Developer documentation | Axl-2.5.1
axlAbstractSurfaceParametric Class Reference
#include <axlAbstractSurfaceParametric.h>
Inheritance diagram for axlAbstractSurfaceParametric:
axlAbstractSurface axlAbstractData axlAbstractSurfaceBSpline axlAbstractSurfaceRational axlConeParametric axlCylinderParametric axlPlaneParametric axlSurfaceParametricOffset axlSurfaceRevolutionParametric axlTorusParametric
Public Slots
void setSamples_u (const int &color)
void setSamples_v (const int &color)
- Public Slots inherited from axlAbstractData
void touchGeometry (void)
void touchProperty (void)
void touchStructure (void)
virtual void touchField (void)
void setColor (const QColor &color)
void setOpacity (const double &opacity)
void setSize (const double &size)
void setShader (const QString &shader)
void setEditable (bool edit)
Public Member Functions
 axlAbstractSurfaceParametric (void)
virtual ~axlAbstractSurfaceParametric (void)
virtual axlPoint eval (double u, double v)
virtual void eval (axlPoint *point, double u, double v)
virtual void eval (double &, double &, double &, double u, double v)
virtual void normal (axlPoint *normal, double u, double v)
virtual axlMesh eval (double u, double v, int derivs, bool u_from_right=true, bool v_from_right=true, double resolution=1.0e-12)
virtual dtkDeprecated::dtkVector3D< double > eval2 (double u, double v)
virtual void parameterOf (const axlPoint &point, double &um, double &vm)
virtual dtkDeprecated::dtkVector3D< double > normal (double u, double v)
virtual void normal (dtkDeprecated::dtkVector3D< double > *normal, double u, double v)
virtual double area (double tol)
virtual int numSamples_u (void)
virtual int numSamples_v (void)
virtual double startParam_u (void)
virtual double endParam_u (void)
virtual double startParam_v (void)
virtual double endParam_v (void)
virtual double startParam_u (int numCell)
virtual double endParam_u (int numCell)
virtual double startParam_v (int numCell)
virtual double endParam_v (int numCell)
virtual void eval (axlPoint *point, double u, double v, int numCell)
virtual void normal (axlPoint *normal, double u, double v, int numCell)
virtual bool hasCells (void)
virtual int countCells (void)
virtual int numSamples_u (int numCell)
virtual int numSamples_v (int numCell)
virtual int stripes (void)
virtual void setStripes (int stripes)
virtual void setNumSamples_u (int numSamples)
virtual void setNumSamples_v (int numSamples)
const int & samples_u (void) const
const int & samples_v (void) const
- Public Member Functions inherited from axlAbstractSurface
 axlAbstractSurface (void)
virtual ~axlAbstractSurface (void)
virtual int dimension (void) const
virtual axlMeshtoAxlMesh (void)
virtual void * surface (void)
- Public Member Functions inherited from axlAbstractData
 axlAbstractData (axlAbstractData *parent=NULL)
 axlAbstractData (const axlAbstractData &data)
virtual ~axlAbstractData (void)
const QColor & color (void) const
const double & opacity (void) const
const double & size (void) const
const QString & shader (void) const
const bool & editable (void)
const bool & updateView (void)
void setColor (double r, double g, double b)
void addField (axlAbstractField *field)
 Add a field to the field list of the object. More...
bool updateFieldList (QString nameField)
 Check if a field with the same name is already applied on the object. More...
QString changeFieldName (QString fieldName)
axlMeshmesh (void)
 Return the mesh of that object is computed. More...
void setMesh (axlMesh *mesh)
 Set a corresponding mesh for that object. More...
virtual QVariantList convertDataToQVariant (void) const
 Convert an axlAbstractData into a QVariantList that specifies all properties of the axlAbstractData. More...
virtual int convertQVariantToData (const QVariantList &data)
 Modify properties and geometry variables of the axlAbstractData. Return 1 if the modification was sucessfully made. Otherwise return 0. More...
void setUpdateView (bool updateView)
QList< axlAbstractField * > fields (void)
Properties
int samples_u
int samples_v
- Properties inherited from axlAbstractData
QColor color
double opacity
double size
QString shader
Additional Inherited Members
- Signals inherited from axlAbstractData
void modifiedGeometry (void)
void modifiedStructure (void)
void modifiedField (void)
void modifiedProperty (void)
Detailed Description
Definition at line 33 of file axlAbstractSurfaceParametric.h.
Constructor & Destructor Documentation
axlAbstractSurfaceParametric::axlAbstractSurfaceParametric ( void  )
Definition at line 40 of file axlAbstractSurfaceParametric.cpp.
axlAbstractSurfaceParametric::~axlAbstractSurfaceParametric ( void  )
virtual
Definition at line 49 of file axlAbstractSurfaceParametric.cpp.
