Class axlEllipsoid defines 3D ellipsoids. More...
#include <axlEllipsoid.h>
Public Slots | |
void | onCenterChanged (axlPoint *center) |
void | onSemiXChanged (axlPoint *semiX) |
void | onSemiYChanged (axlPoint *semiY) |
void | onSemiZChanged (axlPoint *semiZ) |
void | calculateYZ (void) |
void | calculateXZ (void) |
void | calculateXY (void) |
void | touchGeometry (void) |
void | touchProperty (void) |
void | touchStructure (void) |
virtual void | touchField (void) |
void | setColor (const QColor &color) |
void | setOpacity (const double &opacity) |
void | setSize (const double &size) |
void | setShader (const QString &shader) |
void | setEditable (bool edit) |
Public Member Functions | |
axlEllipsoid (QObject *parent=0) | |
Constructs a axel ellipsoid of with firstPoint and second point are NULL and 1.0 radius with parent parent of QObject type. More... | |
axlEllipsoid (axlPoint *center, axlPoint *semiX, axlPoint *semiY, axlPoint *semiZ, QObject *parent=0) | |
Constructs a axel ellipsoid of two axlPoint center p2 and radius radius with parent parent of QObject type. More... | |
axlEllipsoid (const axlPoint ¢er, const axlPoint &semiX, const axlPoint &semiY, const axlPoint &semiZ, QObject *parent=0) | |
Constructs a axel ellipsoid from two axlPoint center p2 and radius radius with parent parent. More... | |
axlEllipsoid (const axlEllipsoid &other) | |
Constructs a copy of other with same axlPoints. More... | |
~axlEllipsoid (void) | |
Destroys the axel ellipsoid. More... | |
virtual QString | description (void) const |
virtual QString | identifier (void) const |
axlPoint * | center (void) const |
Returns center of the ellipsoid. More... | |
axlPoint * | semiX (void) const |
Returns semi x axe value of the ellipsoid. More... | |
axlPoint * | semiY (void) const |
Returns semi y axe value of the ellipsoid. More... | |
axlPoint * | semiZ (void) const |
Returns semi z axe value of the ellipsoid. More... | |
void | setValues (axlPoint *center, axlPoint *semiX, axlPoint *semiY, axlPoint *semiZ) |
Change center, semi axes x, y, z values and quarternion of this ellipsoid. More... | |
void | setCenter (axlPoint *center) |
Change center of this ellipsoid. More... | |
void | setSemiX (axlPoint *semiX) |
Change semi axes x value of this ellipsoid. More... | |
void | setSemiY (axlPoint *semiY) |
Change semi axes y value of this ellipsoid. More... | |
void | setSemiZ (axlPoint *semiZ) |
Change semi axes z value of this ellipsoid. More... | |
void | touchCenter (axlPoint center) |
void | touchSemiX (axlPoint semiX) |
void | touchSemiY (axlPoint semiY) |
void | touchSemiZ (axlPoint semiZ) |
void | modifyCenter (double *center) |
modify Center of this Ellipsoid. More... | |
void | modifyCenterX (double x) |
modify X Center value of this Ellipsoid. More... | |
void | modifyCenterY (double y) |
modify Y Center value of this Ellipsoid. More... | |
void | modifyCenterZ (double z) |
modify Z Center value of this Ellipsoid. More... | |
void | modifySemiX (double *semiX) |
modify SemiX of this Ellipsoid. More... | |
void | modifySemiXX (double x) |
modify X SemiX value of this Ellipsoid. More... | |
void | modifySemiXY (double y) |
modify Y SemiX value of this Ellipsoid. More... | |
void | modifySemiXZ (double z) |
modify Z SemiX value of this Ellipsoid. More... | |
void | modifySemiY (double *semiY) |
modify SemiY of this Ellipsoid. More... | |
void | modifySemiYX (double x) |
modify X SemiY value of this Ellipsoid. More... | |
void | modifySemiYY (double y) |
modify Y SemiY value of this Ellipsoid. More... | |
void | modifySemiYZ (double z) |
modify Z SemiY value of this Ellipsoid. More... | |
void | modifySemiZ (double *semiZ) |
modify SemiZ of this Ellipsoid. More... | |
void | modifySemiZX (double x) |
modify X SemiZ value of this Ellipsoid. More... | |
void | modifySemiZY (double y) |
modify Y SemiZ value of this Ellipsoid. More... | |
void | modifySemiZZ (double z) |
modify Z SemiZ value of this Ellipsoid. More... | |
axlEllipsoid & | operator= (const axlEllipsoid &other) |
Assigns other to this ellipsoid and returns a reference to this ellipsoid. More... | |
QVariantList | convertDataToQVariant (void) const |
Convert an axlAbstractData into a QVariantList that specifies all properties of the axlAbstractData. More... | |
int | convertQVariantToData (const QVariantList &data) |
Modify properties and geometry variables of the axlAbstractData. Return 1 if the modification was sucessfully made. Otherwise return 0. More... | |
axlAbstractData (axlAbstractData *parent=NULL) | |
axlAbstractData (const axlAbstractData &data) | |
virtual | ~axlAbstractData (void) |
const QColor & | color (void) const |
const double & | opacity (void) const |
const double & | size (void) const |
const QString & | shader (void) const |
const bool & | editable (void) |
const bool & | updateView (void) |
void | setColor (double r, double g, double b) |
void | addField (axlAbstractField *field) |
Add a field to the field list of the object. More... | |
bool | updateFieldList (QString nameField) |
Check if a field with the same name is already applied on the object. More... | |
QString | changeFieldName (QString fieldName) |
axlMesh * | mesh (void) |
Return the mesh of that object is computed. More... | |
void | setMesh (axlMesh *mesh) |
Set a corresponding mesh for that object. More... | |
void | setUpdateView (bool updateView) |
QList< axlAbstractField * > | fields (void) |
Properties | |
axlPoint | center |
axlPoint | semiX |
axlPoint | semiY |
axlPoint | semiZ |
QColor | color |
double | opacity |
double | size |
QString | shader |
Friends | |
QDebug | operator<< (QDebug dbg, axlEllipsoid line) |
QDebug | operator<< (QDebug dbg, axlEllipsoid &line) |
QDebug | operator<< (QDebug dbg, axlEllipsoid *line) |
Additional Inherited Members | |
void | modifiedGeometry (void) |
void | modifiedStructure (void) |
void | modifiedField (void) |
void | modifiedProperty (void) |
This class enables to represent and manipulate 3D ellipsoids.
Example:
Definition at line 35 of file axlEllipsoid.h.
axlEllipsoid::axlEllipsoid | ( | QObject * | parent = 0 | ) |
The parent of an object may be viewed as the object's owner. The destructor of a parent object destroys all child objects. Setting parent to 0 constructs a axel ellipsoid with no parent.
Definition at line 51 of file axlEllipsoid.cpp.
axlEllipsoid::axlEllipsoid | ( | axlPoint * | center, |
axlPoint * | semiX, | ||
axlPoint * | semiY, | ||
axlPoint * | semiZ, | ||
The parent of an object may be viewed as the object's owner. The destructor of a parent object destroys all child objects. Setting parent to 0 constructs a axel point with no parent.
Definition at line 67 of file axlEllipsoid.cpp.
axlEllipsoid::axlEllipsoid | ( | const axlPoint & | center, |
const axlPoint & | semiX, | ||
const axlPoint & | semiY, | ||
const axlPoint & | semiZ, | ||
Definition at line 83 of file axlEllipsoid.cpp.
axlEllipsoid::axlEllipsoid | ( | const axlEllipsoid & | other | ) |
Definition at line 97 of file axlEllipsoid.cpp.
axlEllipsoid::~axlEllipsoid | ( | void | ) |
Definition at line 112 of file axlEllipsoid.cpp.
slot |
Definition at line 610 of file axlEllipsoid.cpp.
slot |
Definition at line 556 of file axlEllipsoid.cpp.
slot |
Definition at line 502 of file axlEllipsoid.cpp.
axlPoint * axlEllipsoid::center | ( | void | ) | const |
Definition at line 157 of file axlEllipsoid.cpp.
virtual |
Reimplemented from axlAbstractData.
Definition at line 664 of file axlEllipsoid.cpp.
virtual |
Definition at line 682 of file axlEllipsoid.cpp.
virtual |
Definition at line 296 of file axlEllipsoid.cpp.
virtual |
Definition at line 308 of file axlEllipsoid.cpp.
void axlEllipsoid::modifyCenter | ( | double * | center | ) |
Definition at line 342 of file axlEllipsoid.cpp.
void axlEllipsoid::modifyCenterX | ( | double | x | ) |
Definition at line 352 of file axlEllipsoid.cpp.
void axlEllipsoid::modifyCenterY | ( | double | y | ) |
Definition at line 362 of file axlEllipsoid.cpp.
void axlEllipsoid::modifyCenterZ | ( | double | z | ) |
Definition at line 372 of file axlEllipsoid.cpp.
void axlEllipsoid::modifySemiX | ( | double * | semiX | ) |
Definition at line 382 of file axlEllipsoid.cpp.
void axlEllipsoid::modifySemiXX | ( | double | x | ) |
Definition at line 392 of file axlEllipsoid.cpp.
void axlEllipsoid::modifySemiXY | ( | double | y | ) |
Definition at line 402 of file axlEllipsoid.cpp.
void axlEllipsoid::modifySemiXZ | ( | double | z | ) |
Definition at line 412 of file axlEllipsoid.cpp.
void axlEllipsoid::modifySemiY | ( | double * | semiY | ) |
Definition at line 422 of file axlEllipsoid.cpp.
void axlEllipsoid::modifySemiYX | ( | double | x | ) |
Definition at line 432 of file axlEllipsoid.cpp.
void axlEllipsoid::modifySemiYY | ( | double | y | ) |
Definition at line 443 of file axlEllipsoid.cpp.
void axlEllipsoid::modifySemiYZ | ( | double | z | ) |
Definition at line 453 of file axlEllipsoid.cpp.
void axlEllipsoid::modifySemiZ | ( | double * | semiZ | ) |
Definition at line 463 of file axlEllipsoid.cpp.
void axlEllipsoid::modifySemiZX | ( | double | x | ) |
Definition at line 473 of file axlEllipsoid.cpp.
void axlEllipsoid::modifySemiZY | ( | double | y | ) |
Definition at line 484 of file axlEllipsoid.cpp.
void axlEllipsoid::modifySemiZZ | ( | double | z | ) |
Definition at line 495 of file axlEllipsoid.cpp.
slot |
Definition at line 314 of file axlEllipsoid.cpp.
slot |
Definition at line 320 of file axlEllipsoid.cpp.
slot |
Definition at line 326 of file axlEllipsoid.cpp.
slot |
Definition at line 332 of file axlEllipsoid.cpp.
axlEllipsoid & axlEllipsoid::operator= | ( | const axlEllipsoid & | other | ) |
Definition at line 143 of file axlEllipsoid.cpp.
axlPoint * axlEllipsoid::semiX | ( | void | ) | const |
Definition at line 166 of file axlEllipsoid.cpp.
axlPoint * axlEllipsoid::semiY | ( | void | ) | const |
Definition at line 175 of file axlEllipsoid.cpp.
axlPoint * axlEllipsoid::semiZ | ( | void | ) | const |
Definition at line 184 of file axlEllipsoid.cpp.
void axlEllipsoid::setCenter | ( | axlPoint * | center | ) |
Definition at line 207 of file axlEllipsoid.cpp.
void axlEllipsoid::setSemiX | ( | axlPoint * | semiX | ) |
Definition at line 218 of file axlEllipsoid.cpp.
void axlEllipsoid::setSemiY | ( | axlPoint * | semiY | ) |
Definition at line 229 of file axlEllipsoid.cpp.
void axlEllipsoid::setSemiZ | ( | axlPoint * | semiZ | ) |
Definition at line 240 of file axlEllipsoid.cpp.
void axlEllipsoid::setValues | ( | axlPoint * | center, |
axlPoint * | semiZ | ||
Definition at line 193 of file axlEllipsoid.cpp.
void axlEllipsoid::touchCenter | ( | axlPoint | center | ) |
Definition at line 247 of file axlEllipsoid.cpp.
void axlEllipsoid::touchSemiX | ( | axlPoint | semiX | ) |
Definition at line 253 of file axlEllipsoid.cpp.
void axlEllipsoid::touchSemiY | ( | axlPoint | semiY | ) |
Definition at line 259 of file axlEllipsoid.cpp.
void axlEllipsoid::touchSemiZ | ( | axlPoint | semiZ | ) |
Definition at line 265 of file axlEllipsoid.cpp.
friend |
Definition at line 275 of file axlEllipsoid.cpp.
friend |
Definition at line 282 of file axlEllipsoid.cpp.
friend |
Definition at line 289 of file axlEllipsoid.cpp.
readwrite |
Definition at line 38 of file axlEllipsoid.h.
readwrite |
readwrite |
Definition at line 39 of file axlEllipsoid.h.
readwrite |
Definition at line 40 of file axlEllipsoid.h.
