Class axlAbstractData defines an API for all type of axel data. More...
#include <axlAbstractData.h>
 | Public Slots | |
| void | touchGeometry (void) |
| void | touchProperty (void) |
| void | touchStructure (void) |
| virtual void | touchField (void) |
| void | setColor (const QColor &color) |
| void | setOpacity (const double &opacity) |
| void | setSize (const double &size) |
| void | setShader (const QString &shader) |
| void | setEditable (bool edit) |
| Signals | |
| void | modifiedGeometry (void) |
| void | modifiedStructure (void) |
| void | modifiedField (void) |
| void | modifiedProperty (void) |
| Public Member Functions | |
| axlAbstractData (axlAbstractData *parent=NULL) | |
| axlAbstractData (const axlAbstractData &data) | |
| virtual | ~axlAbstractData (void) |
| const QColor & | color (void) const |
| const double & | opacity (void) const |
| const double & | size (void) const |
| const QString & | shader (void) const |
| const bool & | editable (void) |
| const bool & | updateView (void) |
| void | setColor (double r, double g, double b) |
| void | addField (axlAbstractField *field) |
| Add a field to the field list of the object.  More... | |
| bool | updateFieldList (QString nameField) |
| Check if a field with the same name is already applied on the object.  More... | |
| QString | changeFieldName (QString fieldName) |
| axlMesh * | mesh (void) |
| Return the mesh of that object is computed.  More... | |
| void | setMesh (axlMesh *mesh) |
| Set a corresponding mesh for that object.  More... | |
| virtual QVariantList | convertDataToQVariant (void) const |
| Convert an axlAbstractData into a QVariantList that specifies all properties of the axlAbstractData.  More... | |
| virtual int | convertQVariantToData (const QVariantList &data) |
| Modify properties and geometry variables of the axlAbstractData. Return 1 if the modification was sucessfully made. Otherwise return 0.  More... | |
| void | setUpdateView (bool updateView) |
| QList< axlAbstractField * > | fields (void) |
| Properties | |
| QColor | color |
| double | opacity |
| double | size |
| QString | shader |
Every axel data must inherite from this abstract class.
Definition at line 33 of file axlAbstractData.h.
| axlAbstractData::axlAbstractData | ( | axlAbstractData * | parent = NULL | ) |
Definition at line 44 of file axlAbstractData.cpp.
| axlAbstractData::axlAbstractData | ( | const axlAbstractData & | data | ) |
Definition at line 54 of file axlAbstractData.cpp.
 | virtual |
Definition at line 66 of file axlAbstractData.cpp.
| void axlAbstractData::addField | ( | axlAbstractField * | field | ) |
Definition at line 160 of file axlAbstractData.cpp.
| QString axlAbstractData::changeFieldName | ( | QString | nameField | ) |
Check if a field with the same name is already applied on the object. Modify nameField if it's the case. Field names must be unique!
Definition at line 187 of file axlAbstractData.cpp.
| const QColor & axlAbstractData::color | ( | void | ) | const |
Definition at line 72 of file axlAbstractData.cpp.
 | virtual |
Reimplemented in axlMesh, axlShape, axlAbstractVolumeBSpline, axlPoint, axlEllipsoid, axlAbstractSurfaceBSpline, axlAbstractCurveBSpline, axlCone, axlLine, axlSphere, axlDataDynamic, axlCircleArc, axlCylinder, axlTorus, axlPlane, axlDouble, and axlInteger.
Definition at line 233 of file axlAbstractData.cpp.
 | virtual |
Reimplemented in axlMesh, axlShape, axlAbstractVolumeBSpline, axlPoint, axlEllipsoid, axlAbstractSurfaceBSpline, axlAbstractCurveBSpline, axlDataDynamic, axlCone, axlLine, axlSphere, axlCircleArc, axlCylinder, axlTorus, axlPlane, axlDouble, and axlInteger.
Definition at line 244 of file axlAbstractData.cpp.
| const bool & axlAbstractData::editable | ( | void | ) |
Definition at line 122 of file axlAbstractData.cpp.
| QList< axlAbstractField * > axlAbstractData::fields | ( | void | ) |
Definition at line 204 of file axlAbstractData.cpp.
| axlMesh * axlAbstractData::mesh | ( | void | ) |
Definition at line 142 of file axlAbstractData.cpp.
 | signal |
 | signal |
 | signal |
 | signal |
| const double & axlAbstractData::opacity | ( | void | ) | const |
Definition at line 87 of file axlAbstractData.cpp.
| void axlAbstractData::setColor | ( | double | r, |
| double | g, | ||
| double | b | ||
Definition at line 82 of file axlAbstractData.cpp.
 | slot |
Definition at line 77 of file axlAbstractData.cpp.
 | slot |
Definition at line 132 of file axlAbstractData.cpp.
| void axlAbstractData::setMesh | ( | axlMesh * | mesh | ) |
Definition at line 151 of file axlAbstractData.cpp.
 | slot |
Definition at line 92 of file axlAbstractData.cpp.
 | slot |
Definition at line 127 of file axlAbstractData.cpp.
 | slot |
Definition at line 102 of file axlAbstractData.cpp.
| void axlAbstractData::setUpdateView | ( | bool | updateView | ) |
Definition at line 112 of file axlAbstractData.cpp.
| const QString & axlAbstractData::shader | ( | void | ) | const |
Definition at line 117 of file axlAbstractData.cpp.
| const double & axlAbstractData::size | ( | void | ) | const |
Definition at line 97 of file axlAbstractData.cpp.
 | virtualslot |
Definition at line 209 of file axlAbstractData.cpp.
 | slot |
Definition at line 214 of file axlAbstractData.cpp.
 | slot |
Definition at line 219 of file axlAbstractData.cpp.
 | slot |
Definition at line 224 of file axlAbstractData.cpp.
| bool axlAbstractData::updateFieldList | ( | QString | nameField | ) |
Definition at line 171 of file axlAbstractData.cpp.
| const bool & axlAbstractData::updateView | ( | void | ) |
Definition at line 107 of file axlAbstractData.cpp.
 | readwrite |
Definition at line 36 of file axlAbstractData.h.
 | readwrite |
Definition at line 37 of file axlAbstractData.h.
 | readwrite |
Definition at line 39 of file axlAbstractData.h.
 | readwrite |
Definition at line 38 of file axlAbstractData.h.
