Developer documentation | Axl-2.5.1
axlAbstractView.cpp
Go to the documentation of this file.
1 /* axlAbstractView.cpp ---
2  *
3  * Author: Meriadeg Perrinel
4  * Copyright (C) 2008 - Meriadeg Perrinel, Inria.
5  * Created: Tue Nov 9 16:58:59 2010 (+0100)
6  * Version: $Id$
7  * Last-Updated: Tue Nov 9 17:09:38 2010 (+0100)
8  * By: Meriadeg Perrinel
9  * Update #: 19
10  */
11
12 /* Commentary:
13  *
14  */
15
16 /* Change log:
17  *
18  */
19
20 #include "axlAbstractView.h"
23 #include "axlAbstractActor.h"
24 #include "axlAbstractActorField.h"
25 #include "axlAbstractField.h"
26 #include "axlViewController.h"
27 #include "axlDataDynamic.h"
28
29 #include <dtkCoreSupport/dtkAbstractViewFactory.h>
30
31
32 class axlAbstractViewPrivate
33 {
34 public:
35  axlViewController *view_controller;
36 };
37
38 axlAbstractView::axlAbstractView(void) : dtkAbstractView(), d(new axlAbstractViewPrivate)
39 {
40  d->view_controller = new axlViewController;
41
42  connect(d->view_controller, SIGNAL(inserted()), this, SIGNAL(inserted()));
43 }
44
46 {
47  disconnect(d->view_controller, SIGNAL(inserted()), this, SIGNAL(inserted()));
48
49  delete d->view_controller;
50  delete d;
51
52  d = NULL;
53 }
54
56 {
57  DTK_DEFAULT_IMPLEMENTATION;
58
59  Q_UNUSED(data);
60
61  return NULL;
62 }
63
64 QList<axlAbstractActor *> axlAbstractView::insertSet(QList<axlAbstractData *> dataSet)
65 {
66  DTK_DEFAULT_IMPLEMENTATION;
67
68  Q_UNUSED(dataSet);
69
70  return QList<axlAbstractActor *>();
71 }
72
73 void axlAbstractView::removeSet(QList<axlAbstractActor *> actorSet)
74 {
75  DTK_DEFAULT_IMPLEMENTATION;
76
77  Q_UNUSED(actorSet);
78 }
79
80 void axlAbstractView::removeSetFields(QList<axlAbstractActorField *> actorSet)
81 {
82  DTK_DEFAULT_IMPLEMENTATION;
83
84  Q_UNUSED(actorSet);
85 }
86
87 void axlAbstractView::activeDefaultLigh(bool useDefaultLight)
88 {
89  DTK_DEFAULT_IMPLEMENTATION;
90
91  Q_UNUSED(useDefaultLight);
92 }
93
94 void axlAbstractView::setLight(int i, bool hide, double *position, double *ambiant, double *diffuse, double *specular, int exponent)
95 {
96  DTK_DEFAULT_IMPLEMENTATION;
97
98  Q_UNUSED(i);
99  Q_UNUSED(hide);
100  Q_UNUSED(position);
101  Q_UNUSED(ambiant);
102  Q_UNUSED(diffuse);
103  Q_UNUSED(specular);
104  Q_UNUSED(exponent);
105 }
106
108 {
109  if(axlAbstractField *axlData = dynamic_cast<axlAbstractField *> (data))
110  return d->view_controller->actorField(axlData);
111  else
112  return d->view_controller->actor(data);
113 }
114
115 void axlAbstractView::insert(dtkAbstractData *data, axlAbstractActor *actor)
116 {
117  axlAbstractField *dataField = dynamic_cast<axlAbstractField *>(data);
118  axlAbstractActorField *actorField = dynamic_cast<axlAbstractActorField *>(actor);
119
120
121  if(dataField && actorField)
122  d->view_controller->insertField(dataField, actorField);
123  else
124  d->view_controller->insert(data, actor);
125 }
126
127 void axlAbstractView::removeData(dtkAbstractData *data)
128 {
129  d->view_controller->remove(data);
130 }
131
132 void axlAbstractView::removeField(dtkAbstractData *data)
133 {
134  if(axlAbstractField* dataField = dynamic_cast<axlAbstractField*>(data))
135  d->view_controller->removeField(dataField);
136 }
137
139 {
140  return d->view_controller;
141 }
142
144 {
145  DTK_DEFAULT_IMPLEMENTATION;
146 }
147
149 {
150  DTK_DEFAULT_IMPLEMENTATION;
151 }
152
154 {
155  DTK_DEFAULT_IMPLEMENTATION;
156 }
157
159 {
160  DTK_DEFAULT_IMPLEMENTATION;
161 }
162
164 {
165  DTK_DEFAULT_IMPLEMENTATION;
166 }
167
169 {
170  DTK_DEFAULT_IMPLEMENTATION;
171 }
172
174 {
175  DTK_DEFAULT_IMPLEMENTATION;
176 }
177
