#include <axlAbstractSurfaceBSpline.h>
Signals | |
void | updated (void) |
void | samplingChanged (void) |
void | edgeSelected (int numEdge, int previous, int n) |
void | indexSelected (int i) |
void | modifiedControlPoints (void) |
void | modifiedGeometry (void) |
void | modifiedStructure (void) |
void | modifiedField (void) |
void | modifiedProperty (void) |
Public Member Functions | |
axlAbstractSurfaceBSpline (void) | |
virtual | ~axlAbstractSurfaceBSpline (void) |
virtual axlAbstractSurfaceBSpline * | copy (void) const |
virtual int | countControlPoints (void) const |
virtual int | countControlPoints_u (void) const |
virtual int | countControlPoints_v (void) const |
virtual int | knotVectorSize_u (void) const |
virtual int | knotVectorSize_v (void) const |
virtual int | order_u (void) const |
virtual int | order_v (void) const |
virtual double | getCoord (int n, int m, int v) const |
virtual axlPoint | getCoef (int n, int m) const |
virtual axlPoint | getCoef (int n) const |
virtual double | getWeight (int n, int m) const |
virtual bool | setCoef (int n, int m, int v, double c) |
virtual bool | setCoef (int n, int m, double *controlPoint) |
virtual bool | setCoef (int n, double *controlPoint) |
virtual double | getKnot_u (int n) const |
virtual double | getKnot_v (int n) const |
virtual void | setSurface (int pointsCount_u, int pointsCount_v, int order_u, int order_v, int dimension, double *knots_u, double *knots_v, double *points, bool rational) |
axlAbstractSurfaceBSpline::setSurface More... | |
virtual void | updateRcoeff () |
virtual void | insertKnot_u (double k) |
virtual void | removeKnot_u (double k) |
virtual void | insertKnot_v (double k) |
virtual void | removeKnot_v (double k) |
virtual bool | rational (void) const |
virtual QVector< axlPoint * > | sampling () |
virtual void | gridEvaluator (int num_u, int num_v, std::vector< double > &points, std::vector< double > ¶m_u, std::vector< double > ¶m_v) |
virtual QString | printCoeffs (bool print) const |
virtual QString | printKnotsVector (bool print) const |
virtual QString | description (void) const |
QVariantList | convertDataToQVariant (void) const |
Convert an axlAbstractData into a QVariantList that specifies all properties of the axlAbstractData. More... | |
int | convertQVariantToData (const QVariantList &data) |
Modify properties and geometry variables of the axlAbstractData. Return 1 if the modification was sucessfully made. Otherwise return 0. More... | |
double | scalarValue (double u, double v) |
void | setScalarValue (double u, double v, double value) |
virtual bool | connectionsAreDefined (void) |
Return true if control points connections were defined by developers. False if there are default connections visualization. More... | |
virtual QList< int > | getControlPointConnection (int i) |
The list returned contains all indices of coefficients that are still to be connected to the ith coefficient. More... | |
virtual void | defineControlPointConnection (int i, int j) |
Define connection between the ith and the jth coefficient. More... | |
virtual void | resetControlPointConnections (void) |
Removes all control point connections. More... | |
virtual void | selectIndex (int i) |
axlAbstractSurfaceParametric (void) | |
virtual | ~axlAbstractSurfaceParametric (void) |
virtual axlPoint | eval (double u, double v) |
virtual void | eval (axlPoint *point, double u, double v) |
virtual void | eval (double &, double &, double &, double u, double v) |
virtual void | normal (axlPoint *normal, double u, double v) |
virtual axlMesh | eval (double u, double v, int derivs, bool u_from_right=true, bool v_from_right=true, double resolution=1.0e-12) |
virtual dtkDeprecated::dtkVector3D< double > | eval2 (double u, double v) |
virtual void | parameterOf (const axlPoint &point, double &um, double &vm) |
virtual dtkDeprecated::dtkVector3D< double > | normal (double u, double v) |
virtual void | normal (dtkDeprecated::dtkVector3D< double > *normal, double u, double v) |
virtual double | area (double tol) |
virtual int | numSamples_u (void) |
virtual int | numSamples_v (void) |
virtual double | startParam_u (void) |
virtual double | endParam_u (void) |
virtual double | startParam_v (void) |
virtual double | endParam_v (void) |
virtual double | startParam_u (int numCell) |
virtual double | endParam_u (int numCell) |
virtual double | startParam_v (int numCell) |
virtual double | endParam_v (int numCell) |
virtual void | eval (axlPoint *point, double u, double v, int numCell) |
virtual void | normal (axlPoint *normal, double u, double v, int numCell) |
virtual bool | hasCells (void) |
virtual int | countCells (void) |
virtual int | numSamples_u (int numCell) |
virtual int | numSamples_v (int numCell) |
virtual int | stripes (void) |
virtual void | setStripes (int stripes) |
virtual void | setNumSamples_u (int numSamples) |
virtual void | setNumSamples_v (int numSamples) |
const int & | samples_u (void) const |
const int & | samples_v (void) const |
axlAbstractSurface (void) | |
virtual | ~axlAbstractSurface (void) |
virtual int | dimension (void) const |
virtual axlMesh * | toAxlMesh (void) |
virtual void * | surface (void) |
axlAbstractData (axlAbstractData *parent=NULL) | |
axlAbstractData (const axlAbstractData &data) | |
virtual | ~axlAbstractData (void) |
const QColor & | color (void) const |
const double & | opacity (void) const |
const double & | size (void) const |
const QString & | shader (void) const |
const bool & | editable (void) |
const bool & | updateView (void) |
void | setColor (double r, double g, double b) |
void | addField (axlAbstractField *field) |
Add a field to the field list of the object. More... | |
bool | updateFieldList (QString nameField) |
Check if a field with the same name is already applied on the object. More... | |
QString | changeFieldName (QString fieldName) |
axlMesh * | mesh (void) |
Return the mesh of that object is computed. More... | |
void | setMesh (axlMesh *mesh) |
Set a corresponding mesh for that object. More... | |
void | setUpdateView (bool updateView) |
QList< axlAbstractField * > | fields (void) |
Additional Inherited Members | |
void | setSamples_u (const int &color) |
void | setSamples_v (const int &color) |
void | touchGeometry (void) |
void | touchProperty (void) |
void | touchStructure (void) |
virtual void | touchField (void) |
void | setColor (const QColor &color) |
void | setOpacity (const double &opacity) |
void | setSize (const double &size) |
void | setShader (const QString &shader) |
void | setEditable (bool edit) |
int | samples_u |
int | samples_v |
QColor | color |
double | opacity |
double | size |
QString | shader |
Definition at line 32 of file axlAbstractSurfaceBSpline.h.
axlAbstractSurfaceBSpline::axlAbstractSurfaceBSpline | ( | void | ) |
Definition at line 34 of file axlAbstractSurfaceBSpline.cpp.
virtual |
Definition at line 39 of file axlAbstractSurfaceBSpline.cpp.
virtual |
Definition at line 252 of file axlAbstractSurfaceBSpline.cpp.
virtual |
Reimplemented from axlAbstractData.
Definition at line 303 of file axlAbstractSurfaceBSpline.cpp.
virtual |
Definition at line 335 of file axlAbstractSurfaceBSpline.cpp.
virtual |
Definition at line 45 of file axlAbstractSurfaceBSpline.cpp.
virtual |
Definition at line 51 of file axlAbstractSurfaceBSpline.cpp.
virtual |
Definition at line 57 of file axlAbstractSurfaceBSpline.cpp.
virtual |
Definition at line 63 of file axlAbstractSurfaceBSpline.cpp.
virtual |
Definition at line 278 of file axlAbstractSurfaceBSpline.cpp.
virtual |
Reimplemented in axlAbstractSurfaceTrimmed.
