23 #include <dtkCoreSupport/dtkAbstractData.h>
   24 #include <dtkCoreSupport/dtkAbstractDataFactory.h>
   39     return "axlPlaneParametricWriter";
   43     return "axlPlaneParametricWriter";
   47     return QStringList() <<
"axlPlaneParametric";
   56     return planeParam != NULL;
   60     return !this->
accept(data);
   70     QDomElement planeParamElement = doc->createElement(
"planeParam");
   71     planeParamElement.setAttribute(
"name",plane->name());
   74     planeParamElement.setAttribute(
"size", QString::number(plane->
size()));
   77     QColor qcolor = plane->
color();
   79     QTextStream(&color) << QString::number(qcolor.red()) <<
   80                         << QString::number(qcolor.green()) <<
   81                         << QString::number(qcolor.blue()) <<
   82                         << QString::number(plane->
opacity());
   83     planeParamElement.setAttribute(
"color", color);
   86     QString shader = plane->
shader();
   87     QFileInfo shaderFileInfo(shader);
   88     planeParamElement.setAttribute(
"shader", shaderFileInfo.fileName());
   92     QDomElement point = doc->createElement(
"point");
   94     QTextStream(&pointStr) << QString::number(plane->
point()->
x()) <<
" "<< QString::number(plane->
point()->
y()) <<
point()->
z());
   95     QDomText pointDomText = doc->createTextNode(pointStr);
   96     point.appendChild(pointDomText);
   98     planeParamElement.appendChild(point);
  101     QDomElement normal = doc->createElement(
"normal");
  103     QTextStream(&normalStr) << QString::number(plane->
normal()->
x()) <<
normal()->
y()) <<
normal()->
z());
  104     QDomText normalDomText = doc->createTextNode(normalStr);
  105     normal.appendChild(normalDomText);
  107     planeParamElement.appendChild(normal);
  110     QDomElement refdir = doc->createElement(
"refdir");
  112     QTextStream(&refdirStr) << QString::number(planeParam->
getI()->
x()) <<
" "<< QString::number(planeParam->
getI()->
y()) <<
getI()->
z());
  113     QDomText refdirDomText = doc->createTextNode(refdirStr);
  114     refdir.appendChild(refdirDomText);
  116     planeParamElement.appendChild(refdir);
  119     if (!plane->
fields().isEmpty()) {
  122             QDomElement fieldElement = field_writer->
write(doc, field);
  123             planeParamElement.appendChild(fieldElement);
  127     return planeParamElement;
  131 QDomElement axlPlaneParametricWriter::elementByWriter(
axlAbstractDataWriter *axl_writer, QDomDocument *doc, dtkAbstractData *data) {
  137     if(!axl_writer->
accept(data))
  140     element = axl_writer->
write(doc, data);
axlPlane * getPlane(void) const
virtual ~axlPlaneParametricWriter(void)
virtual bool accept(dtkAbstractData *data)=0
Class axlPlane defines 3D planes.
static axlFieldWritersFactory * instance(void)
dtkAbstractDataWriter * createaxlPlaneParametricWriter(void)
virtual QString identifier(void) const
QStringList handled(void) const
dtkAbstractDataWriter * create(const QString &interface_name)
Class axlAbstractField defines an API for arrays of numeric data.
QDomElement write(QDomDocument *doc, dtkAbstractData *data)
axlPoint * getI(void) const
QList< axlAbstractField * > fields(void)
virtual QDomElement write(QDomDocument *doc, dtkAbstractData *data)=0
static bool registered(void)
QString description(void) const
bool reject(dtkAbstractData *data)
