21 #include <dtkCoreSupport/dtkAbstractData.h>
   22 #include <dtkCoreSupport/dtkAbstractDataFactory.h>
   23 #include <dtkCoreSupport/dtkAbstractProcessFactory.h>
   41     return "axlFieldDiscreteReader";
   46     return "axlFieldDiscreteReader";
   51     return QStringList() <<
"axlFieldDiscrete";
   56     return dtkAbstractDataFactory::instance()->registerDataReaderType(
"axlFieldDiscreteReader", QStringList(),
createaxlFieldDiscreteReader);
   61     QDomElement element = node.toElement();
   63     if(element.tagName() !=
"field")
   71     return !this->
accept(node);
   79     QDomElement element = node.toElement();
   90     QString count = element.attribute(
"count");
   93         countNumb = count.toInt();
   98     QString dimension = element.attribute(
"dimension");
  100     if(!dimension.isEmpty()){
  101         int dim = dimension.toInt();
  115     QString support = element.attribute(
"support");
  117     if(!support.isEmpty()){
  118         if(support ==
"point"){
  121         }
else if(support ==
"cell"){
  131     QString name = element.attribute(
"name");
  133         name =
"axlFieldDiscrete";
  157     QString *text_fields;
  158     int size = field->
size();
  159     text_fields =
new QString(element.text());
  161     QTextStream in_fields(text_fields);
  165         for(
int i = 0 ; i < size ; i++)
  167             in_fields.skipWhiteSpace();
  174         for(
  176             in_fields.skipWhiteSpace();
  178             in_fields.skipWhiteSpace();
  180             in_fields.skipWhiteSpace();
  186         for(
  188             in_fields.skipWhiteSpace();
  190             in_fields.skipWhiteSpace();
  192             in_fields.skipWhiteSpace();
  194             in_fields.skipWhiteSpace();
  196             in_fields.skipWhiteSpace();
  198             in_fields.skipWhiteSpace();
  200             in_fields.skipWhiteSpace();
  202             in_fields.skipWhiteSpace();
  204             in_fields.skipWhiteSpace();
  206             field->
setTensor(i, v1, v2, v3, v4, v5, v6, v7, v8, v9);
axlFieldDiscreteReader(void)
virtual void update(void)
QStringList handled(void) const
virtual void setVector(int index, double v1, double v2, double v3)
static bool registered(void)
bool reject(const QDomNode &node)
virtual void setScalar(int index, double v1)
axlAbstractData * read(const QDomNode &node)
virtual void setSize(int size)
dtkAbstractDataReader * createaxlFieldDiscreteReader(void)
Class axlFieldDiscrete defines an API for arrays of numeric data.
virtual void setType(Type type)
Sets the type of the field which can be either int, float or double.
virtual void setSupport(Support support)
QString identifier(void) const
virtual void setTensor(int index, double v1, double v2, double v3, double v4, double v5, double v6, double v7, double v8, double v9)
~axlFieldDiscreteReader(void)
bool accept(const QDomNode &node)
virtual void setKind(Kind kind)
Sets the kind of the field which can be either scalar, vector or tensor.
QString description(void) const
Class axlAbstractData defines an API for all type of axel data.
