Developer documentation | Axl-2.5.1
axlAbstractSurfaceBSpline Member List
This is the complete list of members for axlAbstractSurfaceBSpline, including all inherited members.
addField(axlAbstractField *field)axlAbstractData
area(double tol)axlAbstractSurfaceParametricvirtual
axlAbstractData(axlAbstractData *parent=NULL)axlAbstractData
axlAbstractData(const axlAbstractData &data)axlAbstractData
axlAbstractSurface(void)axlAbstractSurface
axlAbstractSurfaceBSpline(void)axlAbstractSurfaceBSpline
axlAbstractSurfaceParametric(void)axlAbstractSurfaceParametric
changeFieldName(QString fieldName)axlAbstractData
coloraxlAbstractData
color(void) const axlAbstractData
connectionsAreDefined(void)axlAbstractSurfaceBSplinevirtual
convertDataToQVariant(void) const axlAbstractSurfaceBSplinevirtual
convertQVariantToData(const QVariantList &data)axlAbstractSurfaceBSplinevirtual
copy(void) const axlAbstractSurfaceBSplinevirtual
countCells(void)axlAbstractSurfaceParametricvirtual
countControlPoints(void) const axlAbstractSurfaceBSplinevirtual
countControlPoints_u(void) const axlAbstractSurfaceBSplinevirtual
countControlPoints_v(void) const axlAbstractSurfaceBSplinevirtual
defineControlPointConnection(int i, int j)axlAbstractSurfaceBSplinevirtual
description(void) const axlAbstractSurfaceBSplinevirtual
dimension(void) const axlAbstractSurfacevirtual
edgeSelected(int numEdge, int previous, int n)axlAbstractSurfaceBSplinesignal
editable(void)axlAbstractData
endParam_u(void)axlAbstractSurfaceParametricvirtual
endParam_u(int numCell)axlAbstractSurfaceParametricvirtual
endParam_v(void)axlAbstractSurfaceParametricvirtual
endParam_v(int numCell)axlAbstractSurfaceParametricvirtual
eval(double u, double v)axlAbstractSurfaceParametricvirtual
eval(axlPoint *point, double u, double v)axlAbstractSurfaceParametricvirtual
eval(double &, double &, double &, double u, double v)axlAbstractSurfaceParametricvirtual
eval(double u, double v, int derivs, bool u_from_right=true, bool v_from_right=true, double resolution=1.0e-12)axlAbstractSurfaceParametricvirtual
eval(axlPoint *point, double u, double v, int numCell)axlAbstractSurfaceParametricvirtual
eval2(double u, double v)axlAbstractSurfaceParametricvirtual
fields(void)axlAbstractData
getCoef(int n, int m) const axlAbstractSurfaceBSplinevirtual
getCoef(int n) const axlAbstractSurfaceBSplinevirtual
getControlPointConnection(int i)axlAbstractSurfaceBSplinevirtual
getCoord(int n, int m, int v) const axlAbstractSurfaceBSplinevirtual
getKnot_u(int n) const axlAbstractSurfaceBSplinevirtual
getKnot_v(int n) const axlAbstractSurfaceBSplinevirtual
getWeight(int n, int m) const axlAbstractSurfaceBSplinevirtual
gridEvaluator(int num_u, int num_v, std::vector< double > &points, std::vector< double > &param_u, std::vector< double > &param_v)axlAbstractSurfaceBSplinevirtual
hasCells(void)axlAbstractSurfaceParametricvirtual
indexSelected(int i)axlAbstractSurfaceBSplinesignal
insertKnot_u(double k)axlAbstractSurfaceBSplinevirtual
insertKnot_v(double k)axlAbstractSurfaceBSplinevirtual
knotVectorSize_u(void) const axlAbstractSurfaceBSplinevirtual
knotVectorSize_v(void) const axlAbstractSurfaceBSplinevirtual
mesh(void)axlAbstractData
modifiedControlPoints(void)axlAbstractSurfaceBSplinesignal
modifiedField(void)axlAbstractDatasignal
modifiedGeometry(void)axlAbstractDatasignal
modifiedProperty(void)axlAbstractDatasignal
modifiedStructure(void)axlAbstractDatasignal
normal(axlPoint *normal, double u, double v)axlAbstractSurfaceParametricvirtual
normal(double u, double v)axlAbstractSurfaceParametricvirtual
