Developer documentation | Axl-2.5.1
axlAbstractSurface Class Reference
#include <axlAbstractSurface.h>
Inheritance diagram for axlAbstractSurface:
axlAbstractData axlAbstractSurfaceImplicit axlAbstractSurfaceParametric axlSurfaceRevolution axlTabulatedCylinder axlTrimmedParametricSurface axlAbstractSurfaceBSpline axlAbstractSurfaceRational axlConeParametric axlCylinderParametric axlPlaneParametric axlSurfaceParametricOffset axlSurfaceRevolutionParametric axlTorusParametric
Public Member Functions
 axlAbstractSurface (void)
virtual ~axlAbstractSurface (void)
virtual int dimension (void) const
virtual axlMeshtoAxlMesh (void)
virtual void * surface (void)
- Public Member Functions inherited from axlAbstractData
 axlAbstractData (axlAbstractData *parent=NULL)
 axlAbstractData (const axlAbstractData &data)
virtual ~axlAbstractData (void)
const QColor & color (void) const
const double & opacity (void) const
const double & size (void) const
const QString & shader (void) const
const bool & editable (void)
const bool & updateView (void)
void setColor (double r, double g, double b)
void addField (axlAbstractField *field)
 Add a field to the field list of the object. More...
bool updateFieldList (QString nameField)
 Check if a field with the same name is already applied on the object. More...
QString changeFieldName (QString fieldName)
axlMeshmesh (void)
 Return the mesh of that object is computed. More...
void setMesh (axlMesh *mesh)
 Set a corresponding mesh for that object. More...
virtual QVariantList convertDataToQVariant (void) const
 Convert an axlAbstractData into a QVariantList that specifies all properties of the axlAbstractData. More...
virtual int convertQVariantToData (const QVariantList &data)
 Modify properties and geometry variables of the axlAbstractData. Return 1 if the modification was sucessfully made. Otherwise return 0. More...
void setUpdateView (bool updateView)
QList< axlAbstractField * > fields (void)
Additional Inherited Members
- Public Slots inherited from axlAbstractData
void touchGeometry (void)
void touchProperty (void)
void touchStructure (void)
virtual void touchField (void)
void setColor (const QColor &color)
void setOpacity (const double &opacity)
void setSize (const double &size)
void setShader (const QString &shader)
void setEditable (bool edit)
- Signals inherited from axlAbstractData
void modifiedGeometry (void)
void modifiedStructure (void)
void modifiedField (void)
void modifiedProperty (void)
- Properties inherited from axlAbstractData
QColor color
double opacity
double size
QString shader
Detailed Description
Definition at line 31 of file axlAbstractSurface.h.
Constructor & Destructor Documentation
axlAbstractSurface::axlAbstractSurface ( void  )
Definition at line 32 of file axlAbstractSurface.cpp.
axlAbstractSurface::~axlAbstractSurface ( void  )
virtual
Definition at line 37 of file axlAbstractSurface.cpp.
Member Function Documentation
int axlAbstractSurface::dimension ( void  ) const
virtual
Definition at line 44 of file axlAbstractSurface.cpp.
void * axlAbstractSurface::surface ( void  )
virtual
Definition at line 58 of file axlAbstractSurface.cpp.
axlMesh * axlAbstractSurface::toAxlMesh ( void  )
virtual
Definition at line 51 of file axlAbstractSurface.cpp.
The documentation for this class was generated from the following files:
