Class axlCylinder defines 3D cylinders. More...
#include <axlCylinder.h>
 | Public Slots | |
| void | onFirstPointChanged (axlPoint *p1) |
| void | onSecondPointChanged (axlPoint *p2) |
| void | onRadiusChanged (double radius) |
|  Public Slots inherited from axlAbstractData | |
| void | touchGeometry (void) |
| void | touchProperty (void) |
| void | touchStructure (void) |
| virtual void | touchField (void) |
| void | setColor (const QColor &color) |
| void | setOpacity (const double &opacity) |
| void | setSize (const double &size) |
| void | setShader (const QString &shader) |
| void | setEditable (bool edit) |
| Public Member Functions | |
| axlCylinder (QObject *parent=0) | |
| Constructs a axel cylinder of with firstPoint and second point are NULL and 1.0 radius with parent parent of QObject type.  More... | |
| axlCylinder (axlPoint *p1, axlPoint *p2, double radius, QObject *parent=0) | |
| Constructs a axel cylinder of two axlPoint p1 p2 and radius radius with parent parent of QObject type.  More... | |
| axlCylinder (const axlPoint &p1, const axlPoint &p2, double radius, QObject *parent=0) | |
| Constructs an axel cylinder from two axlPoint p1 p2 and radius radius with parent parent.  More... | |
| axlCylinder (const axlCylinder &other) | |
| Constructs a copy of other with same axlPoints.  More... | |
| ~axlCylinder (void) | |
| Destroys the axel cylinder.  More... | |
| virtual QString | description (void) const |
| virtual QString | identifier (void) const |
| axlPoint * | firstPoint (void) const |
| Returns first point of the cylinder.  More... | |
| axlPoint * | secondPoint (void) const |
| Returns second point of the cylinder.  More... | |
| double | radius (void) const |
| Returns radius of the cylinder.  More... | |
| double | length (void) const |
| Returns length of the cylinder.  More... | |
| void | setValues (axlPoint *p1, axlPoint *p2, double radius) |
| Change first point and second point of this cylinder.  More... | |
| void | setFirstPoint (axlPoint *p1) |
| Change first point of this cylinder.  More... | |
| void | setSecondPoint (axlPoint *p2) |
| Change second point of this cylinder.  More... | |
| void | setRadius (double radius) |
| Change radius of this cylinder.  More... | |
| void | setLength (double length) |
| Change length of this cylinder we considered then first point is the origin of the cylinder and we change secondPoint in consequence.  More... | |
| void | setFirstPoint (double *p1) |
| modify first point of this line.  More... | |
| void | setSecondPoint (double *p2) |
| modify second point of this line.  More... | |
| void | touchFirstPoint (axlPoint p1) |
| void | touchSecondPoint (axlPoint p2) |
| void | touchRadius (double radius) |
| axlCylinder & | operator= (const axlCylinder &other) |
| Assigns other to this cylinder and returns a reference to this cylinder.  More... | |
| QVariantList | convertDataToQVariant (void) const |
| Convert an axlAbstractData into a QVariantList that specifies all properties of the axlAbstractData.  More... | |
| int | convertQVariantToData (const QVariantList &data) |
| Modify properties and geometry variables of the axlAbstractData. Return 1 if the modification was sucessfully made. Otherwise return 0.  More... | |
|  Public Member Functions inherited from axlAbstractData | |
| axlAbstractData (axlAbstractData *parent=NULL) | |
| axlAbstractData (const axlAbstractData &data) | |
| virtual | ~axlAbstractData (void) |
| const QColor & | color (void) const |
| const double & | opacity (void) const |
| const double & | size (void) const |
| const QString & | shader (void) const |
| const bool & | editable (void) |
| const bool & | updateView (void) |
| void | setColor (double r, double g, double b) |
| void | addField (axlAbstractField *field) |
| Add a field to the field list of the object.  More... | |
| bool | updateFieldList (QString nameField) |
| Check if a field with the same name is already applied on the object.  More... | |
| QString | changeFieldName (QString fieldName) |
| axlMesh * | mesh (void) |
| Return the mesh of that object is computed.  More... | |
| void | setMesh (axlMesh *mesh) |
| Set a corresponding mesh for that object.  More... | |
| void | setUpdateView (bool updateView) |
| QList< axlAbstractField * > | fields (void) |
| Properties | |
| axlPoint | point1 |
| axlPoint | point2 |
| double | radius |
|  Properties inherited from axlAbstractData | |
| QColor | color |
| double | opacity |
| double | size |
| QString | shader |
| Friends | |
| QDebug | operator<< (QDebug dbg, axlCylinder line) |
| QDebug | operator<< (QDebug dbg, axlCylinder &line) |
| QDebug | operator<< (QDebug dbg, axlCylinder *line) |
| Additional Inherited Members | |
|  Signals inherited from axlAbstractData | |
| void | modifiedGeometry (void) |
| void | modifiedStructure (void) |
| void | modifiedField (void) |
| void | modifiedProperty (void) |
This class enables to represent and manipulate 3D cylinders.
