#include <axlTabulatedCylinder.h>
Public Member Functions | |
axlTabulatedCylinder (QObject *parent=0) | |
~axlTabulatedCylinder () | |
axlAbstractCurve | get_directrix () const |
axlAbstractCurve * | get_pt_directrix () const |
axlPoint & | get_ref_generatrix () const |
axlPoint * | get_pt_generatrix () |
void | set_generatrix (const axlPoint &vector) |
void | set_generatrix (axlPoint *vector) |
void | set_directrix (axlAbstractCurve *curve) |
void | set_directrix (const axlAbstractCurve &curve) |
virtual QString | description (void) const |
virtual QString | identifier (void) const |
axlTabulatedCylinder & | operator= (const axlTabulatedCylinder &other) |
axlAbstractSurface (void) | |
virtual | ~axlAbstractSurface (void) |
virtual int | dimension (void) const |
virtual axlMesh * | toAxlMesh (void) |
virtual void * | surface (void) |
axlAbstractData (axlAbstractData *parent=NULL) | |
axlAbstractData (const axlAbstractData &data) | |
virtual | ~axlAbstractData (void) |
const QColor & | color (void) const |
const double & | opacity (void) const |
const double & | size (void) const |
const QString & | shader (void) const |
const bool & | editable (void) |
const bool & | updateView (void) |
void | setColor (double r, double g, double b) |
void | addField (axlAbstractField *field) |
Add a field to the field list of the object. More... | |
bool | updateFieldList (QString nameField) |
Check if a field with the same name is already applied on the object. More... | |
QString | changeFieldName (QString fieldName) |
axlMesh * | mesh (void) |
Return the mesh of that object is computed. More... | |
void | setMesh (axlMesh *mesh) |
Set a corresponding mesh for that object. More... | |
virtual QVariantList | convertDataToQVariant (void) const |
Convert an axlAbstractData into a QVariantList that specifies all properties of the axlAbstractData. More... | |
virtual int | convertQVariantToData (const QVariantList &data) |
Modify properties and geometry variables of the axlAbstractData. Return 1 if the modification was sucessfully made. Otherwise return 0. More... | |
void | setUpdateView (bool updateView) |
QList< axlAbstractField * > | fields (void) |
Additional Inherited Members | |
void | touchGeometry (void) |
void | touchProperty (void) |
void | touchStructure (void) |
virtual void | touchField (void) |
void | setColor (const QColor &color) |
void | setOpacity (const double &opacity) |
void | setSize (const double &size) |
void | setShader (const QString &shader) |
void | setEditable (bool edit) |
void | modifiedGeometry (void) |
void | modifiedStructure (void) |
void | modifiedField (void) |
void | modifiedProperty (void) |
QColor | color |
double | opacity |
double | size |
QString | shader |
Definition at line 23 of file axlTabulatedCylinder.h.
axlTabulatedCylinder::axlTabulatedCylinder | ( | QObject * | parent = 0 | ) |
Definition at line 13 of file axlTabulatedCylinder.cpp.
axlTabulatedCylinder::~axlTabulatedCylinder | ( | ) |
Definition at line 18 of file axlTabulatedCylinder.cpp.
virtual |
Definition at line 64 of file axlTabulatedCylinder.cpp.
axlAbstractCurve axlTabulatedCylinder::get_directrix | ( | ) | const |
Definition at line 24 of file axlTabulatedCylinder.cpp.
axlAbstractCurve * axlTabulatedCylinder::get_pt_directrix | ( | ) | const |
Definition at line 29 of file axlTabulatedCylinder.cpp.
axlPoint * axlTabulatedCylinder::get_pt_generatrix | ( | ) |
Definition at line 39 of file axlTabulatedCylinder.cpp.
axlPoint & axlTabulatedCylinder::get_ref_generatrix | ( | ) | const |
Definition at line 34 of file axlTabulatedCylinder.cpp.
virtual |
Definition at line 70 of file axlTabulatedCylinder.cpp.
axlTabulatedCylinder & axlTabulatedCylinder::operator= | ( | const axlTabulatedCylinder & | other | ) |
Definition at line 75 of file axlTabulatedCylinder.cpp.
void axlTabulatedCylinder::set_directrix | ( | axlAbstractCurve * | curve | ) |
Definition at line 54 of file axlTabulatedCylinder.cpp.
void axlTabulatedCylinder::set_directrix | ( | const axlAbstractCurve & | curve | ) |
Definition at line 59 of file axlTabulatedCylinder.cpp.
void axlTabulatedCylinder::set_generatrix | ( | const axlPoint & | vector | ) |
Definition at line 44 of file axlTabulatedCylinder.cpp.
void axlTabulatedCylinder::set_generatrix | ( | axlPoint * | vector | ) |
Definition at line 49 of file axlTabulatedCylinder.cpp.
