The edge structure. More...
#include <axlShape.h>
Public Member Functions | |
| Edge () | |
| Edge (axlAbstractCurveParametric *crv, int si, int ei) | |
| Constructor from a parametric curve pointer, the starting and ending indices;.  More... | |
Public Attributes | |
| int | indexStartVertex |
| Index of the starting point of the edge in the array of vertices of the axlShape.  More... | |
| int | indexEndVertex |
| Index of the ending point of the edge in the array of vertices of the axlShape.  More... | |
| axlAbstractCurveParametric * | curve |
| Pointer to the parametric curve supporting the edge, of type axlAbstractCurveParametric.  More... | |
The edge structure.
An edge is composed of a supporting parametric curve and of the indices in the array of vertices of the starting vertex and ending vertex.
Definition at line 41 of file axlShape.h.
  inline |
Definition at line 51 of file axlShape.h.
  inline |
Definition at line 54 of file axlShape.h.
| axlAbstractCurveParametric* axlShape::Edge::curve |
Definition at line 49 of file axlShape.h.
| int axlShape::Edge::indexEndVertex |
Definition at line 46 of file axlShape.h.
| int axlShape::Edge::indexStartVertex |
Definition at line 43 of file axlShape.h.
