#include <axlTrimmedParametricSurface.h>
Public Member Functions | |
| axlTrimmedParametricSurface (QObject *parent=0) | |
| axlTrimmedParametricSurface (axlCurveOnParamSurface *outer, QList< axlCurveOnParamSurface * > inner) | |
| ~axlTrimmedParametricSurface () | |
| void | setSurfaceBeTrimmed (axlAbstractSurface *surf) |
| void | setOuterIsBoundary (bool outerIsBoundaryOrNot) |
| void | setOuter (axlCurveOnParamSurface *outer) |
| void | setInner (QList< axlCurveOnParamSurface * > list_inner) |
| void | addInner (axlCurveOnParamSurface *inner) |
| void | addListInner (QList< axlCurveOnParamSurface * > list_inner) |
| axlCurveOnParamSurface & | getOuter () const |
| axlCurveOnParamSurface * | getOuter () |
| axlAbstractSurfaceParametric & | getSurface () const |
| axlAbstractSurface * | getSurface () |
| bool | getouterIsBoundaryOrNot () |
| QList< axlCurveOnParamSurface * > & | getInner () const |
| axlCurveOnParamSurface * | getInner (int id) |
| virtual QString | description (void) const |
| virtual QString | identifier (void) const |
| axlTrimmedParametricSurface & | operator= (const axlTrimmedParametricSurface &other) |
Public Member Functions inherited from axlAbstractSurface | |
| axlAbstractSurface (void) | |
| virtual | ~axlAbstractSurface (void) |
| virtual int | dimension (void) const |
| virtual axlMesh * | toAxlMesh (void) |
| virtual void * | surface (void) |
Public Member Functions inherited from axlAbstractData | |
| axlAbstractData (axlAbstractData *parent=NULL) | |
| axlAbstractData (const axlAbstractData &data) | |
| virtual | ~axlAbstractData (void) |
| const QColor & | color (void) const |
| const double & | opacity (void) const |
| const double & | size (void) const |
| const QString & | shader (void) const |
| const bool & | editable (void) |
| const bool & | updateView (void) |
| void | setColor (double r, double g, double b) |
| void | addField (axlAbstractField *field) |
| Add a field to the field list of the object. More... | |
| bool | updateFieldList (QString nameField) |
| Check if a field with the same name is already applied on the object. More... | |
| QString | changeFieldName (QString fieldName) |
| axlMesh * | mesh (void) |
| Return the mesh of that object is computed. More... | |
| void | setMesh (axlMesh *mesh) |
| Set a corresponding mesh for that object. More... | |
| virtual QVariantList | convertDataToQVariant (void) const |
| Convert an axlAbstractData into a QVariantList that specifies all properties of the axlAbstractData. More... | |
| virtual int | convertQVariantToData (const QVariantList &data) |
| Modify properties and geometry variables of the axlAbstractData. Return 1 if the modification was sucessfully made. Otherwise return 0. More... | |
| void | setUpdateView (bool updateView) |
| QList< axlAbstractField * > | fields (void) |
Additional Inherited Members | |
Public Slots inherited from axlAbstractData | |
| void | touchGeometry (void) |
| void | touchProperty (void) |
| void | touchStructure (void) |
| virtual void | touchField (void) |
| void | setColor (const QColor &color) |
| void | setOpacity (const double &opacity) |
| void | setSize (const double &size) |
| void | setShader (const QString &shader) |
| void | setEditable (bool edit) |
Signals inherited from axlAbstractData | |
| void | modifiedGeometry (void) |
| void | modifiedStructure (void) |
| void | modifiedField (void) |
| void | modifiedProperty (void) |
Properties inherited from axlAbstractData | |
| QColor | color |
| double | opacity |
| double | size |
| QString | shader |
Definition at line 31 of file axlTrimmedParametricSurface.h.
| axlTrimmedParametricSurface::axlTrimmedParametricSurface | ( | QObject * | parent = 0 | ) |
Definition at line 12 of file axlTrimmedParametricSurface.cpp.
| axlTrimmedParametricSurface::axlTrimmedParametricSurface | ( | axlCurveOnParamSurface * | outer, |
| QList< axlCurveOnParamSurface * > | inner | ||
Definition at line 22 of file axlTrimmedParametricSurface.cpp.
| axlTrimmedParametricSurface::~axlTrimmedParametricSurface | ( | ) |
Definition at line 28 of file axlTrimmedParametricSurface.cpp.
| void axlTrimmedParametricSurface::addInner | ( | axlCurveOnParamSurface * | inner | ) |
Definition at line 68 of file axlTrimmedParametricSurface.cpp.
| void axlTrimmedParametricSurface::addListInner | ( | QList< axlCurveOnParamSurface * > | list_inner | ) |
Definition at line 73 of file axlTrimmedParametricSurface.cpp.
virtual |
Definition at line 34 of file axlTrimmedParametricSurface.cpp.
| QList< axlCurveOnParamSurface * > & axlTrimmedParametricSurface::getInner | ( | ) | const |
Definition at line 98 of file axlTrimmedParametricSurface.cpp.
| axlCurveOnParamSurface * axlTrimmedParametricSurface::getInner | ( | int | id | ) |
Definition at line 107 of file axlTrimmedParametricSurface.cpp.
| axlCurveOnParamSurface & axlTrimmedParametricSurface::getOuter | ( | ) | const |
Definition at line 78 of file axlTrimmedParametricSurface.cpp.
| axlCurveOnParamSurface * axlTrimmedParametricSurface::getOuter | ( | ) |
Definition at line 83 of file axlTrimmedParametricSurface.cpp.
| bool axlTrimmedParametricSurface::getouterIsBoundaryOrNot | ( | ) |
Definition at line 103 of file axlTrimmedParametricSurface.cpp.
| axlAbstractSurfaceParametric & axlTrimmedParametricSurface::getSurface | ( | ) | const |
Definition at line 88 of file axlTrimmedParametricSurface.cpp.
| axlAbstractSurface * axlTrimmedParametricSurface::getSurface | ( | ) |
Definition at line 93 of file axlTrimmedParametricSurface.cpp.
virtual |
Definition at line 40 of file axlTrimmedParametricSurface.cpp.
| axlTrimmedParametricSurface & axlTrimmedParametricSurface::operator= | ( | const axlTrimmedParametricSurface & | other | ) |
Definition at line 112 of file axlTrimmedParametricSurface.cpp.
| void axlTrimmedParametricSurface::setInner | ( | QList< axlCurveOnParamSurface * > | list_inner | ) |
Definition at line 59 of file axlTrimmedParametricSurface.cpp.
| void axlTrimmedParametricSurface::setOuter | ( | axlCurveOnParamSurface * | outer | ) |
Definition at line 49 of file axlTrimmedParametricSurface.cpp.
| void axlTrimmedParametricSurface::setOuterIsBoundary | ( | bool | outerIsBoundaryOrNot | ) |
Definition at line 54 of file axlTrimmedParametricSurface.cpp.
| void axlTrimmedParametricSurface::setSurfaceBeTrimmed | ( | axlAbstractSurface * | surf | ) |
Definition at line 44 of file axlTrimmedParametricSurface.cpp.
