Class axlShapeBSpline defines a set of boundary curves (Edges) and bspline surface patches (Face). More...
#include <axlShapeBSpline.h>
Classes | |
| struct | ControlPoint |
| struct | Edge |
| struct | Face |
Signals | |
| void | indexSelected (int i) |
Signals inherited from axlAbstractData | |
| void | modifiedGeometry (void) |
| void | modifiedStructure (void) |
| void | modifiedField (void) |
| void | modifiedProperty (void) |
Public Member Functions | |
| axlShapeBSpline () | |
| ~axlShapeBSpline () | |
| QString | description (void) const |
| Return a description of the surface. More... | |
| QString | identifier (void) const |
| Return the "axlShapeBSpline" identifier.Useful for data factory. More... | |
| void | setSurface (int order_u, int order_v, int nbpoints, int nbEdges, int nbFaces, double *points, QVector< QVector< int > > pe, QVector< QVector< int > >pf, QVector< QPair< int, int > >npf) |
| Create a surface. More... | |
| void | setControlPoints (int nbpoints, double *points) |
| Add control points to the Surface. All points should be on the plane z =0;. More... | |
| void | setFace (int i, QVector< int > p, int order_u, int order_v, int nu, int nv) |
| Add or modify a face to the Surface. More... | |
| void | setFace (int i, QVector< int > p, axlAbstractSurfaceBSpline *surf) |
| void | setEdge (int i, QVector< int > p, int order) |
| Add or modify an edge to the Surface. More... | |
| void | setEdge (int i, QVector< int > p, axlAbstractCurveBSpline *curv) |
| void | removeEdge (int i) |
| Remove an edge. More... | |
| void | createSurfaceFromBSplineDataSet (QList< axlAbstractSurfaceBSpline * > dataSet) |
| Create an axlShapeBSpline from a set of axlAbstractSurfaceBSpline. More... | |
| Edge * | getEdge (int i) |
| Return edge. More... | |
| Face * | getFace (int i) |
| Return face. More... | |
| ControlPoint * | getPoint (int i) |
| Return control point. More... | |
| axlPoint | getCoef (int index) const |
| Get a coefficient of the surface. More... | |
| bool | setCoef (int index, double *newCoordinate) |
| Modified a coefficient of the surface. More... | |
| int | countControlPoints () const |
| int | countBoundaryEdges () const |
| Return how many edges. More... | |
| int | order_u () const |
| Return the order of the surface for the u parameter. More... | |
| int | order_v () const |
| Return the order of the surface for the v parameter. More... | |
| int | numSamples_u (int numCell) |
| Mesh subdision on the u-direction. More... | |
| int | numSamples_v (int numCell) |
| Mesh subdision on the v-direction. More... | |
| void | setNumSamples_u (int numSamples) |
| Modify mesh subdision on the v-direction. Same for all faces. More... | |
| void | setNumSamples_v (int numSamples) |
| int | stripes (void) |
| void | setStripes (int stripes) |
| void | normal (axlPoint *normal, double u, double v) |
| void | eval (axlPoint *point, double u, double v) |
| bool | connectionsAreDefined (void) |
| Return true if control points connections were defined by developers. False if there are default connections visualization. More... | |
| QList< int > | getControlPointConnection (int i) |
| int | countControlPoints_u (void) const |
| int | countControlPoints_v (void) const |
| void | selectIndex (int i) |
| double | scalarValue (double u, double v) |
| void | setScalarValue (double u, double v, double value) |
| double | startParam_u (int i) |
| Return the first u parameter value of a face. More... | |
| double | startParam_v (int i) |
| double | endParam_u (int i) |
| Return the last u parameter value of a face. More... | |
| double | endParam_v (int i) |
| Return the last v parameter value of a face. More... | |
| void | eval (axlPoint *point, double u, double v, int i) |
| Compute coordinates of a point of the Surface. More... | |
| void | normal (axlPoint *currentNormal, double paramCourant_u, double paramCourant_v, int indice) |
| Compute normal. More... | |
| bool | hasFaces (void) |
| Return whether the surface have several faces. More... | |
| int | countFaces (void) |
| Return how many faces. More... | |
| void | insert_point (double x, double y, double z) |
| Add a point to the control point set of the surface. More... | |
| void | insert_point (axlPoint *point) |
| void | insert_edge (Edge *edge) |
| Add an edge to the surface. More... | |
| void | insert_face (Face *face) |
| Add a face to the surface. More... | |
| void | updateFaceEdges (int numFace) |
| Update indices list of the face edges. More... | |
| void | emitEdgeSelected (int numEdge) |
Public Member Functions inherited from axlAbstractData | |
| axlAbstractData (axlAbstractData *parent=NULL) | |
| axlAbstractData (const axlAbstractData &data) | |
| virtual | ~axlAbstractData (void) |
| const QColor & | color (void) const |
| const double & | opacity (void) const |
| const double & | size (void) const |
| const QString & | shader (void) const |
| const bool & | editable (void) |
| const bool & | updateView (void) |
| void | setColor (double r, double g, double b) |
| void | addField (axlAbstractField *field) |
| Add a field to the field list of the object. More... | |
| bool | updateFieldList (QString nameField) |
| Check if a field with the same name is already applied on the object. More... | |
| QString | changeFieldName (QString fieldName) |
| axlMesh * | mesh (void) |
| Return the mesh of that object is computed. More... | |
| void | setMesh (axlMesh *mesh) |
| Set a corresponding mesh for that object. More... | |
| virtual QVariantList | convertDataToQVariant (void) const |
| Convert an axlAbstractData into a QVariantList that specifies all properties of the axlAbstractData. More... | |
| virtual int | convertQVariantToData (const QVariantList &data) |
| Modify properties and geometry variables of the axlAbstractData. Return 1 if the modification was sucessfully made. Otherwise return 0. More... | |
| void | setUpdateView (bool updateView) |
| QList< axlAbstractField * > | fields (void) |
Static Public Member Functions | |
| static bool | registered (void) |
| Emit a signal edgesSeleted. More... | |
Additional Inherited Members | |
Public Slots inherited from axlAbstractData | |
| void | touchGeometry (void) |
| void | touchProperty (void) |
| void | touchStructure (void) |
| virtual void | touchField (void) |
| void | setColor (const QColor &color) |
| void | setOpacity (const double &opacity) |
| void | setSize (const double &size) |
| void | setShader (const QString &shader) |
| void | setEditable (bool edit) |
Properties inherited from axlAbstractData | |
| QColor | color |
| double | opacity |
| double | size |
| QString | shader |
To build each Edge and Face of an axlShapeBSpline, control points must be specified as their supports are respectively bspline curves and bspline surfaces. To be sure a control point is shared by different element and not duplicated, control point point must be defines one, even if it is shared by several Faces and/or Edges. This type of object is used in mesherplugin, which connect Axel and Num3sis simulator, as a geometry of a problem. Edges are useful to determine where to apply boundary conditions of a physical problem. Faces are useful for meshing by divided the geometry into several domains.
Definition at line 12 of file axlShapeBSpline.h.
| axlShapeBSpline::axlShapeBSpline | ( | ) |
Definition at line 25 of file axlShapeBSpline.cpp.
| axlShapeBSpline::~axlShapeBSpline | ( | ) |
Definition at line 30 of file axlShapeBSpline.cpp.
| bool axlShapeBSpline::connectionsAreDefined | ( | void | ) |
Definition at line 418 of file axlShapeBSpline.cpp.
| int axlShapeBSpline::countBoundaryEdges | ( | ) | const |
Definition at line 485 of file axlShapeBSpline.cpp.
| int axlShapeBSpline::countControlPoints | ( | void | ) | const |
| index | : coefficient index. |
Definition at line 319 of file axlShapeBSpline.cpp.
| int axlShapeBSpline::countControlPoints_u | ( | void | ) | const |
Definition at line 397 of file axlShapeBSpline.cpp.
| int axlShapeBSpline::countControlPoints_v | ( | void | ) | const |
Definition at line 403 of file axlShapeBSpline.cpp.
| int axlShapeBSpline::countFaces | ( | void | ) |
Definition at line 477 of file axlShapeBSpline.cpp.
| void axlShapeBSpline::createSurfaceFromBSplineDataSet | ( | QList< axlAbstractSurfaceBSpline * > | dataSet | ) |
| dataSet | : set of axlAbstractSurfaceBSpline. |
Definition at line 117 of file axlShapeBSpline.cpp.
| QString axlShapeBSpline::description | ( | void | ) | const |
Definition at line 76 of file axlShapeBSpline.cpp.
| void axlShapeBSpline::emitEdgeSelected | ( | int | numEdge | ) |
| double axlShapeBSpline::endParam_u | ( | int | i | ) |
| i | : face identifier. |
Definition at line 442 of file axlShapeBSpline.cpp.
| double axlShapeBSpline::endParam_v | ( | int | i | ) |
Definition at line 450 of file axlShapeBSpline.cpp.
| void axlShapeBSpline::eval | ( | axlPoint * | point, |
| double | u, | ||
| double | v | ||
Definition at line 360 of file axlShapeBSpline.cpp.
| double | u, | ||
| double | v, | ||
| int | i | ||
| point | : point of the surface. |
| u | : value of the u-parameter. |
| v | : value of the v-parameter. |
Definition at line 460 of file axlShapeBSpline.cpp.
| axlPoint axlShapeBSpline::getCoef | ( | int | index | ) | const |
Definition at line 283 of file axlShapeBSpline.cpp.
| QList< int > axlShapeBSpline::getControlPointConnection | ( | int | i | ) |
Definition at line 409 of file axlShapeBSpline.cpp.
| axlShapeBSpline::Edge * axlShapeBSpline::getEdge | ( | int | i | ) |
Return edge.
| i | : edge identifier. |
Definition at line 493 of file axlShapeBSpline.cpp.
| axlShapeBSpline::Face * axlShapeBSpline::getFace | ( | int | i | ) |
Return face.
Definition at line 501 of file axlShapeBSpline.cpp.
| axlShapeBSpline::ControlPoint * axlShapeBSpline::getPoint | ( | int | i | ) |
| i | : control point identifier. |
Definition at line 509 of file axlShapeBSpline.cpp.
| bool axlShapeBSpline::hasFaces | ( | void | ) |
Definition at line 469 of file axlShapeBSpline.cpp.
| QString axlShapeBSpline::identifier | ( | void | ) | const |
Definition at line 68 of file axlShapeBSpline.cpp.
signal |
| void axlShapeBSpline::insert_edge | ( | Edge * | edge | ) |
| edge | : edge of type axlShapeBSpline::Edge. |
Definition at line 690 of file axlShapeBSpline.cpp.
| void axlShapeBSpline::insert_face | ( | Face * | face | ) |
| face | : face of type axlShapeBSpline::Face. |
Definition at line 698 of file axlShapeBSpline.cpp.
| void axlShapeBSpline::insert_point | ( | double | x, |
| double | y, | ||
| double | z | ||
| x | : x-coordinate. |
| y | : y-coordinate |
| z | : z-coordinate |
Definition at line 681 of file axlShapeBSpline.cpp.
| void axlShapeBSpline::insert_point | ( | axlPoint * | point | ) |
| point | : a point. |
Definition at line 670 of file axlShapeBSpline.cpp.
| void axlShapeBSpline::normal | ( | axlPoint * | normal, |
| double | u, | ||
| double | v | ||
Definition at line 367 of file axlShapeBSpline.cpp.
| void axlShapeBSpline::normal | ( | axlPoint * | currentNormal, |
| double | paramCourant_u, | ||
| double | paramCourant_v, | ||
| int | indice | ||
Compute normal.
| currentNormal | : normal. |
| paramCourant_u | : value of the u-parameter. |
| paramCourant_v | : value of the v-parameter. |
| indice | : face identifier. |
Definition at line 561 of file axlShapeBSpline.cpp.
| int axlShapeBSpline::numSamples_u | ( | int | i | ) |
Definition at line 517 of file axlShapeBSpline.cpp.
| int axlShapeBSpline::numSamples_v | ( | int | i | ) |
Definition at line 526 of file axlShapeBSpline.cpp.
| int axlShapeBSpline::order_u | ( | void | ) | const |
Definition at line 94 of file axlShapeBSpline.cpp.