normal(dtkDeprecated::dtkVector3D< double > *normal, double u, double v)axlAbstractSurfaceParametricvirtual
normal(axlPoint *normal, double u, double v, int numCell)axlAbstractSurfaceParametricvirtual
numSamples_u(void)axlAbstractSurfaceParametricvirtual
numSamples_u(int numCell)axlAbstractSurfaceParametricvirtual
numSamples_v(void)axlAbstractSurfaceParametricvirtual
numSamples_v(int numCell)axlAbstractSurfaceParametricvirtual
opacityaxlAbstractData
opacity(void) const axlAbstractData
order_u(void) const axlAbstractSurfaceBSplinevirtual
order_v(void) const axlAbstractSurfaceBSplinevirtual
parameterOf(const axlPoint &point, double &um, double &vm)axlAbstractSurfaceParametricvirtual
printCoeffs(bool print) const axlAbstractSurfaceBSplinevirtual
printKnotsVector(bool print) const axlAbstractSurfaceBSplinevirtual
rational(void) const axlAbstractSurfaceBSplinevirtual
removeKnot_u(double k)axlAbstractSurfaceBSplinevirtual
removeKnot_v(double k)axlAbstractSurfaceBSplinevirtual
resetControlPointConnections(void)axlAbstractSurfaceBSplinevirtual
samples_uaxlAbstractSurfaceParametric
samples_u(void) const axlAbstractSurfaceParametric
samples_vaxlAbstractSurfaceParametric
samples_v(void) const axlAbstractSurfaceParametric
sampling()axlAbstractSurfaceBSplinevirtual
samplingChanged(void)axlAbstractSurfaceBSplinesignal
scalarValue(double u, double v)axlAbstractSurfaceBSpline
selectIndex(int i)axlAbstractSurfaceBSplineinlinevirtual
setCoef(int n, int m, int v, double c)axlAbstractSurfaceBSplinevirtual
setCoef(int n, int m, double *controlPoint)axlAbstractSurfaceBSplinevirtual
setCoef(int n, double *controlPoint)axlAbstractSurfaceBSplinevirtual
setColor(double r, double g, double b)axlAbstractData
setColor(const QColor &color)axlAbstractDataslot
setEditable(bool edit)axlAbstractDataslot
setMesh(axlMesh *mesh)axlAbstractData
setNumSamples_u(int numSamples)axlAbstractSurfaceParametricvirtual
setNumSamples_v(int numSamples)axlAbstractSurfaceParametricvirtual
setOpacity(const double &opacity)axlAbstractDataslot
setSamples_u(const int &color)axlAbstractSurfaceParametricslot
setSamples_v(const int &color)axlAbstractSurfaceParametricslot
setScalarValue(double u, double v, double value)axlAbstractSurfaceBSpline
setShader(const QString &shader)axlAbstractDataslot
setSize(const double &size)axlAbstractDataslot
setStripes(int stripes)axlAbstractSurfaceParametricvirtual
setSurface(int pointsCount_u, int pointsCount_v, int order_u, int order_v, int dimension, double *knots_u, double *knots_v, double *points, bool rational)axlAbstractSurfaceBSplinevirtual
setUpdateView(bool updateView)axlAbstractData
shaderaxlAbstractData
shader(void) const axlAbstractData
sizeaxlAbstractData
size(void) const axlAbstractData
startParam_u(void)axlAbstractSurfaceParametricvirtual
startParam_u(int numCell)axlAbstractSurfaceParametricvirtual
startParam_v(void)axlAbstractSurfaceParametricvirtual
startParam_v(int numCell)axlAbstractSurfaceParametricvirtual
stripes(void)axlAbstractSurfaceParametricvirtual
surface(void)axlAbstractSurfacevirtual
toAxlMesh(void)axlAbstractSurfacevirtual
touchField(void)axlAbstractDatavirtualslot
touchGeometry(void)axlAbstractDataslot
touchProperty(void)axlAbstractDataslot
touchStructure(void)axlAbstractDataslot
updated(void)axlAbstractSurfaceBSplinesignal
updateFieldList(QString nameField)axlAbstractData
updateRcoeff()axlAbstractSurfaceBSplinevirtual
updateView(void)axlAbstractData
~axlAbstractData(void)axlAbstractDatavirtual
~axlAbstractSurface(void)axlAbstractSurfacevirtual
~axlAbstractSurfaceBSpline(void)axlAbstractSurfaceBSplinevirtual
~axlAbstractSurfaceParametric(void)axlAbstractSurfaceParametricvirtual
