19 #include <dtkCoreSupport/dtkGlobal.h>
21 #include <dtkCoreSupport/dtkAbstractDataFactory.h>
22 #include <dtkCoreSupport/dtkAbstractProcessFactory.h>
24 class axlAbstractFieldParametricPrivate
62 DTK_DEFAULT_IMPLEMENTATION;
73 qDebug() <<
"Getting scalar value on non scalar field.";
86 qDebug() <<
"Getting vector value on non vector field.";
99 qDebug() <<
"Getting tensor value on non tensor field.";
170 DTK_DEFAULT_IMPLEMENTATION;
189 DTK_DEFAULT_IMPLEMENTATION;
202 DTK_DEFAULT_IMPLEMENTATION;
virtual QString description(void) const
Returns the description of the field.
Class axlAbstractFieldParametric defines an API for parametric field.
dtkAbstractData * createaxlAbstractFieldParametric(void)
virtual int size(void)
Returns number of parameters on which the field is evaluated.
virtual ~axlAbstractFieldParametric(void)
Destroys a parametric field.
virtual double * tensor(double u, double v=0, double w=0)
Returns the value of the spatial field at the coordinates point entered.
virtual axlAbstractData * getFunction(void)
virtual double * vector(double u, double v=0, double w=0)
Returns the value of the parametric field evaluated at the parameters in input.
virtual double scalar(double u, double v=0, double w=0)
Returns the value of the parametric field at the parameters values in input.
Class axlAbstractField defines an API for arrays of numeric data.
virtual void setFunction(axlAbstractData *data)
axlAbstractFieldParametric()
virtual QString identifier(void) const
virtual void update(void)
Class axlAbstractData defines an API for all type of axel data.