178 void axlAbstractView::setCameraPosition(double x, double y, double z)
179 {
180  DTK_DEFAULT_IMPLEMENTATION;
181 }
182
183 void axlAbstractView::setGrid(bool isGridX, bool isGridY, bool isGridZ)
184 {
185  Q_UNUSED(isGridX);
186  Q_UNUSED(isGridY);
187  Q_UNUSED(isGridZ);
188
189  DTK_DEFAULT_IMPLEMENTATION;
190 }
191
192 void axlAbstractView::showColorMapping(dtkAbstractData *data)
193 {
194  if(dynamic_cast<axlAbstractSurfaceBSpline *>(data))
195  d->view_controller->actor(data)->onSamplingChanged();
196 }
197
198 void axlAbstractView::onShaderChanged(dtkAbstractData *data, QString isophoteShaderXml)
199 {
200  d->view_controller->actor(data)->setShader(isophoteShaderXml);
201 }
202
203 void axlAbstractView::onControlPointChanged(dtkAbstractData *data)
204 {
205  d->view_controller->actor(data)->onControlPointChanged();
206 // this->widget()->update();
207  this->update();
208 }
209
210 void axlAbstractView::onTubeFilterRadiusChanged(dtkAbstractData *data, double radius)
211 {
212  if(dynamic_cast<axlAbstractCurveBSpline *>(data))
213  d->view_controller->actor(data)->onTubeFilterRadiusChanged(radius);
214  else
215  d->view_controller->actor(data)->setSize(radius);
216
217  this->update();
218 }
219
220 void axlAbstractView::processIsophoteByShader(dtkAbstractData *data, QString isophoteShaderXml)
221 {
222  if(dynamic_cast<axlAbstractSurfaceBSpline *>(data))
223  d->view_controller->actor(data)->setShaderFromString(isophoteShaderXml);
224 }
225
226 void axlAbstractView::dataChangedByGeometry(dtkAbstractData *data)
227 {
228  d->view_controller->actor(data)->onUpdateGeometry();
229 }
230
231
232 void axlAbstractView::dataChangedByOpacity(dtkAbstractData *data, double opacity)
233 {
234  d->view_controller->actor(data)->setOpacity(opacity);
235 }
236
237 void axlAbstractView::dataChangedBySize(dtkAbstractData *data, double size)
238 {
239  d->view_controller->actor(data)->setSize(size);
240 }
241
242 void axlAbstractView::dataChangedByColor(dtkAbstractData *data, double red, double green, double blue)
243 {
244  d->view_controller->actor(data)->setColor(red, green, blue);
245 }
246
248
255 void axlAbstractView::dataChangedByProperty(dtkAbstractData *data, int channel)
256 {
257  if (channel == 0) {
258  //qDebug() << Q_FUNC_INFO;
259  QColor color = dynamic_cast<axlAbstractData *>(data)->color();
260  d->view_controller->actor(data)->setColor(color.red(), color.green(), color.blue());
261  } else if (channel == 1) {
262  double opacity = dynamic_cast<axlAbstractData *>(data)->opacity();
263  d->view_controller->actor(data)->setOpacity(opacity);
264  } else if (channel == 2) {
265  QString xmlFile = dynamic_cast<axlAbstractData *>(data)->shader();
266  d->view_controller->actor(data)->setShader(xmlFile);
267  } else if (channel == 3) {
268  double size = dynamic_cast<axlAbstractData *>(data)->size();
269  axlAbstractActor *actor = d->view_controller->actor(data);
270  if (actor) {
271  //qDebug() << Q_FUNC_INFO<< "size";
272  // if(!(actor->identifier()=="axlActorMesh")){
273  // d->view_controller->actor(data)->onUpdateGeometry();
274  // }else{
275  actor->setSize(size);
276  // }
277  }
278  }
279
280  // if(!dynamic_cast<axlAbstractData *>(data)->fields().isEmpty())
281  // dynamic_cast<axlAbstractData *>(data)->runFieldUpdated();
282
283  this->update();
284 }
285
286 void axlAbstractView::onInterpolationChanded(dtkAbstractData *data, int interpolation)
287 {
288  d->view_controller->actor(data)->setInterpolation(interpolation);
289 }
290
291 void axlAbstractView::onStateChanged(dtkAbstractData *data, int mode)
292 {
293  d->view_controller->actor(data)->onModeChanged(mode);
