Generic interface for parametric curve. More...
#include <axlAbstractCurveParametric.h>
 | Public Slots | |
| virtual void | onDirectChanged (bool direct) |
| void | setSamples (const int &color) |
|  Public Slots inherited from axlAbstractData | |
| void | touchGeometry (void) |
| void | touchProperty (void) |
| void | touchStructure (void) |
| virtual void | touchField (void) |
| void | setColor (const QColor &color) |
| void | setOpacity (const double &opacity) |
| void | setSize (const double &size) |
| void | setShader (const QString &shader) |
| void | setEditable (bool edit) |
| Public Member Functions | |
| axlAbstractCurveParametric (void) | |
| virtual | ~axlAbstractCurveParametric (void) |
| virtual double | startParam (void) |
| virtual double | endParam (void) |
| virtual axlPoint | eval (double u) |
| virtual void | eval (axlPoint *point, double u) |
| virtual axlMesh | eval (double u, int derivs, bool from_right=true) |
| double | parameterOf (const axlPoint &p) |
| virtual double | length (double tolerance) |
| virtual int | numSamples (void) |
| virtual void | setNumSamples (int numSamples) |
| const int & | samples (void) const |
|  Public Member Functions inherited from axlAbstractCurve | |
| axlAbstractCurve (void) | |
| virtual | ~axlAbstractCurve (void) |
| virtual int | dimension (void) const |
| virtual bool | isPlanar (void) const |
| virtual void * | curve (void) |
|  Public Member Functions inherited from axlAbstractData | |
| axlAbstractData (axlAbstractData *parent=NULL) | |
| axlAbstractData (const axlAbstractData &data) | |
| virtual | ~axlAbstractData (void) |
| const QColor & | color (void) const |
| const double & | opacity (void) const |
| const double & | size (void) const |
| const QString & | shader (void) const |
| const bool & | editable (void) |
| const bool & | updateView (void) |
| void | setColor (double r, double g, double b) |
| void | addField (axlAbstractField *field) |
| Add a field to the field list of the object.  More... | |
| bool | updateFieldList (QString nameField) |
| Check if a field with the same name is already applied on the object.  More... | |
| QString | changeFieldName (QString fieldName) |
| axlMesh * | mesh (void) |
| Return the mesh of that object is computed.  More... | |
| void | setMesh (axlMesh *mesh) |
| Set a corresponding mesh for that object.  More... | |
| virtual QVariantList | convertDataToQVariant (void) const |
| Convert an axlAbstractData into a QVariantList that specifies all properties of the axlAbstractData.  More... | |
| virtual int | convertQVariantToData (const QVariantList &data) |
| Modify properties and geometry variables of the axlAbstractData. Return 1 if the modification was sucessfully made. Otherwise return 0.  More... | |
| void | setUpdateView (bool updateView) |
| QList< axlAbstractField * > | fields (void) |
| Properties | |
| int | samples |
|  Properties inherited from axlAbstractData | |
| QColor | color |
| double | opacity |
| double | size |
| QString | shader |
| Additional Inherited Members | |
|  Signals inherited from axlAbstractData | |
| void | modifiedGeometry (void) |
| void | modifiedStructure (void) |
| void | modifiedField (void) |
| void | modifiedProperty (void) |
Definition at line 36 of file axlAbstractCurveParametric.h.
| axlAbstractCurveParametric::axlAbstractCurveParametric | ( | void | ) |
Definition at line 37 of file axlAbstractCurveParametric.cpp.
 | virtual |
Definition at line 43 of file axlAbstractCurveParametric.cpp.
 | virtual |
Reimplemented in axlAbstractCurveBSpline.
Definition at line 56 of file axlAbstractCurveParametric.cpp.
 | virtual |
Definition at line 62 of file axlAbstractCurveParametric.cpp.
 | virtual |
Definition at line 90 of file axlAbstractCurveParametric.cpp.
 | virtual |
Definition at line 81 of file axlAbstractCurveParametric.cpp.
 | virtual |
Definition at line 125 of file axlAbstractCurveParametric.cpp.
 | virtual |
Definition at line 132 of file axlAbstractCurveParametric.cpp.
 | virtualslot |
Definition at line 149 of file axlAbstractCurveParametric.cpp.
| double axlAbstractCurveParametric::parameterOf | ( | const axlPoint & | p | ) |
Definition at line 98 of file axlAbstractCurveParametric.cpp.
| const int & axlAbstractCurveParametric::samples | ( | void | ) | const |
Definition at line 144 of file axlAbstractCurveParametric.cpp.
 | virtual |
Definition at line 139 of file axlAbstractCurveParametric.cpp.
 | slot |
Definition at line 153 of file axlAbstractCurveParametric.cpp.
 | virtual |
Definition at line 50 of file axlAbstractCurveParametric.cpp.
 | readwrite |
Definition at line 39 of file axlAbstractCurveParametric.h.
