addField(axlAbstractField *field) | axlAbstractData | |
axlAbstractData(axlAbstractData *parent=NULL) | axlAbstractData | |
axlAbstractData(const axlAbstractData &data) | axlAbstractData | |
axlShapeBSpline() | axlShapeBSpline | |
changeFieldName(QString fieldName) | axlAbstractData | |
color | axlAbstractData | |
color(void) const | axlAbstractData | |
connectionsAreDefined(void) | axlShapeBSpline | |
convertDataToQVariant(void) const | axlAbstractData | virtual |
convertQVariantToData(const QVariantList &data) | axlAbstractData | virtual |
countBoundaryEdges() const | axlShapeBSpline | |
countControlPoints() const | axlShapeBSpline | |
countControlPoints_u(void) const | axlShapeBSpline | |
countControlPoints_v(void) const | axlShapeBSpline | |
countFaces(void) | axlShapeBSpline | |
createSurfaceFromBSplineDataSet(QList< axlAbstractSurfaceBSpline * > dataSet) | axlShapeBSpline | |
description(void) const | axlShapeBSpline | |
editable(void) | axlAbstractData | |
emitEdgeSelected(int numEdge) | axlShapeBSpline | |
endParam_u(int i) | axlShapeBSpline | |
endParam_v(int i) | axlShapeBSpline | |
eval(axlPoint *point, double u, double v) | axlShapeBSpline | |
eval(axlPoint *point, double u, double v, int i) | axlShapeBSpline | |
fields(void) | axlAbstractData | |
getCoef(int index) const | axlShapeBSpline | |
getControlPointConnection(int i) | axlShapeBSpline | |
getEdge(int i) | axlShapeBSpline | |
getFace(int i) | axlShapeBSpline | |
getPoint(int i) | axlShapeBSpline | |
hasFaces(void) | axlShapeBSpline | |
identifier(void) const | axlShapeBSpline | |
indexSelected(int i) | axlShapeBSpline | signal |
insert_edge(Edge *edge) | axlShapeBSpline | |
insert_face(Face *face) | axlShapeBSpline | |
insert_point(double x, double y, double z) | axlShapeBSpline | |
insert_point(axlPoint *point) | axlShapeBSpline | |
mesh(void) | axlAbstractData | |
modifiedField(void) | axlAbstractData | signal |
modifiedGeometry(void) | axlAbstractData | signal |
modifiedProperty(void) | axlAbstractData | signal |
modifiedStructure(void) | axlAbstractData | signal |
normal(axlPoint *normal, double u, double v) | axlShapeBSpline | |
normal(axlPoint *currentNormal, double paramCourant_u, double paramCourant_v, int indice) | axlShapeBSpline | |
numSamples_u(int numCell) | axlShapeBSpline | |
numSamples_v(int numCell) | axlShapeBSpline | |
opacity | axlAbstractData | |
opacity(void) const | axlAbstractData | |
order_u() const | axlShapeBSpline | |
order_v() const | axlShapeBSpline | |
registered(void) | axlShapeBSpline | static |
removeEdge(int i) | axlShapeBSpline | |
scalarValue(double u, double v) | axlShapeBSpline | |
selectIndex(int i) | axlShapeBSpline | inline |
setCoef(int index, double *newCoordinate) | axlShapeBSpline | |
setColor(double r, double g, double b) | axlAbstractData | |
setColor(const QColor &color) | axlAbstractData | slot |
setControlPoints(int nbpoints, double *points) | axlShapeBSpline | |
setEdge(int i, QVector< int > p, int order) | axlShapeBSpline | |
setEdge(int i, QVector< int > p, axlAbstractCurveBSpline *curv) | axlShapeBSpline | |
setEditable(bool edit) | axlAbstractData | slot |
setFace(int i, QVector< int > p, int order_u, int order_v, int nu, int nv) | axlShapeBSpline | |
setFace(int i, QVector< int > p, axlAbstractSurfaceBSpline *surf) | axlShapeBSpline | |
setMesh(axlMesh *mesh) | axlAbstractData | |
setNumSamples_u(int numSamples) | axlShapeBSpline | |
setNumSamples_v(int numSamples) | axlShapeBSpline | |
setOpacity(const double &opacity) | axlAbstractData | slot |
setScalarValue(double u, double v, double value) | axlShapeBSpline | |
setShader(const QString &shader) | axlAbstractData | slot |
setSize(const double &size) | axlAbstractData | slot |
setStripes(int stripes) | axlShapeBSpline | |
setSurface(int order_u, int order_v, int nbpoints, int nbEdges, int nbFaces, double *points, QVector< QVector< int > > pe, QVector< QVector< int > >pf, QVector< QPair< int, int > >npf) | axlShapeBSpline | |
setUpdateView(bool updateView) | axlAbstractData | |
shader | axlAbstractData | |
shader(void) const | axlAbstractData | |
size | axlAbstractData | |
size(void) const | axlAbstractData | |
startParam_u(int i) | axlShapeBSpline | |
startParam_v(int i) | axlShapeBSpline | |
stripes(void) | axlShapeBSpline | |
touchField(void) | axlAbstractData | virtualslot |
touchGeometry(void) | axlAbstractData | slot |
touchProperty(void) | axlAbstractData | slot |
touchStructure(void) | axlAbstractData | slot |
updateFaceEdges(int numFace) | axlShapeBSpline | |
updateFieldList(QString nameField) | axlAbstractData | |
updateView(void) | axlAbstractData | |
~axlAbstractData(void) | axlAbstractData | virtual |
~axlShapeBSpline() | axlShapeBSpline | |
