23 #include <dtkCoreSupport/dtkAbstractData.h>
   24 #include <dtkCoreSupport/dtkAbstractDataFactory.h>
   40     return "axlCylinderParametricWriter";
   44     return "axlCylinderParametricWriter";
   48     return QStringList() <<
"axlCylinderParametric";
   57     return cylinderParam != NULL;
   61     return !this->
accept(data);
   71     QDomElement cylinderParamElement = doc->createElement(
"cylinderParam");
   72     cylinderParamElement.setAttribute(
"name",cylinder->name());
   75     cylinderParamElement.setAttribute(
"size", QString::number(cylinder->
size()));
   78     QColor qcolor = cylinder->
color();
   80     QTextStream(&color) << QString::number(qcolor.red()) <<
   81                         << QString::number(qcolor.green()) <<
   82                         << QString::number(qcolor.blue()) <<
   83                         << QString::number(cylinder->
opacity());
   84     cylinderParamElement.setAttribute(
"color", color);
   87     QString shader = cylinder->
shader();
   88     QFileInfo shaderFileInfo(shader);
   89     cylinderParamElement.setAttribute(
"shader", shaderFileInfo.fileName());
   93     QDomElement firstPoint = doc->createElement(
"point");
   94     QString firstPointStr;
   95     QTextStream(&firstPointStr) << QString::number(cylinder->
firstPoint()->
x()) <<
" "<< QString::number(cylinder->
firstPoint()->
y()) <<
firstPoint()->
z());
   96     QDomText firstPointDomText = doc->createTextNode(firstPointStr);
   97     firstPoint.appendChild(firstPointDomText);
   99     cylinderParamElement.appendChild(firstPoint);
  102     QDomElement secondPoint = doc->createElement(
"point");
  103     QString secondPointStr;
  104     QTextStream(&secondPointStr) << QString::number(cylinder->
secondPoint()->
x()) <<
secondPoint()->
y()) <<
secondPoint()->
z());
  105     QDomText secondPointDomText = doc->createTextNode(secondPointStr);
  106     secondPoint.appendChild(secondPointDomText);
  108     cylinderParamElement.appendChild(secondPoint);
  111     QDomElement radius = doc->createElement(
"radius");
  113     QTextStream(&radiusStr) << QString::number(cylinder->
radius());
  114     QDomText radiusDomText = doc->createTextNode(radiusStr);
  115     radius.appendChild(radiusDomText);
  117     cylinderParamElement.appendChild(radius);
  120     QDomElement refdir = doc->createElement(
"refdir");
  122     QTextStream(&refdirStr) << QString::number(cylinderParam->
getR()->
x()) <<
" "<< QString::number(cylinderParam->
getR()->
y()) <<
getR()->
z());
  123     QDomText refdirDomText = doc->createTextNode(refdirStr);
  124     refdir.appendChild(refdirDomText);
  126     cylinderParamElement.appendChild(refdir);
  129     if(!cylinder->
fields().isEmpty()){
  132             QDomElement fieldElement = field_writer->
write(doc, field);
  133             cylinderParamElement.appendChild(fieldElement);
  137     return cylinderParamElement;
  141 QDomElement axlCylinderParametricWriter::elementByWriter(
axlAbstractDataWriter *axl_writer, QDomDocument *doc, dtkAbstractData *data) {
  147     if(!axl_writer->
accept(data))
  150     element = axl_writer->
write(doc, data);
bool accept(dtkAbstractData *data)
virtual ~axlCylinderParametricWriter(void)
virtual bool accept(dtkAbstractData *data)=0
axlPoint * secondPoint(void) const
Returns second point of the cylinder.
Class axlCylinder defines 3D cylinders.
static axlFieldWritersFactory * instance(void)
axlPoint * firstPoint(void) const
Returns first point of the cylinder.
virtual QString identifier(void) const
QString description(void) const
bool reject(dtkAbstractData *data)
dtkAbstractDataWriter * create(const QString &interface_name)
static bool registered(void)
Class axlAbstractField defines an API for arrays of numeric data.
dtkAbstractDataWriter * createaxlCylinderParametricWriter(void)
QDomElement write(QDomDocument *doc, dtkAbstractData *data)
QList< axlAbstractField * > fields(void)
virtual QDomElement write(QDomDocument *doc, dtkAbstractData *data)=0
axlCylinder * getCylinder(void) const
QStringList handled(void) const
axlPoint * getR(void) const
