Class axlAbstractField defines an API for arrays of numeric data. More...
#include <axlAbstractField.h>
Public Types | |
enum | Type { Int = 0x001, Float = 0x002, Double = 0x004 } |
enum | Kind { Scalar = 0x001, Vector = 0x002, Tensor = 0x004 } |
enum | Support { Point = 0x001, Cell = 0x002, Custom = 0x004 } |
Public Slots | |
virtual void | update (void) |
void | touchGeometry (void) |
void | touchProperty (void) |
void | touchStructure (void) |
virtual void | touchField (void) |
void | setColor (const QColor &color) |
void | setOpacity (const double &opacity) |
void | setSize (const double &size) |
void | setShader (const QString &shader) |
void | setEditable (bool edit) |
Signals | |
void | updated (void) |
void | modifiedGeometry (void) |
void | modifiedStructure (void) |
void | modifiedField (void) |
void | modifiedProperty (void) |
Public Member Functions | |
axlAbstractField () | |
axlAbstractField (QString name, Type type, Kind kind, Support support) | |
virtual | ~axlAbstractField (void) |
Destroys the field. More... | |
virtual void | setType (Type type) |
Sets the type of the field which can be either int, float or double. More... | |
virtual void | setKind (Kind kind) |
Sets the kind of the field which can be either scalar, vector or tensor. More... | |
virtual void | setSupport (Support support) |
virtual Type | type (void) |
virtual Kind | kind (void) |
virtual Support | support (void) |
virtual void | setMin (double mini) |
Sets the minimum value of the field. More... | |
virtual double | minValue (void) |
Returns the minimum value of the field. More... | |
virtual void | setMax (double maxi) |
Sets the maximum value of the field.. More... | |
virtual double | maxValue (void) |
Returns the maximum value of the field. More... | |
virtual QString | identifier (void) const |
axlAbstractData (axlAbstractData *parent=NULL) | |
axlAbstractData (const axlAbstractData &data) | |
virtual | ~axlAbstractData (void) |
const QColor & | color (void) const |
const double & | opacity (void) const |
const double & | size (void) const |
const QString & | shader (void) const |
const bool & | editable (void) |
const bool & | updateView (void) |
void | setColor (double r, double g, double b) |
void | addField (axlAbstractField *field) |
Add a field to the field list of the object. More... | |
bool | updateFieldList (QString nameField) |
Check if a field with the same name is already applied on the object. More... | |
QString | changeFieldName (QString fieldName) |
axlMesh * | mesh (void) |
Return the mesh of that object is computed. More... | |
void | setMesh (axlMesh *mesh) |
Set a corresponding mesh for that object. More... | |
virtual QVariantList | convertDataToQVariant (void) const |
Convert an axlAbstractData into a QVariantList that specifies all properties of the axlAbstractData. More... | |
virtual int | convertQVariantToData (const QVariantList &data) |
Modify properties and geometry variables of the axlAbstractData. Return 1 if the modification was sucessfully made. Otherwise return 0. More... | |
void | setUpdateView (bool updateView) |
QList< axlAbstractField * > | fields (void) |
Additional Inherited Members | |
QColor | color |
double | opacity |
double | size |
QString | shader |
! Returns a void pointer to the underlying vtkDataArray object. *!
This class, based on a wrapping of vtkDataArray class, enables to deal with different type (int, float or double) and different kind (scalar, vector, tensor) of data.
Definition at line 29 of file axlAbstractField.h.
Enumerator | |
Scalar | |
Vector | |
Tensor |
Definition at line 40 of file axlAbstractField.h.
Enumerator | |
Point | |
Cell | |
Custom |
Definition at line 46 of file axlAbstractField.h.
Enumerator | |
Int | |
Float | |
Double |
Definition at line 34 of file axlAbstractField.h.
axlAbstractField::axlAbstractField | ( | ) |
Definition at line 43 of file axlAbstractField.cpp.
Definition at line 56 of file axlAbstractField.cpp.
virtual |
Destroys the field.
Definition at line 71 of file axlAbstractField.cpp.
virtual |
Return the identifier of an axlAbstractField which is empty.
Reimplemented in axlAbstractFieldParametricSurface, axlFieldParametricVolume, axlAbstractFieldParametric, axlFieldDiscrete, axlFieldParametricSurface, axlFieldParametricCurve, axlAbstractFieldParametricVolume, axlFieldParametricVolumeTangentVector, axlFieldParametricSurfaceTangentVector, axlAbstractFieldParametricCurve, axlFieldParametricNormalVector, axlFieldParametricCurveTangentVector, axlAbstractFieldSpatial, axlFieldSpatialPointDistance, and axlFieldSpatialCoordinates.
Definition at line 272 of file axlAbstractField.cpp.
virtual |
Definition at line 148 of file axlAbstractField.cpp.
virtual |
Definition at line 194 of file axlAbstractField.cpp.
virtual |
Definition at line 175 of file axlAbstractField.cpp.
virtual |
Definition at line 88 of file axlAbstractField.cpp.
virtual |
Definition at line 203 of file axlAbstractField.cpp.
virtual |
Definition at line 184 of file axlAbstractField.cpp.
virtual |
Definition at line 97 of file axlAbstractField.cpp.
virtual |
Definition at line 79 of file axlAbstractField.cpp.
virtual |
Definition at line 153 of file axlAbstractField.cpp.
virtual |
Definition at line 143 of file axlAbstractField.cpp.
virtualslot |
! Returns the value at index location of the scalar array. *! ! Returns the value at index location of the vector array. *! ! Returns the value at index location of the tensor array. *! ! Returns the name the field. *! Mark the internal data structure as changed to notify underlying pipeline execution.
Definition at line 262 of file axlAbstractField.cpp.
signal |
