14 #include "axlCoreExport.h"
15 #ifndef AXLFIELDPARAMETRICSURFACE_H
16 #define AXLFIELDPARAMETRICSURFACE_H
20 class axlFieldParametricSurfacePrivate;
54 virtual double scalar(
double u,
double v,
double w = 0);
55 virtual double *
vector(
double u,
double v,
double w = 0);
56 virtual double *
tensor(
double u,
double v,
double w = 0);
69 axlFieldParametricSurfacePrivate *d;
75 #endif // AXLFIELDPARAMETRICSURFACE_H
AXLCORE_EXPORT dtkAbstractData * createaxlFieldParametricSurface(void)
Class axlFieldParametricSurface defines an API for field which owns a BSpline Surface as a function a...
virtual axlAbstractData * getFunction(void)
Returns the description of the field.
virtual double start_u(void)
Returns the first u-value parameter.
virtual int size(void)
Returns number of parameters on which the field is evaluated.
virtual double scalar(double u, double v, double w=0)
Returns the value of the parametric field at the parameters values in input.
virtual void update(void)
virtual double start_v(void)
Returns the first v-value parameter.
virtual double numbersample_v(void)
Returns the number of v-parameters.
virtual void setFunction(axlAbstractData *data)
virtual double numbersample_u(void)
Returns the number of u-parameters.
virtual double * tensor(double u, double v, double w=0)
Returns the value of the spatial field at the coordinates point entered.
virtual double end_u(void)
Returns the last v-value parameter.
virtual double * vector(double u, double v, double w=0)
Returns the value of the parametric field evaluated at the parameters in input.
virtual double end_v(void)
virtual QString identifier(void) const
virtual QString description(void) const
Class axlAbstractFieldParametricSurface defines an API for parametric field.
virtual void setSurface(axlAbstractData *surface)
Sets the support surface of the field.
Class axlAbstractData defines an API for all type of axel data.
