17 * This class is implemented for the Tabulated Cylinder. A tabulated cylinder is a surface formed by moving a line segment called the generatrix parallel to
18 * itself along a curve called the directrix. This curve may be a line, circular arc, conic arc, parametric
19 * spline curve, rational B-spline curve, composite curve, or any parametric curve