| int axlShapeBSpline::order_v | ( | void | ) | const |
Definition at line 105 of file axlShapeBSpline.cpp.
static |
| numEdge | : the identifier of the Edge selected.Registered the data in the data factory. |
Definition at line 59 of file axlShapeBSpline.cpp.
| void axlShapeBSpline::removeEdge | ( | int | i | ) |
| double axlShapeBSpline::scalarValue | ( | double | u, |
| double | v | ||
Definition at line 374 of file axlShapeBSpline.cpp.
inline |
Definition at line 166 of file axlShapeBSpline.h.
| bool axlShapeBSpline::setCoef | ( | int | index, |
| double * | newCoordinate | ||
Definition at line 293 of file axlShapeBSpline.cpp.
| void axlShapeBSpline::setControlPoints | ( | int | nbpoints, |
| double * | points | ||
| nbpoints | : number of control points. |
| points | : points coordinates, size of points is equal to 3*nbpoints. |
Definition at line 184 of file axlShapeBSpline.cpp.
| void axlShapeBSpline::setEdge | ( | int | i, |
| QVector< int > | p, | ||
| int | order | ||
| p | : set of indices of control points owned by the face support. |
| order | : curve support order. |
Definition at line 218 of file axlShapeBSpline.cpp.
| axlAbstractCurveBSpline * | curv | ||
| curv | : curve support. |
Definition at line 253 of file axlShapeBSpline.cpp.
| void axlShapeBSpline::setFace | ( | int | i, |
| int | order_u, | ||
| int | order_v, | ||
| int | nu, | ||
| int | nv | ||
| p | : set of indices of control points owned by the surface support. |
| order_u | : surface support order for u parameter. |
| order_v | : surface support order for v parameter. |
| nu | : number of control point the u-direction. |
| nv | : number of control point the v-direction. |
Definition at line 200 of file axlShapeBSpline.cpp.
| axlAbstractSurfaceBSpline * | surf | ||
| surf | : surface support. |
Definition at line 236 of file axlShapeBSpline.cpp.
| void axlShapeBSpline::setNumSamples_u | ( | int | numSamples | ) |
| numSamples | : number of points for the subdivision. |
Definition at line 534 of file axlShapeBSpline.cpp.
| void axlShapeBSpline::setNumSamples_v | ( | int | numSamples | ) |
Definition at line 549 of file axlShapeBSpline.cpp.
| void axlShapeBSpline::setScalarValue | ( | double | u, |
| double | v, | ||
| double | value | ||
Definition at line 379 of file axlShapeBSpline.cpp.
| void axlShapeBSpline::setStripes | ( | int | stripes | ) |
Definition at line 391 of file axlShapeBSpline.cpp.
| void axlShapeBSpline::setSurface | ( | int | order_u, |
| int | order_v, | ||
| int | nbpoints, | ||
| int | nbEdges, | ||
| int | nbFaces, | ||
| double * | points, | ||
| QVector< QVector< int > > | pe, | ||
| QVector< QVector< int > > | pf, | ||
| QVector< QPair< int, int > > | npf | ||
Create a surface.
| order_u | : surface order for u parameter. |
| order_v | : surface order for v parameter. |
| nbEdges | : number of edges. |
| nbFaces | : number of faces. |
| pe | : contains all set of indices to precise what points is owned by each edge. |
| pf | : contains all set of indices to precise what points is owned by each face. |
| npf | : contains all pair of size to precise how many control points for the u-direction and the v-direction, for each face. |
Definition at line 167 of file axlShapeBSpline.cpp.
| double axlShapeBSpline::startParam_u | ( | int | i | ) |
Definition at line 426 of file axlShapeBSpline.cpp.
| double axlShapeBSpline::startParam_v | ( | int | i | ) |
Definition at line 434 of file axlShapeBSpline.cpp.
| int axlShapeBSpline::stripes | ( | void | ) |
Definition at line 384 of file axlShapeBSpline.cpp.
| void axlShapeBSpline::updateFaceEdges | ( | int | numFace | ) |
| numFace | : face identifier. |
Definition at line 569 of file axlShapeBSpline.cpp.
