Developer documentation | Axl-2.5.1
axlTorus Class Reference
#include <axlTorus.h>
Inheritance diagram for axlTorus:
axlAbstractData
Public Slots
void onCenterChanged (axlPoint *center)
void onDirectionChanged (axlPoint *direction)
void onRingRadiusChanged (double ringRadius)
void onCrossSectionRadiusChanged (double crossSectionRadius)
- Public Slots inherited from axlAbstractData
void touchGeometry (void)
void touchProperty (void)
void touchStructure (void)
virtual void touchField (void)
void setColor (const QColor &color)
void setOpacity (const double &opacity)
void setSize (const double &size)
void setShader (const QString &shader)
void setEditable (bool edit)
Public Member Functions
 axlTorus (QObject *parent=0)
 axlTorus (axlPoint *center, axlPoint *direction, double ringRadius, double crossSectionRadius)
 axlTorus (const axlPoint &center, const axlPoint &direction, double ringRadius, double crossSectionRadius)
 axlTorus (const axlTorus &other)
virtual ~axlTorus (void)
virtual QString description (void) const
virtual QString identifier (void) const
axlPointcenterPoint (void) const
axlPointdirection (void) const
double ringRadius (void) const
double crossSectionRadius (void) const
void setValues (axlPoint *center, axlPoint *direction, double ringRadius, double crossSectionRadius)
void setCenter (axlPoint *center)
void setCenter (double *center)
void setDirection (axlPoint *direction)
void setDirection (double *direction)
void setRingRadius (double ringRadius)
void setCrossSectionRadius (double crossSectionRadius)
void touchCenterPoint (axlPoint center)
void touchDirection (axlPoint direction)
void touchRingRadius (double ringRadius)
void touchCrossSectionRadius (double crossSectionRadius)
axlTorusoperator= (const axlTorus &other)
QVariantList convertDataToQVariant (void) const
 Convert an axlAbstractData into a QVariantList that specifies all properties of the axlAbstractData. More...
int convertQVariantToData (const QVariantList &data)
 Modify properties and geometry variables of the axlAbstractData. Return 1 if the modification was sucessfully made. Otherwise return 0. More...
- Public Member Functions inherited from axlAbstractData
 axlAbstractData (axlAbstractData *parent=NULL)
 axlAbstractData (const axlAbstractData &data)
virtual ~axlAbstractData (void)
const QColor & color (void) const
const double & opacity (void) const
const double & size (void) const
const QString & shader (void) const
const bool & editable (void)
const bool & updateView (void)
void setColor (double r, double g, double b)
void addField (axlAbstractField *field)
 Add a field to the field list of the object. More...
bool updateFieldList (QString nameField)
 Check if a field with the same name is already applied on the object. More...
QString changeFieldName (QString fieldName)
axlMeshmesh (void)
 Return the mesh of that object is computed. More...
void setMesh (axlMesh *mesh)
 Set a corresponding mesh for that object. More...
void setUpdateView (bool updateView)
QList< axlAbstractField * > fields (void)
Properties
axlPoint centerPoint
axlPoint direction
double ringRadius
- Properties inherited from axlAbstractData
QColor color
double opacity
double size
QString shader
Friends
QDebug operator<< (QDebug dbg, axlTorus torus)
QDebug operator<< (QDebug dbg, axlTorus &torus)
QDebug operator<< (QDebug dbg, axlTorus *torus)
Additional Inherited Members
- Signals inherited from axlAbstractData
void modifiedGeometry (void)
void modifiedStructure (void)
void modifiedField (void)
void modifiedProperty (void)
Detailed Description
Definition at line 28 of file axlTorus.h.
Constructor & Destructor Documentation
axlTorus::axlTorus ( QObject *  parent = 0)
Definition at line 39 of file axlTorus.cpp.
axlTorus::axlTorus ( axlPoint center,
axlPoint direction,
double  ringRadius,
Definition at line 51 of file axlTorus.cpp.
axlTorus::axlTorus ( const axlPoint center,
const axlPoint direction,
double  ringRadius,
Definition at line 63 of file axlTorus.cpp.
axlTorus::axlTorus ( const axlTorus other)
Definition at line 75 of file axlTorus.cpp.
axlTorus::~axlTorus ( void  )
virtual
Definition at line 87 of file axlTorus.cpp.
Member Function Documentation
axlPoint * axlTorus::centerPoint ( void  ) const
Definition at line 113 of file axlTorus.cpp.
QVariantList axlTorus::convertDataToQVariant ( void  ) const
virtual
Reimplemented from axlAbstractData.
Definition at line 234 of file axlTorus.cpp.
int axlTorus::convertQVariantToData ( const QVariantList &  data)
virtual
Definition at line 252 of file axlTorus.cpp.
double axlTorus::crossSectionRadius ( void  ) const
Definition at line 125 of file axlTorus.cpp.
QString axlTorus::description ( void  ) const
virtual
Definition at line 100 of file axlTorus.cpp.
axlPoint * axlTorus::direction ( void  ) const
Definition at line 117 of file axlTorus.cpp.
QString axlTorus::identifier ( void  ) const
virtual
Definition at line 109 of file axlTorus.cpp.
void axlTorus::onCenterChanged ( axlPoint center)
slot
Definition at line 214 of file axlTorus.cpp.
void axlTorus::onCrossSectionRadiusChanged ( double  crossSectionRadius)
slot
Definition at line 229 of file axlTorus.cpp.
void axlTorus::onDirectionChanged ( axlPoint direction)
slot
Definition at line 219 of file axlTorus.cpp.
void axlTorus::onRingRadiusChanged ( double  ringRadius)
slot
Definition at line 224 of file axlTorus.cpp.
axlTorus & axlTorus::operator= ( const axlTorus other)
Definition at line 190 of file axlTorus.cpp.
double axlTorus::ringRadius ( void  ) const
Definition at line 121 of file axlTorus.cpp.
void axlTorus::setCenter ( axlPoint center)
Definition at line 136 of file axlTorus.cpp.
void axlTorus::setCenter ( double *  center)
Definition at line 152 of file axlTorus.cpp.
void axlTorus::setCrossSectionRadius ( double  crossSectionRadius)
Definition at line 148 of file axlTorus.cpp.
void axlTorus::setDirection ( axlPoint direction)
Definition at line 140 of file axlTorus.cpp.
void axlTorus::setDirection ( double *  direction)
Definition at line 159 of file axlTorus.cpp.
void axlTorus::setRingRadius ( double  ringRadius)
Definition at line 144 of file axlTorus.cpp.
void axlTorus::setValues ( axlPoint center,
axlPoint direction,
double  ringRadius,
Definition at line 129 of file axlTorus.cpp.
void axlTorus::touchCenterPoint ( axlPoint  center)
Definition at line 166 of file axlTorus.cpp.
void axlTorus::touchCrossSectionRadius ( double  crossSectionRadius)
Definition at line 184 of file axlTorus.cpp.
void axlTorus::touchDirection ( axlPoint  direction)
Definition at line 172 of file axlTorus.cpp.
void axlTorus::touchRingRadius ( double  ringRadius)
Definition at line 178 of file axlTorus.cpp.
Friends And Related Function Documentation
QDebug operator<< ( QDebug  dbg,
axlTorus  torus
friend
Definition at line 199 of file axlTorus.cpp.
axlTorus torus
friend
Definition at line 204 of file axlTorus.cpp.
axlTorus torus
friend
Definition at line 209 of file axlTorus.cpp.
Property Documentation
axlPoint axlTorus::centerPoint
readwrite
Definition at line 30 of file axlTorus.h.
readwrite
Definition at line 32 of file axlTorus.h.
axlPoint axlTorus::direction
readwrite
readwrite
Definition at line 31 of file axlTorus.h.
The documentation for this class was generated from the following files:
