23 #include <dtkCoreSupport/dtkGlobal.h>
   30 class axlShapePrivate {
   36     QVector<axlPoint*> vertices;
   37     QVector<axlShape::Edge*> edges;
   38     QVector<axlShape::Face*> faces;
   47     d(new axlShapePrivate) {
   49     d->vertexCount = vertexCount;
   50     d->edgeCount = edgeCount;
   51     d->faceCount = faceCount;
   53     d->vertices = QVector<axlPoint*>(vertexCount, NULL);
   54     d->edges = QVector<Edge*>(edgeCount, NULL);
   55     d->faces = QVector<Face*>(faceCount, NULL);
   78     return d->vertexCount;
   90     QString desc =
"axlShape:\n";
   91     desc +=
" #Vertices: " + QString::number(d->vertexCount) +
"\n";
   92     desc +=
" #Edges: " + QString::number(d->edgeCount) +
"\n";
   93     desc +=
" #Faces: " + QString::number(d->faceCount) +
"\n\n";
   95     for (
int k = 0; k < d->faceCount; k++) {
   97         int nbLoops = d->faces.at(k)->loops.size();
   98         desc +=
"\nFace\t#" + QString::number(k) +
":\t" + QString::number(nbLoops) +
" loop(s)\n";
   99         for (
int i = 0; i < nbLoops; i++) {
  100             int nbEdges = d->faces.at(k)->loops.at(i)->edges.size();
  101             desc +=
" Loop\t#" + QString::number(i) +
":\t" + QString::number(nbEdges) +
" edge(s)\n";
  102             for (
int j = 0; j < nbEdges; j++) {
  103                 int currIndexEdge = d->faces.at(k)->loops.at(i)->edges.at(j);
  104                 if (currIndexEdge > -1 && currIndexEdge < d->edges.size()) {
  109                             desc +=
"  Edge\t#" + QString::number(j) +
":\t(" + currCurve->identifier() +
")\n";
  111                             desc +=
":\tcurve NULL\n";
  113                         desc +=
":\tNULL\n";
  116                     desc +=
"  Index of Edge out of range:" + QString::number(currIndexEdge) +
"\n";
  122             desc +=
" Surface\t:" + currSurf->identifier() +
"\n";
  124             desc +=
" Surface is NULL\n";
  135     d->vertices.replace(index, vertex);
  139     d->edges.replace(index, edge);
  144     d->edges.replace(index, edge);
  149     QVector<int> edgesSorted;
  150     QVector<bool> orientationsSorted;
  153     QVector<int> edges = loop->
edges;
  161     for (
int k = 0; k < edges.size()-1; k++) {
  165             fstEdgeIndex = edges.at(k);
  166             fstOrientation = orientations.at(k);
  168             edgesSorted << fstEdgeIndex;
  169             orientationsSorted << fstOrientation;
  173         Edge* fstEdge = d->edges.at(fstEdgeIndex);
  187         for (
int i = 1; i <= edges.size(); i++) {
  189             int currIndex = (k+i)%edges.size();
  191             sndEdgeIndex = edges.at(currIndex);
  194             Edge* sndEdge = d->edges.at(sndEdgeIndex);
  196             sndOrientation = orientations.at(currIndex);
  210                 edgesSorted << sndEdgeIndex;
  211                 orientationsSorted << sndOrientation;
  213                 fstEdgeIndex = sndEdgeIndex;
  214                 fstOrientation = sndOrientation;
  220             }
else if (i == edges.size()) {
  221                 dtkError() <<
"Error within void axlShape::sortEdges";
  228     loop->
edges = edgesSorted;
  233     for (
int k = 0; k < face->
loops.size(); k++) {
  240     QVector<axlShape::Loop *> loops;
  242     for(
int k = 0;k < nbLoops;k++){
  244         for(
int i=0;i < loopsSize[k];i++){
  246                 loops.at(k)->
edges << l[i];
  247                 loops.at(k)->orientations << orient[i];
  249                 loops.at(k)->edges << l[i+loopsSize[k-1]];
  250                 loops.at(k)->orientations << orient[i+loopsSize[k-1]];
  254     face->
loops << loops;
  256     d->faces.replace(index, face);
  261     QVector<axlShape::Loop *> loops;
  263     for(
  265         for(
  267                 loops.at(k)->
edges << l[i];
  268                 loops.at(k)->orientations << orient[i];
  270                 loops.at(k)->edges << l[i+loopsSize[k-1]];
  271                 loops.at(k)->orientations << orient[i+loopsSize[k-1]];
  275     face->
loops << loops;
  276     d->faces.replace(index, face);
  283     for(
int i=0;i < sizel;i++){
  286     for(
int j=0;j < sizeOrient;j++){
  291     d->faces.replace(index, face);
  298     for(
  301     for(
  305     d->faces.replace(index, face);
  310     d->faces.replace(index, face);
  316     QVariant
id = QVariant::fromValue(
identifier());
  317     QVariant vertexCount = QVariant::fromValue(d->vertexCount);
  318     QVariant faceCount = QVariant::fromValue(d->faceCount);
  319     QVariant edgeCount = QVariant::fromValue(d->edgeCount);
  324     list.append(vertexCount);
  325     list.append(faceCount);
  326     list.append(edgeCount);
  329     for(
int i = 0; i< d->vertexCount;i++){
  330         list.append(d->vertices.at(i)->convertDataToQVariant());
  334     for(
int i = 0; i< d->edgeCount;i++){
  339     for(
int i = 0; i< d->faceCount;i++){
  343     QVariant name = QVariant::fromValue(objectName());
  357     for(
int i = 0; i< data.at(1).toInt();i++){
  359         double x = data.at(4*i+1+newBegin).toDouble() ;
  360         double y = data.at(4*i+2+newBegin).toDouble();
  361         double z = data.at(4*i+3+newBegin).toDouble();
  367     newBegin = (4*d->vertexCount)+newBegin;
  392     setObjectName(data.last().toString());
Class axlPoint defines 3D points.
axlAbstractCurveParametric * curve
Pointer to the parametric curve supporting the edge, of type axlAbstractCurveParametric.
virtual QString identifier(void) const
int indexStartVertex
Index of the starting point of the edge in the array of vertices of the axlShape. ...
axlShape(int vertexCount, int edgeCount, int faceCount, axlShape *parent=0)
QVector< int > edges
Vector of indices of the edges of the loop in the array of edges of the axlShape. ...
QVector< Face * > getFaces(void) const
virtual QString description(void) const
void sortLoops(Face *face)
Sort loops.
QVector< Edge * > getEdges(void) const
int getFaceCount(void) const
int getEdgeCount(void) const
void insert_face(Face *face, int index)
int getVertexCount(void) const
void insert_edge(Edge *edge, int index)
Generic interface for parametric curve.
void sortEdges(Loop *loop)
Sort edges.
QVariantList convertDataToQVariant(void) const
int indexEndVertex
Index of the ending point of the edge in the array of vertices of the axlShape.
void insert_face_with_no_sort(axlAbstractSurfaceParametric *surf, int *l, int *orient, int sizel, int sizeOrient, int index)
QVector< bool > orientations
Vector of booleans of the same size as edges: true means the direct orientation, false is the reverse...
axlAbstractSurfaceParametric * surface
Pointer to the supporting surface of type axlAbstractSurfaceParametric.
int convertQVariantToData(const QVariantList &data)
QVector< Loop * > loops
Vector of all the loops defining the face.
void insert_vertex(axlPoint *vertex, int index)
QVector< axlPoint * > getVertices(void) const
Class axlAbstractData defines an API for all type of axel data.