294 // this->widget()->update();
295  this->update();
296 }
297
298 void axlAbstractView::onActorVisibilityChanged(dtkAbstractData *data, bool actorVisibility)
299 {
300  if(actorVisibility){
301  d->view_controller->actor(data)->show();
302  if( axlDataDynamic* axlData = dynamic_cast<axlDataDynamic*>(data)){
303  int indiceOutput = axlData->numberOfChannels();
304  for( int i = 0; i < indiceOutput; i++){
305  d->view_controller->actor(axlData->outputs(i))->show();
306  }
307  }
308
309
310  if(d->view_controller->actor(data)->parent()){
311  //hide parents for dynamic object, the problem is hide not just one output actor.
312  d->view_controller->actor(data)->parent()->show();
313  }
314  // axlAbstractData* axlData = dynamic_cast<axlAbstractData*>(data);
315  // foreach(axlAbstractField* field, axlData->fields()){
316  // d->view_controller->actorField(field)->show();
317  // }
318  }
319  else{
320  d->view_controller->actor(data)->hide();
321
322  if( axlDataDynamic* axlData = dynamic_cast<axlDataDynamic*>(data)){
323  int indiceOutput = axlData->numberOfChannels();
324  for( int i = 0; i < indiceOutput; i++){
325  d->view_controller->actor(axlData->outputs(i))->hide();
326  }
327
328  }
329
330  if(d->view_controller->actor(data)->parent()){
331  //hide parents for dynamic object, not just one output actor.
332  d->view_controller->actor(data)->parent()->hide();
334  // if(axlDataDynamic* axlObject = dynamic_cast<axlDataDynamic *>(d->view_controller->actor(data)->parent()->data())){
335  // int indiceO = axlObject->numberOfChannels();
336  // for( int i = 0; i < indiceO; i++){
337  // if(d->view_controller->actor(axlObject->outputs(i))->data()->objectName() == d->view_controller->actor(data)->objectName() ){
338  // qDebug() << "passe a l'endroit souhaite";
339  // d->view_controller->actor(axlObject->outputs(i))->hide();
340  // }
341  // }
342
343  // }
344  }
345  // axlAbstractData* axlData = dynamic_cast<axlAbstractData*>(data);
346  // foreach(axlAbstractField* field, axlData->fields()){
347  // d->view_controller->actorField(field)->hide();
348  // }
349
350
352  if (!dynamic_cast<axlAbstractData *>(data)->fields().isEmpty()) {
353  foreach (axlAbstractField * field,dynamic_cast<axlAbstractData *>(data)->fields() ) {
354  axlAbstractField::Kind kind = field->kind();
355
356  if (kind == axlAbstractField::Scalar) {
357  d->view_controller->actorField(field)->displayAsNoneScalar();
358  } else if (kind == axlAbstractField::Vector) {
359  d->view_controller->actorField(field)->displayAsNoneVector();
360  }
361
362  }
363  }
364  }
365
366 // this->widget()->update();
367  this->update();
368 }
369
370 void axlAbstractView::ondataSetRemoved(QList<dtkAbstractData *> dataSetToRemoved)
371 {
372  QList<axlAbstractActor *> actorSetToRemoved;
373  QList<axlAbstractActorField *> actorSetFieldToRemoved;
374
375  for(int i = 0 ; i < dataSetToRemoved .size() ; i++)
376  {
377  if(axlAbstractActor *actor = d->view_controller->actor(dataSetToRemoved.value(i)))
378  actorSetToRemoved << actor;
379
380  if (axlAbstractData* data = dynamic_cast<axlAbstractData*>(dataSetToRemoved.value(i))){
381  foreach(axlAbstractField* field,data->fields()){
382  if(axlAbstractActorField *actor = d->view_controller->actorField(field)){
383  actorSetFieldToRemoved << actor;
384  }
385  }
386  }
387  }
388  this->removeSet(actorSetToRemoved);
389  this->removeSetFields(actorSetFieldToRemoved);
390 }
391
393 {
394  return d->view_controller->size();
395 }
396
397 void axlAbstractView::onLightPositionChanged(double x, double y, double z)
398 {
399  emit lightPositionChanged(x, y, z);
400 }
401
403 {
404  Q_UNUSED(resolution);
405
406  DTK_DEFAULT_IMPLEMENTATION;
407 }
408
410 {
411  Q_UNUSED(show);
412
413  DTK_DEFAULT_IMPLEMENTATION;
414 }
415
417 {
418  Q_UNUSED(gradient);
419
420  DTK_DEFAULT_IMPLEMENTATION;
421 }
422
424 {
425  DTK_DEFAULT_IMPLEMENTATION;
426
427  return 0;
428 }
429
430 void axlAbstractView::setParallelScale(double parallelScale)
431 {
432  Q_UNUSED(parallelScale);
433
434  DTK_DEFAULT_IMPLEMENTATION;
435 }
436
438 {
439  DTK_DEFAULT_IMPLEMENTATION;
440
441  return 0.0;
442 }
443
445 {
446  DTK_DEFAULT_IMPLEMENTATION;
447
448  return NULL;
449 }
450
452 {
453  DTK_DEFAULT_IMPLEMENTATION;
454
455  return 0;
456 }
457
459 {
460  DTK_DEFAULT_IMPLEMENTATION;
461
462  return 0;
463 }
464
466 {
467  DTK_DEFAULT_IMPLEMENTATION;
468
469  return NULL;
470 }
471
472 void axlAbstractView::setCameraFocalPoint(double x, double y, double z)
473 {
474  Q_UNUSED(x);
475  Q_UNUSED(y);
476  Q_UNUSED(z);
477
478  DTK_DEFAULT_IMPLEMENTATION;
479 }
480
482 {
483  DTK_DEFAULT_IMPLEMENTATION;
484
485  return NULL;
486 }
487
488 void axlAbstractView::setCameraUp(double x, double y, double z)
489 {
490  Q_UNUSED(x);
491  Q_UNUSED(y);
492  Q_UNUSED(z);
493
494  DTK_DEFAULT_IMPLEMENTATION;
495 }
496
498 {
499  DTK_DEFAULT_IMPLEMENTATION;
500
501  return 0.0;
502 }
503
505 {
506  Q_UNUSED(angle);
507
508  DTK_DEFAULT_IMPLEMENTATION;
509 }
510
511
513  DTK_DEFAULT_IMPLEMENTATION;
514
515  return NULL;
516 }
517
519 {
520  Q_UNUSED(parallel);
521
522  DTK_DEFAULT_IMPLEMENTATION;
523 }
524
526
529 void axlAbstractView::add(dtkAbstractData *data)
530 {
531  if(axlAbstractData *axldata = dynamic_cast<axlAbstractData *>(data) )
532  {
533  if(!d->view_controller->contains(axldata))
534  emit insertData(axldata);
535  else
536  dtkWarn() << "this data has already been inserted";
537  }
538 }
539
541
544 void axlAbstractView::updateFieldActor(dtkAbstractData *data)
545 {
546  Q_UNUSED(data);
547
548  DTK_DEFAULT_IMPLEMENTATION;
549 }
550
551
552
553
555 {
556  DTK_DEFAULT_IMPLEMENTATION;
557 }
558
560 {
561  DTK_DEFAULT_IMPLEMENTATION;
562 }
563
565 {
566  DTK_DEFAULT_IMPLEMENTATION;
567 }
568
570 {
571  DTK_DEFAULT_IMPLEMENTATION;
572 }
573
574
576 {
577
578 }
579
580 void axlAbstractView::onUpdateActorField(QList<axlAbstractData *> axlDataSet, QString fieldName)
581 {
582  Q_UNUSED(axlDataSet);
583 }
584
585
586 dtkAbstractViewFactory *axlAbstractView::getSingletonFactory(void)
587 {
588  //qDebug()<<"axlAbstractView :: getSingletonFactory"<<dtkAbstractViewFactory::instance();
589
590  return dtkAbstractViewFactory::instance();
591 }
axlViewController * controller(void)
virtual double getCameraViewAngle(void)
virtual void setTrackballInteractor(void)
virtual bool getBackgroundGradient(void)
void dataChangedByProperty(dtkAbstractData *data, int channel)
Modify the right property, which is defined by the channel number :
virtual void setCameraPosition(double x, double y, double z)
virtual void onShowAxis(bool show)
void onActorVisibilityChanged(dtkAbstractData *data, bool actorVisibility)
virtual void setJoystickInteractor(void)
virtual void setParallelCamera(bool parallel)
void dataChangedByGeometry(dtkAbstractData *data)
dtkAbstractViewFactory * getSingletonFactory(void)
virtual ~axlAbstractView(void)
virtual void activeDefaultLigh(bool useDefaultLight)
virtual double * getBackgroundColor(void)
void onLightPositionChanged(double x, double y, double z)
void inserted(void)
virtual void setCameraViewPositiveX(void)
virtual void updateFieldActor(dtkAbstractData *data)
Use view as input to update fields actors on a data.
void onGridResolutionChanged(int resolution)
void onStateChanged(dtkAbstractData *data, int mode)
virtual void removeField(dtkAbstractData *data)
virtual void setObjectCamera(void)
void onInterpolationChanded(dtkAbstractData *data, int interpolation)
void dataChangedByColor(dtkAbstractData *data, double red, double green, double blue)
virtual double * getCameraFocalPoint(void)
virtual double getParallelScale(void)
virtual void removeSet(QList< axlAbstractActor * > actorSet)
virtual void removeData(dtkAbstractData *data)
void processIsophoteByShader(dtkAbstractData *data, QString isophoteShaderXml)
virtual bool getAxesVisibility(void)
void insertData(axlAbstractData *data)
void onShaderChanged(dtkAbstractData *data, QString isophoteShaderXml)
virtual double * getWorldCameraPosition(void)
virtual void setCameraViewPositiveZ(void)
virtual Kind kind(void)
Class axlDataDynamic defines a dynamic object.
virtual bool getParallelProjection(void)
void ondataSetRemoved(QList< dtkAbstractData * > dataSetToRemoved)
void onControlPointChanged(dtkAbstractData *data)
virtual void update(void)
void showColorMapping(dtkAbstractData *data)
virtual void setCameraUp(double x, double y, double z)
virtual int size(void)
void dataChangedBySize(dtkAbstractData *data, double size)
virtual double * getCameraUp(void)
virtual void setParallelScale(double parallelScale)
virtual axlAbstractActor * actor(dtkAbstractData *data)
virtual void onUpdateActorField(QList< axlAbstractData * > axlDataSet, QString fieldName)
virtual void setGrid(bool isGridX, bool isGridY, bool isGridZ)
virtual void setCameraViewDefaut(void)
Class axlAbstractField defines an API for arrays of numeric data.
virtual void setCameraViewNegativeZ(void)
virtual void setWorldCamera(void)
virtual void setCameraViewNegativeX(void)
virtual void setSize(double size)
virtual void add(dtkAbstractData *data)
Use view as input to open a data in axel.
virtual axlAbstractActor * insert(axlAbstractData *data)
void lightPositionChanged(double x, double y, double z)
virtual void onBackgroundGradientChange(bool gradient)
void dataChangedByOpacity(dtkAbstractData *data, double opacity)
virtual QList< axlAbstractActor * > insertSet(QList< axlAbstractData * > dataSet)
QList< axlAbstractField * > fields(void)
virtual void setCameraViewNegativeY(void)
virtual void setCameraFocalPoint(double x, double y, double z)
virtual void setCameraViewAngle(double angle)
void onTubeFilterRadiusChanged(dtkAbstractData *data, double radius)
virtual void setCameraViewPositiveY(void)
Class axlAbstractData defines an API for all type of axel data.
virtual void setLight(int i, bool hide, double *position, double *ambiant, double *diffuse, double *specular, int exponent)
virtual void removeSetFields(QList< axlAbstractActorField * > actorSet)
double angle(axlPoint vCompute, axlPoint vRef, axlPoint normal)
