1 at index location in the scalar data array.
Definition at line 84 of file axlFieldDiscrete.cpp.
 | virtual |
Definition at line 286 of file axlFieldDiscrete.cpp.
 | virtual |
Set a tensor element (v1, v2, v3, v4, v5, v6, v7, v8, v9) at index location in the tensor data array.
Definition at line 186 of file axlFieldDiscrete.cpp.
 | virtual |
Set a vector element (v1, v2, v3) at index location in the vector data array.
Definition at line 124 of file axlFieldDiscrete.cpp.
 | virtual |
Definition at line 281 of file axlFieldDiscrete.cpp.
 | virtual |
Definition at line 353 of file axlFieldDiscrete.cpp.
 | virtualslot |
Mark the internal data structure as changed to notify underlying pipeline execution.
Definition at line 511 of file axlFieldDiscrete.cpp.
 | signal |
 | virtual |
Definition at line 319 of file axlFieldDiscrete.cpp.
