Developer documentation | Axl-2.5.1
axlAbstractFieldParametricSurface.h
Go to the documentation of this file.
1 /* axlAbstractFieldParametricSurface.h ---
2  *
3  * Author: Anais Ducoffe
4  * Copyright (C) 2013 - Anais Ducoffe, Inria.
5  */
6
7 /* Commentary:
8  *
9  */
10
11 /* Change log:
12  *
13  */
14 #include "axlCoreExport.h"
15 #ifndef AXLABSTRACTFIELDPARAMETRICSURFACE_H
16 #define AXLABSTRACTFIELDPARAMETRICSURFACE_H
17
19
20 class axlAbstractFieldParametricSurfacePrivate;
21 class axlAbstractData;
22
24 {
25  Q_OBJECT
26
27 public:
29  virtual ~axlAbstractFieldParametricSurface(void);
30
31  // void setType(Type type);
32  // void setKind(Kind kind);
33  // void setSupport(Support support);
34
35
36  // Type type(void);
37  // Kind kind(void);
38  // Support support(void);
39
40  virtual void setSurface(axlAbstractData *surface);
41
42  virtual int size(void);
43
44  virtual double scalar(double u, double v, double w = 0);
45  virtual double *vector(double u, double v, double w = 0);
46  virtual double *tensor(double u, double v, double w = 0);
47
48  virtual double start_u(void);
49  virtual double start_v(void);
50  // virtual double start_w(void);
51
52  virtual double end_u(void);
53  virtual double end_v(void);
54  // virtual double end_w(void);
55
56  virtual double numbersample_u(void);
57  virtual double numbersample_v(void);
58  // virtual double numbersample_w(void);
59
60  virtual void setFunction(axlAbstractData *data);
61  virtual axlAbstractData *getFunction(void);
62
63  virtual QString description(void) const;
64  virtual QString identifier(void) const;
65  // virtual QString name(void);
66  // virtual void setName(QString name);
67
68 signals :
69  void updated(void);
70
71
72 public slots:
73  virtual void update(void);
74
75
76 private:
77  axlAbstractFieldParametricSurfacePrivate *d;
78 };
79
80 dtkAbstractData *createaxlAbstractFieldParametricSurface(void);
81
82
83 #endif // AXLABSTRACTFIELDPARAMETRICSURFACE_H
Returns the description of the field.
Class axlAbstractFieldParametric defines an API for parametric field.
Returns number of parameters on which the field is evaluated.
dtkAbstractData * createaxlAbstractFieldParametricSurface(void)
virtual double * tensor(double u, double v=0, double w=0)
Returns the value of the spatial field at the coordinates point entered.
virtual axlAbstractData * getFunction(void)
virtual double * vector(double u, double v=0, double w=0)
Returns the value of the parametric field evaluated at the parameters in input.
virtual double scalar(double u, double v=0, double w=0)
Returns the value of the parametric field at the parameters values in input.
#define AXLCORE_EXPORT
Class axlAbstractFieldParametricSurface defines an API for parametric field.
Class axlAbstractData defines an API for all type of axel data.
