Developer documentation | Axl-2.5.1
axlAbstractFieldParametricVolume.h
Go to the documentation of this file.
1 /* axlAbstractFieldParametricVolume.h ---
2  *
3  * Author: Anais Ducoffe
4  * Copyright (C) 2013 - Anais Ducoffe, Inria.
5  */
6
7 /* Commentary:
8  *
9  */
10
11 /* Change log:
12  *
13  */
14 #include "axlCoreExport.h"
15 #ifndef AXLABSTRACTFIELDPARAMETRICVOLUME_H
16 #define AXLABSTRACTFIELDPARAMETRICVOLUME_H
17
19
20 class axlAbstractFieldParametricVolumePrivate;
21 class axlAbstractData;
22
24 {
25  Q_OBJECT
26
27 public:
29  virtual ~axlAbstractFieldParametricVolume(void);
30
31  virtual void setVolume(axlAbstractData *Volume);
32
33  virtual int size(void);
34
35  virtual double scalar(double u, double v, double w);
36  virtual double *vector(double u, double v, double w);
37  virtual double *tensor(double u, double v, double w);
38
39  virtual double start_u(void);
40  virtual double start_v(void);
41  virtual double start_w(void);
42
43  virtual double end_u(void);
44  virtual double end_v(void);
45  virtual double end_w(void);
46
47  virtual double numbersample_u(void);
48  virtual double numbersample_v(void);
49  virtual double numbersample_w(void);
50
51  virtual void setFunction(axlAbstractData *data);
52  virtual axlAbstractData *getFunction(void);
53
54  virtual QString description(void) const;
55  virtual QString identifier(void) const;
56
57 signals :
58  void updated(void);
59
60
61 public slots:
62  virtual void update(void);
63
64
65 private:
66  axlAbstractFieldParametricVolumePrivate *d;
67 };
68
69 dtkAbstractData *createaxlAbstractFieldParametricVolume(void);
70
71
72 #endif // AXLABSTRACTFIELDPARAMETRICVOLUME_H
Returns the description of the field.
Class axlAbstractFieldParametric defines an API for parametric field.
Returns number of parameters on which the field is evaluated.
virtual double * tensor(double u, double v=0, double w=0)
Returns the value of the spatial field at the coordinates point entered.
virtual axlAbstractData * getFunction(void)
virtual double * vector(double u, double v=0, double w=0)
Returns the value of the parametric field evaluated at the parameters in input.
virtual double scalar(double u, double v=0, double w=0)
Returns the value of the parametric field at the parameters values in input.
Class axlAbstractFieldParametricVolume defines an API for parametric field.
#define AXLCORE_EXPORT
Class axlAbstractData defines an API for all type of axel data.
dtkAbstractData * createaxlAbstractFieldParametricVolume(void)
