Class axlPlane defines 3D planes. More...
#include <axlPlane.h>
Public Member Functions | |
axlPlane (QObject *parent=0) | |
Constructs a axel plane of with point and normal vector are NULL with parent parent of QObject type. More... | |
axlPlane (axlPoint *point, axlPoint *normal, QObject *parent=0) | |
Constructs a axel plane of two axlPoint, one for a point of on the plane point and one for the normal of the plane normal with parent parent of QObject type. More... | |
axlPlane (const axlPoint &point, const axlPoint &normal, QObject *parent=0) | |
Constructs an axel plane from two axlPoint, one for a point of on the plane point and one for the normal of the plane normal with parent parent. More... | |
axlPlane (const axlPlane &other) | |
Constructs a copy of other with same point and normal. More... | |
~axlPlane (void) | |
Destroys the axel plane. More... | |
virtual QString | description (void) const |
virtual QString | identifier (void) const |
axlPoint * | point (void) const |
Returns the point of the plane. More... | |
axlPoint * | normal (void) const |
Returns the normal of the plane. More... | |
void | setValues (axlPoint *point, axlPoint *normal) |
Change first point and second point of this plane. More... | |
void | setPoint (axlPoint *point) |
Change first point of this plane. More... | |
void | setPoint (double *p) |
void | setNormal (axlPoint *normal) |
Change second point of this plane. More... | |
void | setNormal (double *normal) |
void | touchPoint (axlPoint point) |
void | touchNormal (axlPoint normal) |
axlPlane & | operator= (const axlPlane &other) |
Assigns other to this plane and returns a reference to this plane. More... | |
QVariantList | convertDataToQVariant (void) const |
Convert an axlAbstractData into a QVariantList that specifies all properties of the axlAbstractData. More... | |
int | convertQVariantToData (const QVariantList &data) |
Modify properties and geometry variables of the axlAbstractData. Return 1 if the modification was sucessfully made. Otherwise return 0. More... | |
axlAbstractData (axlAbstractData *parent=NULL) | |
axlAbstractData (const axlAbstractData &data) | |
virtual | ~axlAbstractData (void) |
const QColor & | color (void) const |
const double & | opacity (void) const |
const double & | size (void) const |
const QString & | shader (void) const |
const bool & | editable (void) |
const bool & | updateView (void) |
void | setColor (double r, double g, double b) |
void | addField (axlAbstractField *field) |
Add a field to the field list of the object. More... | |
bool | updateFieldList (QString nameField) |
Check if a field with the same name is already applied on the object. More... | |
QString | changeFieldName (QString fieldName) |
axlMesh * | mesh (void) |
Return the mesh of that object is computed. More... | |
void | setMesh (axlMesh *mesh) |
Set a corresponding mesh for that object. More... | |
void | setUpdateView (bool updateView) |
QList< axlAbstractField * > | fields (void) |
Properties | |
axlPoint | point |
axlPoint | normal |
QColor | color |
double | opacity |
double | size |
QString | shader |
Friends | |
QDebug | operator<< (QDebug dbg, axlPlane plane) |
QDebug | operator<< (QDebug dbg, axlPlane &plane) |
QDebug | operator<< (QDebug dbg, axlPlane *plane) |
Additional Inherited Members | |
void | touchGeometry (void) |
void | touchProperty (void) |
void | touchStructure (void) |
virtual void | touchField (void) |
void | setColor (const QColor &color) |
void | setOpacity (const double &opacity) |
void | setSize (const double &size) |
void | setShader (const QString &shader) |
void | setEditable (bool edit) |
void | modifiedGeometry (void) |
void | modifiedStructure (void) |
void | modifiedField (void) |
void | modifiedProperty (void) |
This class enables to represent and manipulate 3D planes.
Example:
Definition at line 34 of file axlPlane.h.
axlPlane::axlPlane | ( | QObject * | parent = 0 | ) |
The parent of an object may be viewed as the object's owner. The destructor of a parent object destroys all child objects. Setting parent to 0 constructs a axel plane with no parent.
Definition at line 47 of file axlPlane.cpp.
The parent of an object may be viewed as the object's owner. The destructor of a parent object destroys all child objects. Setting parent to 0 constructs a axel point with no parent.
Definition at line 63 of file axlPlane.cpp.
Definition at line 77 of file axlPlane.cpp.
axlPlane::axlPlane | ( | const axlPlane & | other | ) |
Definition at line 89 of file axlPlane.cpp.
axlPlane::~axlPlane | ( | void | ) |
Definition at line 101 of file axlPlane.cpp.
virtual |
Reimplemented from axlAbstractData.
Definition at line 258 of file axlPlane.cpp.
virtual |
Definition at line 272 of file axlPlane.cpp.
virtual |
Definition at line 232 of file axlPlane.cpp.
virtual |
Definition at line 239 of file axlPlane.cpp.
axlPoint * axlPlane::normal | ( | void | ) | const |
Definition at line 142 of file axlPlane.cpp.
Definition at line 121 of file axlPlane.cpp.
axlPoint * axlPlane::point | ( | void | ) | const |
Definition at line 133 of file axlPlane.cpp.
void axlPlane::setNormal | ( | axlPoint * | normal | ) |
Definition at line 181 of file axlPlane.cpp.
void axlPlane::setNormal | ( | double * | normal | ) |
Definition at line 187 of file axlPlane.cpp.
void axlPlane::setPoint | ( | axlPoint * | point | ) |
Definition at line 163 of file axlPlane.cpp.
void axlPlane::setPoint | ( | double * | p | ) |
Definition at line 169 of file axlPlane.cpp.
Definition at line 152 of file axlPlane.cpp.
void axlPlane::touchNormal | ( | axlPoint | normal | ) |
Definition at line 201 of file axlPlane.cpp.
void axlPlane::touchPoint | ( | axlPoint | point | ) |
Definition at line 195 of file axlPlane.cpp.
friend |
Definition at line 211 of file axlPlane.cpp.
friend |
Definition at line 218 of file axlPlane.cpp.
friend |
Definition at line 225 of file axlPlane.cpp.
readwrite |
Definition at line 37 of file axlPlane.h.
readwrite |
