Developer documentation | Axl-2.5.1
axlPlaneParametric Class Reference
#include <axlPlaneParametric.h>
Inheritance diagram for axlPlaneParametric:
axlAbstractSurfaceParametric axlAbstractSurface axlAbstractData
Public Slots
void onPlaneChanged (axlPlane *plane)
void onIChanged (axlPoint *i)
void onJChanged (axlPoint *j)
- Public Slots inherited from axlAbstractSurfaceParametric
void setSamples_u (const int &color)
void setSamples_v (const int &color)
- Public Slots inherited from axlAbstractData
void touchGeometry (void)
void touchProperty (void)
void touchStructure (void)
virtual void touchField (void)
void setColor (const QColor &color)
void setOpacity (const double &opacity)
void setSize (const double &size)
void setShader (const QString &shader)
void setEditable (bool edit)
Public Member Functions
 axlPlaneParametric (axlAbstractSurfaceParametric *parent=0)
 axlPlaneParametric (axlPlane *plane, axlPoint *i)
 axlPlaneParametric (const axlPlane &plane, const axlPoint &i)
 axlPlaneParametric (const axlPlaneParametric &other)
virtual ~axlPlaneParametric (void)
virtual QString description (void) const
virtual QString identifier (void) const
void setPlane (const axlPlane &plane)
void setI (axlPoint *i)
void setJ (axlPoint *j)
axlPlaneParametricoperator= (const axlPlaneParametric &other)
void modifyI (double *i)
void modifyJ (double *j)
axlPlanegetPlane (void) const
axlPointgetI (void) const
axlPointgetJ (void) const
virtual axlPoint eval (double u, double v)
virtual void eval (axlPoint *point, double u, double v)
virtual void eval (double &x, double &y, double &z, double u, double v)
virtual void normal (axlPoint *normal, double, double)
virtual void parameterOf (const axlPoint &point, double &u, double &v)
- Public Member Functions inherited from axlAbstractSurfaceParametric
 axlAbstractSurfaceParametric (void)
virtual ~axlAbstractSurfaceParametric (void)
virtual axlMesh eval (double u, double v, int derivs, bool u_from_right=true, bool v_from_right=true, double resolution=1.0e-12)
virtual dtkDeprecated::dtkVector3D< double > eval2 (double u, double v)
virtual dtkDeprecated::dtkVector3D< double > normal (double u, double v)
virtual void normal (dtkDeprecated::dtkVector3D< double > *normal, double u, double v)
virtual double area (double tol)
virtual int numSamples_u (void)
virtual int numSamples_v (void)
virtual double startParam_u (void)
virtual double endParam_u (void)
virtual double startParam_v (void)
virtual double endParam_v (void)
virtual double startParam_u (int numCell)
virtual double endParam_u (int numCell)
virtual double startParam_v (int numCell)
virtual double endParam_v (int numCell)
virtual void eval (axlPoint *point, double u, double v, int numCell)
virtual void normal (axlPoint *normal, double u, double v, int numCell)
virtual bool hasCells (void)
virtual int countCells (void)
virtual int numSamples_u (int numCell)
virtual int numSamples_v (int numCell)
virtual int stripes (void)
virtual void setStripes (int stripes)
virtual void setNumSamples_u (int numSamples)
virtual void setNumSamples_v (int numSamples)
const int & samples_u (void) const
const int & samples_v (void) const
 axlAbstractSurface (void)
virtual ~axlAbstractSurface (void)
virtual int dimension (void) const
virtual axlMeshtoAxlMesh (void)
virtual void * surface (void)
- Public Member Functions inherited from axlAbstractData
 axlAbstractData (axlAbstractData *parent=NULL)
 axlAbstractData (const axlAbstractData &data)
virtual ~axlAbstractData (void)
const QColor & color (void) const
const double & opacity (void) const
const double & size (void) const
const QString & shader (void) const
const bool & editable (void)
const bool & updateView (void)
void setColor (double r, double g, double b)
void addField (axlAbstractField *field)
 Add a field to the field list of the object. More...
bool updateFieldList (QString nameField)
 Check if a field with the same name is already applied on the object. More...
