23 #include <dtkCoreSupport/dtkAbstractData.h>
   24 #include <dtkCoreSupport/dtkAbstractDataFactory.h>
   40     return "axlPlaneParametricReader";
   44     return "axlPlaneParametricReader";
   48     return QStringList() <<
"axlPlaneParametric";
   56     QDomElement element = node.toElement();
   58     if(element.tagName() !=
"planeParam")
   74     return !this->
accept(node);
   78     QDomElement element = node.toElement();
   84     QString name = element.attribute(
"name");
   85     if (!name.isEmpty()) {
   86         currentPlaneParametric->setObjectName(name);
   90     QString color = element.attribute(
"color");
   91     if (!color.isEmpty()) {
   92         QStringList colorList = color.split(
   93         if (colorList.size() > 2)
   94             currentPlaneParametric->
setColor(QColor(colorList.at(0).toInt(), colorList.at(1).toInt(), colorList.at(2).toInt()));
   95         if (colorList.size() == 4)
   96             currentPlaneParametric->
setOpacity(colorList.at(3).toFloat());
  100     QString shader = element.attribute(
"shader");
  102     if (!shader.isEmpty()) {
  104         dirShader =
":axlShader/shader/"+shader;
  105         if (!QFile::exists(dirShader)) {
  106             QSettings settings(
"inria",
"dtk");
  108             settings.beginGroup(
"shader");
  109             dirShader = settings.value(
"path", defaultPath).toString();
  111             dirShader.append(
"/"+shader);
  113         currentPlaneParametric->
setShader(dirShader);
  117     QString size = element.attribute(
"size");
  119         currentPlaneParametric->
setSize(size.toFloat());
  122     QDomNodeList pointNodeList = element.elementsByTagName(
"point") ;
  123     QDomElement pointElement = pointNodeList.item(0).toElement() ;
  125     QStringList pointCoords = pointElement.text().simplified().split(QRegExp(
"\\s+"));
  126     if(pointCoords.size() == 3)
  127         currentPlaneParametric->
getPlane()->
setPoint(
new axlPoint(pointCoords[0].toDouble(), pointCoords[1].toDouble(), pointCoords[2].toDouble()));
  129         dtkWarn() <<
"Error within axlPlaneParametricReader::read, data cannot be read correctly: point coordinates";
  132     QDomNodeList normalNodeList = element.elementsByTagName(
"normal") ;
  134     QDomElement normalElement = normalNodeList.item(0).toElement() ;
  136     QStringList normalCoords = normalElement.text().simplified().split(QRegExp(
"\\s+"));
  137     if(normalCoords.size() == 3)
  138         currentPlaneParametric->
getPlane()->
setNormal(
new axlPoint(normalCoords[0].toDouble(), normalCoords[1].toDouble(), normalCoords[2].toDouble()));
  140         dtkWarn() <<
"Error within axlPlaneParametricReader::read, data cannot be read correctly: normal coordinates";
  143     QDomNodeList refdirNodeList = element.elementsByTagName(
"refdir") ;
  145     QDomElement refdirElement = refdirNodeList.item(0).toElement() ;
  147     QStringList refdirCoords = refdirElement.text().simplified().split(QRegExp(
"\\s+"));
  148     if(refdirCoords.size() == 3)
  149         currentPlaneParametric->
setI(
new axlPoint(refdirCoords[0].toDouble(), refdirCoords[1].toDouble(), refdirCoords[2].toDouble()));
  151         dtkWarn() <<
"Error within axlPlaneParametricReader::read, data cannot be read correctly: refdir coordinates";
  155     QDomNodeList nodeListField = element.elementsByTagName(
"field");
  156     if(!nodeListField.isEmpty()){
  157         for(
int i =0; i < nodeListField.size(); i++){
  158             QDomElement fieldElement = nodeListField.at(i).toElement();
  159             QString fieldType = fieldElement.attribute(
"type");
  160             if(!fieldType.isEmpty()){
  164                     QString newName = currentPlaneParametric->
changeFieldName(fieldToAdd->name());
  165                     fieldToAdd->setObjectName(newName);
  166                     currentPlaneParametric->
addField(fieldToAdd);
  172     return currentPlaneParametric;
void setNormal(axlPoint *normal)
Change second point of this plane.
Class axlPoint defines 3D points.
axlPlane * getPlane(void) const
void setShader(const QString &shader)
virtual ~axlPlaneParametricReader(void)
axlAbstractData * read(const QDomNode &node)
QString changeFieldName(QString fieldName)
dtkAbstractDataReader * create(const QString &interface_name)
QString description(void) const
void setPoint(axlPoint *point)
Change first point of this plane.
virtual axlAbstractData * read(const QDomNode &node)=0
static bool registered(void)
Class axlAbstractField defines an API for arrays of numeric data.
bool hasChildNode(QDomElement element, const QString &tag)
void setOpacity(const double &opacity)
QStringList handled(void) const
QString identifier(void) const
static axlFieldReadersFactory * instance(void)
void addField(axlAbstractField *field)
Add a field to the field list of the object.
void setSize(const double &size)
void setColor(double r, double g, double b)
bool reject(const QDomNode &node)
Class axlAbstractData defines an API for all type of axel data.
dtkAbstractDataReader * createaxlPlaneParametricReader(void)
bool accept(const QDomNode &node)
