Developer documentation | Axl-2.5.1
axlAbstractField.cpp
Go to the documentation of this file.
1 /* axlAbstractField.cpp ---
2  *
3  * Author: Thibaud Kloczko
4  * Copyright (C) 2008 - Thibaud Kloczko, Inria.
5  * Created: Wed Jul 28 11:22:28 2010 (+0200)
6  * Version: $Id$
7  * Last-Updated: Tue Oct 25 09:55:32 2011 (+0200)
8  * By: Thibaud Kloczko
9  * Update #: 355
10  */
11
12 /* Commentary:
13  *
14  */
15
16 /* Change log:
17  *
18  */
19
20 #include "axlAbstractField.h"
21
22 #include <dtkCoreSupport/dtkGlobal.h>
23
24 class axlAbstractFieldPrivate
25 {
26 public:
30
31  double min;
32  double max;
33 };
34 // /////////////////////////////////////////////////////////////////
35 // axlAbstractField implementation
36 // /////////////////////////////////////////////////////////////////
37
39
43 axlAbstractField::axlAbstractField(): d(new axlAbstractFieldPrivate)
44 {
45  // d->kind = axlAbstractField::Scalar;
46  // d->type = axlAbstractField::Float;
47  // d->support = axlAbstractField::Point;
48  d->max = 0;
49  d->min = 0;
50
51 }
52
56 axlAbstractField::axlAbstractField(QString name, Type type, Kind kind, Support support)
57 {
58  d->kind = kind;
59  d->type = type;
60  d->support = support;
61  this->setObjectName(name);
62  d->max = 0;
63  d->min = 0;
64 }
65
66
68
72 {
73 }
74
76
80 {
81  d->type = type;
82 }
83
85
89 {
90  d->kind = kind;
91 }
92
94
98 {
99  d->support = support;
100 }
101
104 // * Set a scalar element \a v1 at \a index location in the scalar data array.
105 // */
106 //void axlAbstractField::setScalar(int index, double v1)
107 //{
108 // Q_UNUSED(index);
109 // Q_UNUSED(v1);
110 //}
111
114 // * Set a vector element (\a v1, \a v2, \a v3) at \a index location in the vector data array.
115 // */
116 //void axlAbstractField::setVector(int index, double v1, double v2, double v3)
117 //{
118 // Q_UNUSED(index);
119 // Q_UNUSED(v1);
120 // Q_UNUSED(v2);
121 // Q_UNUSED(v3);
122 //}
123
126 // * Set a tensor element (\a v1, \a v2, \a v3, \a v4, \a v5, \a v6, \a v7, \a v8, \a v9)
127 // * at \a index location in the tensor data array.
128 // */
129 //void axlAbstractField::setTensor(int index, double v1, double v2, double v3, double v4, double v5, double v6, double v7, double v8, double v9)
130 //{
131 // Q_UNUSED(index);
132 // Q_UNUSED(v1);
133 // Q_UNUSED(v2);
134 // Q_UNUSED(v3);
135 // Q_UNUSED(v4);
136 // Q_UNUSED(v5);
137 // Q_UNUSED(v6);
138 // Q_UNUSED(v7);
139 // Q_UNUSED(v8);
140 // Q_UNUSED(v9);
141 //}
142
144 {
145  return d->type;
146 }
147
149 {
150  return d->kind;
151 }
152
154 {
155  return d->support;
156 }
157
158 //int axlAbstractField::size(void)
159 //{
160 // DTK_DEFAULT_IMPLEMENTATION;
161
162 // return -1;
163 //}
164
165 //void axlAbstractField::setSize(int size)
166 //{
167 // Q_UNUSED(size);
168
169 //}
170
172
176 {
177  return d->min;
178 }
179
181
184 void axlAbstractField::setMin(double mini)
185 {
186  d->min = mini;
187 }
188
189
191
195 {
196  return d->max;
197 }
198
200
203 void axlAbstractField::setMax(double maxi)
204 {
205  d->max = maxi;
206 }
207
210 // *
211 // */
212 //double axlAbstractField::scalar(int index)
213 //{
214 // DTK_DEFAULT_IMPLEMENTATION;
215
216 // return 0;
217 //}
218
221 // *
222 // */
223 //double *axlAbstractField::vector(int index)
224 //{
225 // DTK_DEFAULT_IMPLEMENTATION;
226
227 // return NULL;
228 //}
229
232 // *
233 // */
234 //double *axlAbstractField::tensor(int index)
235 //{
236 // DTK_DEFAULT_IMPLEMENTATION;
237
238 // return NULL;
239 //}
240
243 // *
244 // */
245 //QString axlAbstractField::name(void)
246 //{
247
248 // return this->objectName();
249 //}
250
251 //void axlAbstractField::setName(QString name)
252 //{
253 // this->setObjectName(name);
254 //}
255
256
259
263 {
264  DTK_DEFAULT_IMPLEMENTATION;
265 }
266
269
272 QString axlAbstractField::identifier(void) const{
273  return "";
274 }
275
276
279 // *
280 // */
281 //void *axlAbstractField::array(void)
282 //{
283 // DTK_DEFAULT_IMPLEMENTATION;
284
285 // return NULL;
286 //}
287
288 // /////////////////////////////////////////////////////////////////
289 // axlAbstractField documentation
290 // /////////////////////////////////////////////////////////////////
291
virtual double minValue(void)
Returns the minimum value of the field.
virtual void setMax(double maxi)
Sets the maximum value of the field..
virtual void update(void)
virtual QString identifier(void) const
virtual Kind kind(void)
virtual void setMin(double mini)
Sets the minimum value of the field.
virtual ~axlAbstractField(void)
Destroys the field.
virtual Support support(void)
virtual void setType(Type type)
Sets the type of the field which can be either int, float or double.
virtual double maxValue(void)
Returns the maximum value of the field.
virtual void setSupport(Support support)
virtual Type type(void)
virtual void setKind(Kind kind)
Sets the kind of the field which can be either scalar, vector or tensor.