Example:
Definition at line 33 of file axlCylinder.h.
| axlCylinder::axlCylinder | ( | QObject * | parent = 0 | ) |
The parent of an object may be viewed as the object's owner. The destructor of a parent object destroys all child objects. Setting parent to 0 constructs a axel cylinder with no parent.
Definition at line 49 of file axlCylinder.cpp.
The parent of an object may be viewed as the object's owner. The destructor of a parent object destroys all child objects. Setting parent to 0 constructs a axel point with no parent.
Definition at line 64 of file axlCylinder.cpp.
| axlCylinder::axlCylinder | ( | const axlPoint & | p1, |
| const axlPoint & | p2, | ||
| double | radius, | ||
| QObject * | parent = 0 | ||
Definition at line 79 of file axlCylinder.cpp.
| axlCylinder::axlCylinder | ( | const axlCylinder & | other | ) |
Definition at line 91 of file axlCylinder.cpp.
| axlCylinder::~axlCylinder | ( | void | ) |
Definition at line 104 of file axlCylinder.cpp.
 | virtual |
Reimplemented from axlAbstractData.
Definition at line 328 of file axlCylinder.cpp.
 | virtual |
Definition at line 343 of file axlCylinder.cpp.
 | virtual |
Definition at line 299 of file axlCylinder.cpp.
| axlPoint * axlCylinder::firstPoint | ( | void | ) | const |
Definition at line 137 of file axlCylinder.cpp.
 | virtual |
Definition at line 306 of file axlCylinder.cpp.
| double axlCylinder::length | ( | void | ) | const |
Definition at line 164 of file axlCylinder.cpp.
 | slot |
Definition at line 312 of file axlCylinder.cpp.
 | slot |
Definition at line 322 of file axlCylinder.cpp.
 | slot |
Definition at line 317 of file axlCylinder.cpp.
| axlCylinder & axlCylinder::operator= | ( | const axlCylinder & | other | ) |
Definition at line 124 of file axlCylinder.cpp.
| double axlCylinder::radius | ( | void | ) | const |
Definition at line 155 of file axlCylinder.cpp.
| axlPoint * axlCylinder::secondPoint | ( | void | ) | const |
Definition at line 146 of file axlCylinder.cpp.
| void axlCylinder::setFirstPoint | ( | axlPoint * | p1 | ) |
Definition at line 188 of file axlCylinder.cpp.
| void axlCylinder::setFirstPoint | ( | double * | p1 | ) |
Definition at line 199 of file axlCylinder.cpp.
| void axlCylinder::setLength | ( | double | length | ) |
Definition at line 244 of file axlCylinder.cpp.
| void axlCylinder::setRadius | ( | double | radius | ) |
Definition at line 233 of file axlCylinder.cpp.
| void axlCylinder::setSecondPoint | ( | axlPoint * | p2 | ) |
Definition at line 222 of file axlCylinder.cpp.
| void axlCylinder::setSecondPoint | ( | double * | p2 | ) |
Definition at line 210 of file axlCylinder.cpp.
Definition at line 174 of file axlCylinder.cpp.
| void axlCylinder::touchFirstPoint | ( | axlPoint | p1 | ) |
Definition at line 256 of file axlCylinder.cpp.
| void axlCylinder::touchRadius | ( | double | radius | ) |
Definition at line 268 of file axlCylinder.cpp.
| void axlCylinder::touchSecondPoint | ( | axlPoint | p2 | ) |
Definition at line 262 of file axlCylinder.cpp.
 | friend |
Definition at line 278 of file axlCylinder.cpp.
 | friend |
Definition at line 285 of file axlCylinder.cpp.
 | friend |
Definition at line 292 of file axlCylinder.cpp.
 | readwrite |
Definition at line 36 of file axlCylinder.h.
 | readwrite |
 | readwrite |
Definition at line 37 of file axlCylinder.h.