QString changeFieldName (QString fieldName)
axlMeshmesh (void)
 Return the mesh of that object is computed. More...
void setMesh (axlMesh *mesh)
 Set a corresponding mesh for that object. More...
virtual QVariantList convertDataToQVariant (void) const
 Convert an axlAbstractData into a QVariantList that specifies all properties of the axlAbstractData. More...
virtual int convertQVariantToData (const QVariantList &data)
 Modify properties and geometry variables of the axlAbstractData. Return 1 if the modification was sucessfully made. Otherwise return 0. More...
void setUpdateView (bool updateView)
QList< axlAbstractField * > fields (void)
Additional Inherited Members
- Signals inherited from axlAbstractData
void modifiedGeometry (void)
void modifiedStructure (void)
void modifiedField (void)
void modifiedProperty (void)
- Properties inherited from axlAbstractSurfaceParametric
int samples_u
int samples_v
- Properties inherited from axlAbstractData
QColor color
double opacity
double size
QString shader
Detailed Description
Definition at line 29 of file axlPlaneParametric.h.
Constructor & Destructor Documentation
axlPlaneParametric::axlPlaneParametric ( axlAbstractSurfaceParametric parent = 0)
Definition at line 37 of file axlPlaneParametric.cpp.
axlPlaneParametric::axlPlaneParametric ( axlPlane plane,
axlPoint i
Definition at line 50 of file axlPlaneParametric.cpp.
axlPlaneParametric::axlPlaneParametric ( const axlPlane plane,
const axlPoint i
Definition at line 63 of file axlPlaneParametric.cpp.
axlPlaneParametric::axlPlaneParametric ( const axlPlaneParametric other)
Definition at line 76 of file axlPlaneParametric.cpp.
axlPlaneParametric::~axlPlaneParametric ( void  )
virtual
Definition at line 90 of file axlPlaneParametric.cpp.
Member Function Documentation
QString axlPlaneParametric::description ( void  ) const
virtual
Definition at line 102 of file axlPlaneParametric.cpp.
axlPoint axlPlaneParametric::eval ( double  u,
double  v
virtual
Reimplemented from axlAbstractSurfaceParametric.
Definition at line 164 of file axlPlaneParametric.cpp.
void axlPlaneParametric::eval ( axlPoint point,
double  u,
double  v
virtual
Definition at line 168 of file axlPlaneParametric.cpp.
void axlPlaneParametric::eval ( double &  x,
double &  y,
double &  z,
double  u,
double  v
virtual
Definition at line 173 of file axlPlaneParametric.cpp.
axlPoint * axlPlaneParametric::getI ( void  ) const
Definition at line 155 of file axlPlaneParametric.cpp.
axlPoint * axlPlaneParametric::getJ ( void  ) const
Definition at line 159 of file axlPlaneParametric.cpp.
axlPlane * axlPlaneParametric::getPlane ( void  ) const
Definition at line 151 of file axlPlaneParametric.cpp.
QString axlPlaneParametric::identifier ( void  ) const
virtual
Definition at line 110 of file axlPlaneParametric.cpp.
void axlPlaneParametric::modifyI ( double *  i)
Definition at line 139 of file axlPlaneParametric.cpp.
void axlPlaneParametric::modifyJ ( double *  j)
Definition at line 145 of file axlPlaneParametric.cpp.
void axlPlaneParametric::normal ( axlPoint normal,
double  ,
double
virtual
Definition at line 180 of file axlPlaneParametric.cpp.
void axlPlaneParametric::onIChanged ( axlPoint i)
slot
Definition at line 200 of file axlPlaneParametric.cpp.
void axlPlaneParametric::onJChanged ( axlPoint j)
slot
Definition at line 204 of file axlPlaneParametric.cpp.
void axlPlaneParametric::onPlaneChanged ( axlPlane plane)
slot
Definition at line 196 of file axlPlaneParametric.cpp.
axlPlaneParametric & axlPlaneParametric::operator= ( const axlPlaneParametric other)
Definition at line 131 of file axlPlaneParametric.cpp.
void axlPlaneParametric::parameterOf ( const axlPoint point,
double &  u,
double &  v
virtual
Definition at line 184 of file axlPlaneParametric.cpp.
void axlPlaneParametric::setI ( axlPoint i)
Definition at line 120 of file axlPlaneParametric.cpp.
void axlPlaneParametric::setJ ( axlPoint j)
Definition at line 127 of file axlPlaneParametric.cpp.
void axlPlaneParametric::setPlane ( const axlPlane plane)
Definition at line 114 of file axlPlaneParametric.cpp.
The documentation for this class was generated from the following files:
