Class axlAbstractFieldParametricCurve defines an API for parametric field. More...
#include <axlAbstractFieldParametricCurve.h>
Public Slots | |
| virtual void | update (void) |
Public Slots inherited from axlAbstractFieldParametric | |
Public Slots inherited from axlAbstractField | |
Public Slots inherited from axlAbstractData | |
| void | touchGeometry (void) |
| void | touchProperty (void) |
| void | touchStructure (void) |
| virtual void | touchField (void) |
| void | setColor (const QColor &color) |
| void | setOpacity (const double &opacity) |
| void | setSize (const double &size) |
| void | setShader (const QString &shader) |
| void | setEditable (bool edit) |
Signals | |
| void | updated (void) |
Signals inherited from axlAbstractFieldParametric | |
Signals inherited from axlAbstractField | |
Signals inherited from axlAbstractData | |
| void | modifiedGeometry (void) |
| void | modifiedStructure (void) |
| void | modifiedField (void) |
| void | modifiedProperty (void) |
Public Member Functions | |
| axlAbstractFieldParametricCurve () | |
| virtual | ~axlAbstractFieldParametricCurve (void) |
| Destroys a parametric field. More... | |
| virtual void | setCurve (axlAbstractData *Curve) |
| Sets the support Curve of the field. More... | |
| virtual int | size (void) |
| Returns number of parameters on which the field is evaluated. More... | |
| virtual double | scalar (double u, double v=0, double w=0) |
| Returns the value of the parametric field at the parameters values in input. More... | |
| virtual double * | vector (double u, double v=0, double w=0) |
| Returns the value of the parametric field evaluated at the parameters in input. More... | |
| virtual double * | tensor (double u, double v=0, double w=0) |
| Returns the value of the spatial field at the coordinates point entered. More... | |
| virtual double | start_u (void) |
| Returns the first u-value parameter. More... | |
| virtual double | end_u (void) |
| Returns the last v-value parameter. More... | |
| virtual double | numbersample_u (void) |
| Returns the number of u-parameters. More... | |
| virtual void | setFunction (axlAbstractData *data) |
| Returns the description of the field. More... | |
| virtual axlAbstractData * | getFunction (void) |
| virtual QString | description (void) const |
| virtual QString | identifier (void) const |
Public Member Functions inherited from axlAbstractFieldParametric | |
| axlAbstractFieldParametric () | |
| virtual | ~axlAbstractFieldParametric (void) |
Public Member Functions inherited from axlAbstractField | |
| axlAbstractField () | |
| axlAbstractField (QString name, Type type, Kind kind, Support support) | |
| virtual | ~axlAbstractField (void) |
| Destroys the field. More... | |
| virtual void | setType (Type type) |
| Sets the type of the field which can be either int, float or double. More... | |
| virtual void | setKind (Kind kind) |
| Sets the kind of the field which can be either scalar, vector or tensor. More... | |
| virtual void | setSupport (Support support) |
| virtual Type | type (void) |
| virtual Kind | kind (void) |
| virtual Support | support (void) |
| virtual void | setMin (double mini) |
| Sets the minimum value of the field. More... | |
| virtual double | minValue (void) |
| Returns the minimum value of the field. More... | |
| virtual void | setMax (double maxi) |
| Sets the maximum value of the field.. More... | |
| virtual double | maxValue (void) |
| Returns the maximum value of the field. More... | |
Public Member Functions inherited from axlAbstractData | |
| axlAbstractData (axlAbstractData *parent=NULL) | |
| axlAbstractData (const axlAbstractData &data) | |
| virtual | ~axlAbstractData (void) |
| const QColor & | color (void) const |
| const double & | opacity (void) const |
| const double & | size (void) const |
| const QString & | shader (void) const |
| const bool & | editable (void) |
| const bool & | updateView (void) |
| void | setColor (double r, double g, double b) |
| void | addField (axlAbstractField *field) |
| Add a field to the field list of the object. More... | |
| bool | updateFieldList (QString nameField) |
| Check if a field with the same name is already applied on the object. More... | |
| QString | changeFieldName (QString fieldName) |
| axlMesh * | mesh (void) |
| Return the mesh of that object is computed. More... | |
| void | setMesh (axlMesh *mesh) |
| Set a corresponding mesh for that object. More... | |
| virtual QVariantList | convertDataToQVariant (void) const |
| Convert an axlAbstractData into a QVariantList that specifies all properties of the axlAbstractData. More... | |
| virtual int | convertQVariantToData (const QVariantList &data) |
| Modify properties and geometry variables of the axlAbstractData. Return 1 if the modification was sucessfully made. Otherwise return 0. More... | |
| void | setUpdateView (bool updateView) |
| QList< axlAbstractField * > | fields (void) |
Additional Inherited Members | |
Public Types inherited from axlAbstractField | |
| enum | Type { Int = 0x001, Float = 0x002, Double = 0x004 } |
| enum | Kind { Scalar = 0x001, Vector = 0x002, Tensor = 0x004 } |
| enum | Support { Point = 0x001, Cell = 0x002, Custom = 0x004 } |
Properties inherited from axlAbstractData | |
| QColor | color |
| double | opacity |
| double | size |
| QString | shader |
Definition at line 23 of file axlAbstractFieldParametricCurve.h.
| axlAbstractFieldParametricCurve::axlAbstractFieldParametricCurve | ( | ) |
Definition at line 37 of file axlAbstractFieldParametricCurve.cpp.
virtual |
Definition at line 47 of file axlAbstractFieldParametricCurve.cpp.
virtual |
Reimplemented from axlAbstractFieldParametric.
Reimplemented in axlFieldParametricCurve, and axlFieldParametricCurveTangentVector.
Definition at line 171 of file axlAbstractFieldParametricCurve.cpp.
virtual |
Definition at line 129 of file axlAbstractFieldParametricCurve.cpp.
virtual |
Reimplemented in axlFieldParametricCurve.
Definition at line 162 of file axlAbstractFieldParametricCurve.cpp.
virtual |
Definition at line 184 of file axlAbstractFieldParametricCurve.cpp.
virtual |
Definition at line 141 of file axlAbstractFieldParametricCurve.cpp.
virtual |
Definition at line 77 of file axlAbstractFieldParametricCurve.cpp.
virtual |
Definition at line 59 of file axlAbstractFieldParametricCurve.cpp.
virtual |
Definition at line 152 of file axlAbstractFieldParametricCurve.cpp.
virtual |
Definition at line 68 of file axlAbstractFieldParametricCurve.cpp.
virtual |
Definition at line 118 of file axlAbstractFieldParametricCurve.cpp.
virtual |
Definition at line 103 of file axlAbstractFieldParametricCurve.cpp.
virtualslot |
Mark the internal data structure as changed to notify underlying pipeline execution.
Definition at line 196 of file axlAbstractFieldParametricCurve.cpp.
signal |
virtual |
Definition at line 90 of file axlAbstractFieldParametricCurve.cpp.
