19 #include <dtkCoreSupport/dtkGlobal.h>
21 #include <dtkCoreSupport/dtkAbstractDataFactory.h>
22 #include <dtkCoreSupport/dtkAbstractProcessFactory.h>
24 class axlAbstractFieldParametricSurfacePrivate
61 DTK_DEFAULT_IMPLEMENTATION;
69 DTK_DEFAULT_IMPLEMENTATION;
80 qDebug() <<
"Getting scalar value on non scalar field.";
93 qDebug() <<
"Getting vector value on non vector field.";
106 qDebug() <<
"Getting tensor value on non tensor field.";
120 DTK_DEFAULT_IMPLEMENTATION;
131 DTK_DEFAULT_IMPLEMENTATION;
148 DTK_DEFAULT_IMPLEMENTATION;
159 DTK_DEFAULT_IMPLEMENTATION;
176 DTK_DEFAULT_IMPLEMENTATION;
187 DTK_DEFAULT_IMPLEMENTATION;
205 DTK_DEFAULT_IMPLEMENTATION;
224 DTK_DEFAULT_IMPLEMENTATION;
237 DTK_DEFAULT_IMPLEMENTATION;
Class axlAbstractFieldParametric defines an API for parametric field.
virtual axlAbstractData * getFunction(void)
Returns the description of the field.
virtual double start_u(void)
Returns the first u-value parameter.
virtual int size(void)
Returns number of parameters on which the field is evaluated.
virtual double scalar(double u, double v, double w=0)
Returns the value of the parametric field at the parameters values in input.
virtual void update(void)
virtual double start_v(void)
Returns the first v-value parameter.
virtual double numbersample_v(void)
Returns the number of v-parameters.
virtual void setFunction(axlAbstractData *data)
virtual double numbersample_u(void)
Returns the number of u-parameters.
virtual double * tensor(double u, double v, double w=0)
Returns the value of the spatial field at the coordinates point entered.
virtual double end_u(void)
Returns the last v-value parameter.
virtual double * vector(double u, double v, double w=0)
Returns the value of the parametric field evaluated at the parameters in input.
axlAbstractFieldParametricSurface()
dtkAbstractData * createaxlAbstractFieldParametricSurface(void)
virtual double end_v(void)
virtual QString identifier(void) const
virtual QString description(void) const
Class axlAbstractFieldParametricSurface defines an API for parametric field.
virtual void setSurface(axlAbstractData *surface)
Sets the support surface of the field.
Class axlAbstractData defines an API for all type of axel data.
virtual ~axlAbstractFieldParametricSurface(void)
Destroys a parametric field.
