24 #include <dtkCoreSupport/dtkGlobal.h>
   92     this->setParent(other.parent());
   93     d->point =
new axlPoint(other.d->point);
   94     d->normal =
new axlPoint(other.d->normal);
  123     *(d->point) = *(other.d->point);
  124     *(d->normal) = *(other.d->normal);
  154     *(d->point) = *point;
  155     *(d->normal) = *normal;
  165     *(d->point) = *point;
  171     d->point->coordinates()[0] = p[0];
  172     d->point->coordinates()[1] = p[1];
  173     d->point->coordinates()[2] = p[2];
  183     *(d->normal) = *normal;
  189     d->normal->coordinates()[0] = normal[0];
  190     d->normal->coordinates()[1] = normal[1];
  191     d->normal->coordinates()[2] = normal[2];
  197     d->point->setCoordinates(point.
x(),point.
y(),point.
z());
  203     d->normal->setCoordinates(normal.
x(),normal.
y(),normal.
z());
  234     QString result =
"axlPlane";
  235     result.append(
"\nPoint : "+d->point->description() +
"\nNormal : "+d->normal->description());
  260     QVariant
id = QVariant::fromValue(
identifier());
  261     QVariantList
point = d->point->convertDataToQVariant();
  262     QVariantList
normal = d->normal->convertDataToQVariant();
  266     QVariant name = QVariant::fromValue(objectName());
  274     point.append(data.at(1));
  275     point.append(data.at(2));
  276     point.append(data.at(3));
  277     point.append(data.at(4));
  278     point.append(data.at(5));
  279     d->point->convertQVariantToData(point);
  281     normal.append(data.at(6));
  282     normal.append(data.at(7));
  283     normal.append(data.at(8));
  284     normal.append(data.at(9));
  285     normal.append(data.at(10));
  286     d->normal->convertQVariantToData(normal);
  287     setObjectName(data.last().toString());
void setNormal(axlPoint *normal)
Change second point of this plane.
Class axlPoint defines 3D points.
Class axlPlane defines 3D planes.
void setValues(axlPoint *point, axlPoint *normal)
Change first point and second point of this plane.
axlPoint * point(void) const
Returns the point of the plane.
QDebug operator<<(QDebug dbg, axlPlane plane)
~axlPlane(void)
Destroys the axel plane.
void touchPoint(axlPoint point)
void setPoint(axlPoint *point)
Change first point of this plane.
axlPlane(QObject *parent=0)
Constructs a axel plane of with point and normal vector are NULL with parent parent of QObject type...
void touchNormal(axlPoint normal)
axlPoint * normal(void) const
Returns the normal of the plane.
virtual QString identifier(void) const
virtual QString description(void) const
int convertQVariantToData(const QVariantList &data)
Modify properties and geometry variables of the axlAbstractData. Return 1 if the modification was suc...
axlPlane & operator=(const axlPlane &other)
Assigns other to this plane and returns a reference to this plane.
QVariantList convertDataToQVariant(void) const
Convert an axlAbstractData into a QVariantList that specifies all properties of the axlAbstractData...
Class axlAbstractData defines an API for all type of axel data.
dtkAbstractData * createaxlPlane(void)
