21 #include <dtkCoreSupport/dtkAbstractData.h>
   22 #include <dtkCoreSupport/dtkAbstractDataFactory.h>
   23 #include <dtkCoreSupport/dtkAbstractProcessFactory.h>
   41     return "axlFieldParametricSurfaceReader";
   46     return "axlFieldParametricSurfaceReader";
   51     return QStringList() <<
"axlFieldParametricSurface";
   61     QDomElement element = node.toElement();
   63     if(element.tagName() !=
"field")
   71     return !this->
accept(node);
   79     qDebug() << Q_FUNC_INFO <<
"enter";
   80     QDomElement element = node.toElement();
   84     QString type = element.attribute(
"type");
   91     QString name = element.attribute(
"name");
   94         field->setObjectName(name);
   98     QString typeField = element.attribute(
"valueType");
   99     if(!typeField.isEmpty()){
  100         if(typeField ==
"int"){
  102         }
else if(typeField ==
"float"){
  111     QString support = element.attribute(
"support");
  112     if(support ==
"point"){
  114     }
else if(support ==
"cell"){
  121     QString kind = element.attribute(
"kind");
  122     if(kind ==
"scalar"){
  124     }
else if(kind ==
"vector"){
  132     QDomNodeList listFunction = element.elementsByTagName(
"surface");
  133     QDomElement functionDescription = listFunction.at(0).toElement();
  134     qDebug() << Q_FUNC_INFO <<
"read function description";
  136     dtkAbstractData *data = NULL;
  138     foreach(QString reader, dtkAbstractDataFactory::instance()->readers()) {
  140         data = this->
dataByReader(axl_reader, functionDescription);
  161     if(!axl_reader->
accept(node))
  164     axl_reader->dtkAbstractDataReader::read(this->file());
  166     if(dtkAbstractData *data = axl_reader->
read(node))
QString identifier(void) const
bool accept(const QDomNode &node)
dtkAbstractData * dataByReader(axlAbstractDataReader *axl_reader, const QDomNode &node)
Class axlFieldParametricSurface defines an API for field which owns a BSpline Surface as a function a...
QStringList handled(void) const
bool reject(const QDomNode &node)
static bool registered(void)
dtkAbstractDataReader * createaxlFieldParametricSurfaceReader(void)
void setFunction(axlAbstractData *data)
Sets the Bspline function which determines the values of the parametric field.
virtual axlAbstractData * read(const QDomNode &node)=0
~axlFieldParametricSurfaceReader(void)
QString description(void) const
virtual void update(void)
virtual void setType(Type type)
Sets the type of the field which can be either int, float or double.
virtual void setSupport(Support support)
virtual bool accept(const QDomNode &node)=0
virtual void setKind(Kind kind)
Sets the kind of the field which can be either scalar, vector or tensor.
Class axlAbstractData defines an API for all type of axel data.