Definition at line 232 of file axlAbstractSurfaceBSpline.cpp.
signal |
virtual |
Definition at line 108 of file axlAbstractSurfaceBSpline.cpp.
virtual |
Definition at line 114 of file axlAbstractSurfaceBSpline.cpp.
virtual |
Definition at line 269 of file axlAbstractSurfaceBSpline.cpp.
virtual |
Definition at line 102 of file axlAbstractSurfaceBSpline.cpp.
virtual |
Definition at line 145 of file axlAbstractSurfaceBSpline.cpp.
virtual |
Definition at line 151 of file axlAbstractSurfaceBSpline.cpp.
virtual |
Definition at line 121 of file axlAbstractSurfaceBSpline.cpp.
virtual |
Definition at line 165 of file axlAbstractSurfaceBSpline.cpp.
signal |
virtual |
Definition at line 200 of file axlAbstractSurfaceBSpline.cpp.
virtual |
Definition at line 210 of file axlAbstractSurfaceBSpline.cpp.
virtual |
Definition at line 70 of file axlAbstractSurfaceBSpline.cpp.
virtual |
Definition at line 76 of file axlAbstractSurfaceBSpline.cpp.
signal |
virtual |
Definition at line 83 of file axlAbstractSurfaceBSpline.cpp.
virtual |
Definition at line 89 of file axlAbstractSurfaceBSpline.cpp.
virtual |
Definition at line 220 of file axlAbstractSurfaceBSpline.cpp.
virtual |
Definition at line 226 of file axlAbstractSurfaceBSpline.cpp.
virtual |
Definition at line 96 of file axlAbstractSurfaceBSpline.cpp.
virtual |
Definition at line 205 of file axlAbstractSurfaceBSpline.cpp.
virtual |
Definition at line 215 of file axlAbstractSurfaceBSpline.cpp.
virtual |
Definition at line 260 of file axlAbstractSurfaceBSpline.cpp.
virtual |
Definition at line 158 of file axlAbstractSurfaceBSpline.cpp.
signal |
double axlAbstractSurfaceBSpline::scalarValue | ( | double | u, |
double | v | ||
Definition at line 238 of file axlAbstractSurfaceBSpline.cpp.
inlinevirtual |
Definition at line 106 of file axlAbstractSurfaceBSpline.h.
virtual |
Definition at line 127 of file axlAbstractSurfaceBSpline.cpp.
virtual |
Definition at line 133 of file axlAbstractSurfaceBSpline.cpp.
virtual |
Definition at line 139 of file axlAbstractSurfaceBSpline.cpp.
void axlAbstractSurfaceBSpline::setScalarValue | ( | double | u, |
double | v, | ||
double | value | ||
Definition at line 243 of file axlAbstractSurfaceBSpline.cpp.
virtual |
n_u | number of control points in the u direction |
n_v | number of control points in the v direction |
order_u | degree+1 for the u parameter |
order_v | degree+1 for the v parameter |
dimension | the number of coordinates of the control points (usually 3) |
knots_u | the sequence of knots in the u direction |
knots_v | the sequence of knots in the v direction |
points | the sequence of coordinates of the control points x0 y0 z0 x1 y1 z1 .... The control points are given row by row as
![]() dimension doubles. The points of index (0..n_u,0) correspond to the isoparametric curve v=v_min, the points of index (0..n_u,n_v) correspond to the isoparametric curve v=v_max, the points of index (0, 0..n_v) correspond to the isoparametric curve u=u_min, the points of index (n_u, 0..n_v) correspond to the isoparametric curve u=u_max, where u_min,u_max, v_min, v_max are respectively the min and max values of knot_u, knot_v. |
Definition at line 188 of file axlAbstractSurfaceBSpline.cpp.
signal |
virtual |
Definition at line 194 of file axlAbstractSurfaceBSpline.cpp.
