Class axlAbstractFieldParametric defines an API for parametric field. More...
#include <axlAbstractFieldParametric.h>
 | Public Slots | |
| virtual void | update (void) |
|  Public Slots inherited from axlAbstractField | |
|  Public Slots inherited from axlAbstractData | |
| void | touchGeometry (void) |
| void | touchProperty (void) |
| void | touchStructure (void) |
| virtual void | touchField (void) |
| void | setColor (const QColor &color) |
| void | setOpacity (const double &opacity) |
| void | setSize (const double &size) |
| void | setShader (const QString &shader) |
| void | setEditable (bool edit) |
| Signals | |
| void | updated (void) |
|  Signals inherited from axlAbstractField | |
|  Signals inherited from axlAbstractData | |
| void | modifiedGeometry (void) |
| void | modifiedStructure (void) |
| void | modifiedField (void) |
| void | modifiedProperty (void) |
| Public Member Functions | |
| axlAbstractFieldParametric () | |
| virtual | ~axlAbstractFieldParametric (void) |
| Destroys a parametric field.  More... | |
| virtual int | size (void) |
| Returns number of parameters on which the field is evaluated.  More... | |
| virtual double | scalar (double u, double v=0, double w=0) |
| Returns the value of the parametric field at the parameters values in input.  More... | |
| virtual double * | vector (double u, double v=0, double w=0) |
| Returns the value of the parametric field evaluated at the parameters in input.  More... | |
| virtual double * | tensor (double u, double v=0, double w=0) |
| Returns the value of the spatial field at the coordinates point entered.  More... | |
| virtual void | setFunction (axlAbstractData *data) |
| Returns the description of the field.  More... | |
| virtual axlAbstractData * | getFunction (void) |
| virtual QString | description (void) const |
| virtual QString | identifier (void) const |
|  Public Member Functions inherited from axlAbstractField | |
| axlAbstractField () | |
| axlAbstractField (QString name, Type type, Kind kind, Support support) | |
| virtual | ~axlAbstractField (void) |
| Destroys the field.  More... | |
| virtual void | setType (Type type) |
| Sets the type of the field which can be either int, float or double.  More... | |
| virtual void | setKind (Kind kind) |
| Sets the kind of the field which can be either scalar, vector or tensor.  More... | |
| virtual void | setSupport (Support support) |
| virtual Type | type (void) |
| virtual Kind | kind (void) |
| virtual Support | support (void) |
| virtual void | setMin (double mini) |
| Sets the minimum value of the field.  More... | |
| virtual double | minValue (void) |
| Returns the minimum value of the field.  More... | |
| virtual void | setMax (double maxi) |
| Sets the maximum value of the field..  More... | |
| virtual double | maxValue (void) |
| Returns the maximum value of the field.  More... | |
|  Public Member Functions inherited from axlAbstractData | |
| axlAbstractData (axlAbstractData *parent=NULL) | |
| axlAbstractData (const axlAbstractData &data) | |
| virtual | ~axlAbstractData (void) |
| const QColor & | color (void) const |
| const double & | opacity (void) const |
| const double & | size (void) const |
| const QString & | shader (void) const |
| const bool & | editable (void) |
| const bool & | updateView (void) |
| void | setColor (double r, double g, double b) |
| void | addField (axlAbstractField *field) |
| Add a field to the field list of the object.  More... | |
| bool | updateFieldList (QString nameField) |
| Check if a field with the same name is already applied on the object.  More... | |
| QString | changeFieldName (QString fieldName) |
| axlMesh * | mesh (void) |
| Return the mesh of that object is computed.  More... | |
| void | setMesh (axlMesh *mesh) |
| Set a corresponding mesh for that object.  More... | |
| virtual QVariantList | convertDataToQVariant (void) const |
| Convert an axlAbstractData into a QVariantList that specifies all properties of the axlAbstractData.  More... | |
| virtual int | convertQVariantToData (const QVariantList &data) |
| Modify properties and geometry variables of the axlAbstractData. Return 1 if the modification was sucessfully made. Otherwise return 0.  More... | |
| void | setUpdateView (bool updateView) |
| QList< axlAbstractField * > | fields (void) |
| Additional Inherited Members | |
|  Public Types inherited from axlAbstractField | |
| enum | Type { Int = 0x001, Float = 0x002, Double = 0x004 } |
| enum | Kind { Scalar = 0x001, Vector = 0x002, Tensor = 0x004 } |
| enum | Support { Point = 0x001, Cell = 0x002, Custom = 0x004 } |
|  Properties inherited from axlAbstractData | |
| QColor | color |
| double | opacity |
| double | size |
| QString | shader |
Definition at line 22 of file axlAbstractFieldParametric.h.
| axlAbstractFieldParametric::axlAbstractFieldParametric | ( | ) |
Definition at line 38 of file axlAbstractFieldParametric.cpp.
 | virtual |
Definition at line 49 of file axlAbstractFieldParametric.cpp.
 | virtual |
Reimplemented in axlAbstractFieldParametricSurface, axlFieldParametricVolume, axlFieldParametricSurface, axlFieldParametricCurve, axlAbstractFieldParametricVolume, axlFieldParametricVolumeTangentVector, axlFieldParametricSurfaceTangentVector, axlAbstractFieldParametricCurve, axlFieldParametricNormalVector, and axlFieldParametricCurveTangentVector.
Definition at line 187 of file axlAbstractFieldParametric.cpp.
 | virtual |
Reimplemented in axlAbstractFieldParametricSurface, axlAbstractFieldParametricVolume, axlAbstractFieldParametricCurve, axlFieldParametricCurve, axlFieldParametricSurface, and axlFieldParametricVolume.
Definition at line 178 of file axlAbstractFieldParametric.cpp.
 | virtual |
Reimplemented from axlAbstractField.
Definition at line 200 of file axlAbstractFieldParametric.cpp.
 | virtual |
Reimplemented in axlFieldParametricVolume, axlFieldParametricSurface, axlFieldParametricCurve, axlAbstractFieldParametricSurface, axlAbstractFieldParametricCurve, and axlAbstractFieldParametricVolume.
Definition at line 70 of file axlAbstractFieldParametric.cpp.
 | virtual |
Definition at line 168 of file axlAbstractFieldParametric.cpp.
 | virtual |
Reimplemented in axlFieldParametricVolume, axlFieldParametricSurface, axlFieldParametricVolumeTangentVector, axlFieldParametricCurve, axlFieldParametricSurfaceTangentVector, axlAbstractFieldParametricSurface, axlFieldParametricNormalVector, axlFieldParametricCurveTangentVector, axlAbstractFieldParametricCurve, and axlAbstractFieldParametricVolume.
Definition at line 61 of file axlAbstractFieldParametric.cpp.
 | virtual |
Definition at line 96 of file axlAbstractFieldParametric.cpp.
 | virtualslot |
Mark the internal data structure as changed to notify underlying pipeline execution.
Definition at line 225 of file axlAbstractFieldParametric.cpp.
 | signal |
 | virtual |
Reimplemented in axlFieldParametricVolume, axlFieldParametricSurface, axlFieldParametricCurve, axlFieldParametricVolumeTangentVector, axlFieldParametricSurfaceTangentVector, axlAbstractFieldParametricSurface, axlFieldParametricNormalVector, axlFieldParametricCurveTangentVector, axlAbstractFieldParametricCurve, and axlAbstractFieldParametricVolume.
Definition at line 83 of file axlAbstractFieldParametric.cpp.