Member Function Documentation
double axlAbstractSurfaceParametric::area ( double  tol)
virtual
Definition at line 204 of file axlAbstractSurfaceParametric.cpp.
int axlAbstractSurfaceParametric::countCells ( void  )
virtual
Definition at line 274 of file axlAbstractSurfaceParametric.cpp.
double axlAbstractSurfaceParametric::endParam_u ( void  )
virtual
Definition at line 219 of file axlAbstractSurfaceParametric.cpp.
double axlAbstractSurfaceParametric::endParam_u ( int  numCell)
virtual
Definition at line 248 of file axlAbstractSurfaceParametric.cpp.
double axlAbstractSurfaceParametric::endParam_v ( void  )
virtual
Definition at line 233 of file axlAbstractSurfaceParametric.cpp.
double axlAbstractSurfaceParametric::endParam_v ( int  numCell)
virtual
Definition at line 262 of file axlAbstractSurfaceParametric.cpp.
axlPoint axlAbstractSurfaceParametric::eval ( double  u,
double  v
virtual
void axlAbstractSurfaceParametric::eval ( axlPoint point,
double  u,
double  v
virtual
void axlAbstractSurfaceParametric::eval ( double &  x,
double &  y,
double &  z,
double  u,
double  v
virtual
axlMesh axlAbstractSurfaceParametric::eval ( double  u,
double  v,
int  derivs,
bool  u_from_right = true,
bool  v_from_right = true,
double  resolution = 1.0e-12
virtual
Definition at line 111 of file axlAbstractSurfaceParametric.cpp.
double  u,
double  v,
int  numCell
virtual
Definition at line 85 of file axlAbstractSurfaceParametric.cpp.
dtkDeprecated::dtkVector3D< double > axlAbstractSurfaceParametric::eval2 ( double  u,
double  v
virtual
Definition at line 102 of file axlAbstractSurfaceParametric.cpp.
bool axlAbstractSurfaceParametric::hasCells ( void  )
virtual
Definition at line 269 of file axlAbstractSurfaceParametric.cpp.
void axlAbstractSurfaceParametric::normal ( axlPoint normal,
double  u,
double  v
virtual
Reimplemented in axlPlaneParametric.
Definition at line 175 of file axlAbstractSurfaceParametric.cpp.
dtkDeprecated::dtkVector3D< double > axlAbstractSurfaceParametric::normal ( double  u,
double  v
virtual
Definition at line 166 of file axlAbstractSurfaceParametric.cpp.
void axlAbstractSurfaceParametric::normal ( dtkDeprecated::dtkVector3D< double > *  normal,
double  u,
double  v
virtual
Definition at line 194 of file axlAbstractSurfaceParametric.cpp.
double  u,
double  v,
int  numCell
virtual
Definition at line 184 of file axlAbstractSurfaceParametric.cpp.
int axlAbstractSurfaceParametric::numSamples_u ( void  )
virtual
Definition at line 281 of file axlAbstractSurfaceParametric.cpp.
int axlAbstractSurfaceParametric::numSamples_u ( int  numCell)
virtual
Definition at line 288 of file axlAbstractSurfaceParametric.cpp.
int axlAbstractSurfaceParametric::numSamples_v ( void  )
virtual
Definition at line 296 of file axlAbstractSurfaceParametric.cpp.
int axlAbstractSurfaceParametric::numSamples_v ( int  numCell)
virtual
Definition at line 303 of file axlAbstractSurfaceParametric.cpp.
void axlAbstractSurfaceParametric::parameterOf ( const axlPoint point,
double &  um,
double &  vm
virtual
const int & axlAbstractSurfaceParametric::samples_u ( void  ) const
Definition at line 339 of file axlAbstractSurfaceParametric.cpp.
const int & axlAbstractSurfaceParametric::samples_v ( void  ) const
Definition at line 350 of file axlAbstractSurfaceParametric.cpp.
void axlAbstractSurfaceParametric::setNumSamples_u ( int  numSamples)
virtual
Definition at line 313 of file axlAbstractSurfaceParametric.cpp.
void axlAbstractSurfaceParametric::setNumSamples_v ( int  numSamples)
virtual
Definition at line 333 of file axlAbstractSurfaceParametric.cpp.
void axlAbstractSurfaceParametric::setSamples_u ( const int &  color)
slot
Definition at line 345 of file axlAbstractSurfaceParametric.cpp.
void axlAbstractSurfaceParametric::setSamples_v ( const int &  color)
slot
Definition at line 356 of file axlAbstractSurfaceParametric.cpp.
void axlAbstractSurfaceParametric::setStripes ( int  stripes)
virtual
Definition at line 326 of file axlAbstractSurfaceParametric.cpp.
double axlAbstractSurfaceParametric::startParam_u ( void  )
virtual
Definition at line 212 of file axlAbstractSurfaceParametric.cpp.
double axlAbstractSurfaceParametric::startParam_u ( int  numCell)
virtual
Definition at line 241 of file axlAbstractSurfaceParametric.cpp.
double axlAbstractSurfaceParametric::startParam_v ( void  )
virtual
Definition at line 226 of file axlAbstractSurfaceParametric.cpp.
double axlAbstractSurfaceParametric::startParam_v ( int  numCell)
virtual
Definition at line 255 of file axlAbstractSurfaceParametric.cpp.
int axlAbstractSurfaceParametric::stripes ( void  )
virtual
Definition at line 319 of file axlAbstractSurfaceParametric.cpp.
Property Documentation
int axlAbstractSurfaceParametric::samples_u
readwrite
Definition at line 36 of file axlAbstractSurfaceParametric.h.
int axlAbstractSurfaceParametric::samples_v
readwrite
Definition at line 37 of file axlAbstractSurfaceParametric.h.
The documentation for this class was generated from the following files:
