|   | axlTorusParametric (axlAbstractSurfaceParametric *parent=0) |
|   | axlTorusParametric (axlTorus *torus, axlPoint *r) |
|   | axlTorusParametric (const axlTorus &torus, const axlPoint &r) |
|   | axlTorusParametric (const axlTorusParametric &other) |
| virtual  | ~axlTorusParametric (void) |
| virtual QString  | description (void) const  |
| virtual QString  | identifier (void) const  |
| axlPoint *  | getV (void) const  |
| axlPoint *  | getR (void) const  |
| void  | setR (axlPoint *r) |
| axlPoint *  | getW (void) const  |
| axlTorus *  | getTorus (void) const  |
| void  | setTorus (const axlTorus &torus) |
| axlTorusParametric &  | operator= (const axlTorusParametric &other) |
| void  | modifyR (double *r) |
| virtual axlPoint  | eval (double u, double v) |
| virtual void  | eval (axlPoint *point, double u, double v) |
| virtual void  | eval (double &x, double &y, double &z, double u, double v) |
| virtual void  | parameterOf (const axlPoint &point, double &um, double &vm) |
|   | axlAbstractSurfaceParametric (void) |
| virtual  | ~axlAbstractSurfaceParametric (void) |
| virtual void  | normal (axlPoint *normal, double u, double v) |
| virtual axlMesh  | eval (double u, double v, int derivs, bool u_from_right=true, bool v_from_right=true, double resolution=1.0e-12) |
| virtual dtkDeprecated::dtkVector3D< double >  | eval2 (double u, double v) |
| virtual dtkDeprecated::dtkVector3D< double >  | normal (double u, double v) |
| virtual void  | normal (dtkDeprecated::dtkVector3D< double > *normal, double u, double v) |
| virtual double  | area (double tol) |
| virtual int  | numSamples_u (void) |
| virtual int  | numSamples_v (void) |
| virtual double  | startParam_u (void) |
| virtual double  | endParam_u (void) |
| virtual double  | startParam_v (void) |
| virtual double  | endParam_v (void) |
| virtual double  | startParam_u (int numCell) |
| virtual double  | endParam_u (int numCell) |
| virtual double  | startParam_v (int numCell) |
| virtual double  | endParam_v (int numCell) |
| virtual void  | eval (axlPoint *point, double u, double v, int numCell) |
| virtual void  | normal (axlPoint *normal, double u, double v, int numCell) |
| virtual bool  | hasCells (void) |
| virtual int  | countCells (void) |
| virtual int  | numSamples_u (int numCell) |
| virtual int  | numSamples_v (int numCell) |
| virtual int  | stripes (void) |
| virtual void  | setStripes (int stripes) |
| virtual void  | setNumSamples_u (int numSamples) |
| virtual void  | setNumSamples_v (int numSamples) |
| const int &  | samples_u (void) const  |
| const int &  | samples_v (void) const  |
|   | axlAbstractSurface (void) |
| virtual  | ~axlAbstractSurface (void) |
| virtual int  | dimension (void) const  |
| virtual axlMesh *  | toAxlMesh (void) |
| virtual void *  | surface (void) |
|   | axlAbstractData (axlAbstractData *parent=NULL) |
|   | axlAbstractData (const axlAbstractData &data) |
| virtual  | ~axlAbstractData (void) |
| const QColor &  | color (void) const  |
| const double &  | opacity (void) const  |
| const double &  | size (void) const  |
| const QString &  | shader (void) const  |
| const bool &  | editable (void) |
| const bool &  | updateView (void) |
| void  | setColor (double r, double g, double b) |
| void  | addField (axlAbstractField *field) |
|   | Add a field to the field list of the object.  More...
| bool  | updateFieldList (QString nameField) |
|   | Check if a field with the same name is already applied on the object.  More...
| QString  | changeFieldName (QString fieldName) |
| axlMesh *  | mesh (void) |
|   | Return the mesh of that object is computed.  More...
| void  | setMesh (axlMesh *mesh) |
|   | Set a corresponding mesh for that object.  More...
| virtual QVariantList  | convertDataToQVariant (void) const  |
|   | Convert an axlAbstractData into a QVariantList that specifies all properties of the axlAbstractData.  More...
| virtual int  | convertQVariantToData (const QVariantList &data) |
|   | Modify properties and geometry variables of the axlAbstractData. Return 1 if the modification was sucessfully made. Otherwise return 0.  More...
| void  | setUpdateView (bool updateView) |
| QList< axlAbstractField * >  | fields (void) |
Definition at line 29 of file axlTorusParametric.h.
