21 #include <dtkCoreSupport/dtkAbstractData.h>
   22 #include <dtkCoreSupport/dtkAbstractDataFactory.h>
   44     return "axlShapeReader";
   48     return "axlShapeReader";
   52     return QStringList() <<
"axlShape";
   56     return dtkAbstractDataFactory::instance()->registerDataReaderType(
"axlShapeReader", QStringList(),
createaxlShapeReader);
   60     QDomElement element = node.toElement();
   62     if (element.tagName() !=
"shape")
   69     return !this->
accept(node);
   74     QDomElement element = node.toElement();
   77     int vertexCount = element.attribute(
"nb_vertices").toInt();
   78     int edgeCount = element.attribute(
"nb_edges").toInt();
   79     int faceCount = element.attribute(
"nb_faces").toInt();
   83     QString name = element.attribute(
"name");
   84     if (!name.isEmpty()) {
   85         shape->setObjectName(name);
   89     QString color = element.attribute(
"color");
   90     if (!color.isEmpty()) {
   91         QStringList colorList = color.split(
   92         if (colorList.size() > 2)
   93             shape->
setColor(QColor(colorList.at(0).toInt(), colorList.at(1).toInt(), colorList.at(2).toInt()));
   94         if (colorList.size() == 4)
   99     QString shader = element.attribute(
"shader");
  101     if (!shader.isEmpty()) {
  103         dirShader =
":axlShader/shader/" + shader;
  104         if (!QFile::exists(dirShader)) {
  105             QSettings settings(
"inria",
"dtk");
  107             settings.beginGroup(
"shader");
  108             dirShader = settings.value(
"path", defaultPath).toString();
  109             dirShader.append(
"/" + shader);
  115     QString size = element.attribute(
"size");
  117         shape->
setSize(size.toFloat());
  120     QDomElement verticesElement = element.elementsByTagName(
"vertices").at(0).toElement();
  121     QStringList verticesList = verticesElement.text().simplified().split(QRegExp(
"\\s+"));
  122     for (
int k = 0; k < verticesList.size(); k+=3) {
  124                                           verticesList.at(k+1).toDouble(),
  125                                           verticesList.at(k+2).toDouble());
  130     QDomElement edgesElement = element.elementsByTagName(
"edges").at(0).toElement();
  131     QDomNodeList edgesList = edgesElement.elementsByTagName(
"edge");
  133     for (
int k = 0; k < edgesList.size(); k++) {
  134         QDomElement edgeElement = edgesList.at(k).toElement();
  138         newEdge->
indexEndVertex = edgeElement.attribute(
"index_end").toInt();
  142         QString curveReaderTag = edgeElement.attribute(
"type")+
"Reader";
  148             shape->
insert_edge(newEdge, edgeElement.attribute(
"id").toInt());
  149             dtkWarn()<<
"axlShapeReader::read"<< curveReaderTag;
  151             dtkWarn()<<
"Error within axlShapeReader::read edge:" << curveReaderTag <<
"is not registered within readers.";
  156     QDomElement facesElement = element.elementsByTagName(
"faces").at(0).toElement();
  157     QDomNodeList facesList = facesElement.elementsByTagName(
"face");
  159     for (
int k = 0; k < facesList.size(); k++) {
  160         QDomElement faceElement = facesList.at(k).toElement();
  163         QDomNodeList loopsList = faceElement.elementsByTagName(
"loop");
  167         QString surfaceReaderTag = faceElement.attribute(
"type")+
"Reader";
  178             dtkWarn() <<
"Error within axlShapeReader::read face:" << surfaceReaderTag <<
  184         for (
int i = 0; i < loopsList.size(); i++) {
  185             QDomElement loopElement = loopsList.at(i).toElement();
  188             QDomNodeList edgesList = loopElement.elementsByTagName(
"edge");
  190             for (
int j = 0; j < edgesList.size(); j++) {
  191                 QDomElement edgeElement = edgesList.at(j).toElement();
  193                 loop->
edges << edgeElement.attribute(
"id").toInt();
  195                 bool currOrientation = edgeElement.attribute(
"orientation").toInt();
  201         shape->
insert_face(face, faceElement.attribute(
"id").toInt());
Class axlPoint defines 3D points.
axlAbstractCurveParametric * curve
Pointer to the parametric curve supporting the edge, of type axlAbstractCurveParametric.
virtual ~axlShapeReader(void)
int indexStartVertex
Index of the starting point of the edge in the array of vertices of the axlShape. ...
QVector< int > edges
Vector of indices of the edges of the loop in the array of edges of the axlShape. ...
QString description(void) const
Class axlPlane defines 3D planes.
void setShader(const QString &shader)
void insert_face(Face *face, int index)
bool reject(const QDomNode &node)
void insert_edge(Edge *edge, int index)
Generic interface for parametric curve.
virtual axlAbstractData * read(const QDomNode &node)=0
int indexEndVertex
Index of the ending point of the edge in the array of vertices of the axlShape.
bool accept(const QDomNode &node)
QStringList handled(void) const
QVector< bool > orientations
Vector of booleans of the same size as edges: true means the direct orientation, false is the reverse...
axlAbstractSurfaceParametric * surface
Pointer to the supporting surface of type axlAbstractSurfaceParametric.
static bool registered(void)
QVector< Loop * > loops
Vector of all the loops defining the face.
void setOpacity(const double &opacity)
void insert_vertex(axlPoint *vertex, int index)
dtkAbstractDataReader * createaxlShapeReader(void)
void setSize(const double &size)
void setColor(double r, double g, double b)
Class axlAbstractData defines an API for all type of axel data.
QString identifier(void) const
