#include <axlVolumeDiscrete.h>
Public Member Functions | |
axlVolumeDiscrete (void) | |
axlVolumeDiscrete (const axlVolumeDiscrete &other) | |
~axlVolumeDiscrete (void) | |
axlVolumeDiscrete * | clone (void) const |
axlVolumeDiscrete & | operator= (const axlVolumeDiscrete &other) |
QString | identifier (void) const |
void | setData (void *data) |
void * | data (void) const |
int | xDimension (void) const |
int | yDimension (void) const |
int | zDimension (void) const |
void | setDimensions (unsigned int x, unsigned int y, unsigned int z) |
double | minValue (void) const |
double | midValue (void) const |
double | maxValue (void) const |
void | setMinValue (double min_field_value) |
void | setMidValue (double mid_field_value) |
void | setMaxValue (double max_field_value) |
double | getValue (int i, int j, int k) const |
void | setValue (double value, int i, int j, int k) |
axlAbstractVolumeDiscrete (void) | |
axlAbstractVolumeDiscrete (unsigned int x, unsigned int y, unsigned int z) | |
axlAbstractVolumeDiscrete (const axlAbstractVolumeDiscrete &other) | |
virtual | ~axlAbstractVolumeDiscrete (void) |
virtual double | getValue (int indiceGlobal) const |
virtual void | setValue (double value, int indiceGlobal) |
axlAbstractVolume (void) | |
virtual | ~axlAbstractVolume (void) |
virtual int | dimension (void) const |
virtual axlMesh * | toAxlMesh (void) |
virtual void * | volume (void) |
axlAbstractData (axlAbstractData *parent=NULL) | |
axlAbstractData (const axlAbstractData &data) | |
virtual | ~axlAbstractData (void) |
const QColor & | color (void) const |
const double & | opacity (void) const |
const double & | size (void) const |
const QString & | shader (void) const |
const bool & | editable (void) |
const bool & | updateView (void) |
void | setColor (double r, double g, double b) |
void | addField (axlAbstractField *field) |
Add a field to the field list of the object. More... | |
bool | updateFieldList (QString nameField) |
Check if a field with the same name is already applied on the object. More... | |
QString | changeFieldName (QString fieldName) |
axlMesh * | mesh (void) |
Return the mesh of that object is computed. More... | |
void | setMesh (axlMesh *mesh) |
Set a corresponding mesh for that object. More... | |
virtual QVariantList | convertDataToQVariant (void) const |
Convert an axlAbstractData into a QVariantList that specifies all properties of the axlAbstractData. More... | |
virtual int | convertQVariantToData (const QVariantList &data) |
Modify properties and geometry variables of the axlAbstractData. Return 1 if the modification was sucessfully made. Otherwise return 0. More... | |
void | setUpdateView (bool updateView) |
QList< axlAbstractField * > | fields (void) |
Additional Inherited Members | |
void | touchGeometry (void) |
void | touchProperty (void) |
void | touchStructure (void) |
virtual void | touchField (void) |
void | setColor (const QColor &color) |
void | setOpacity (const double &opacity) |
void | setSize (const double &size) |
void | setShader (const QString &shader) |
void | setEditable (bool edit) |
void | modifiedGeometry (void) |
void | modifiedStructure (void) |
void | modifiedField (void) |
void | modifiedProperty (void) |
QColor | color |
double | opacity |
double | size |
QString | shader |
Definition at line 35 of file axlVolumeDiscrete.h.
axlVolumeDiscrete::axlVolumeDiscrete | ( | void | ) |
Definition at line 49 of file axlVolumeDiscrete.cpp.
axlVolumeDiscrete::axlVolumeDiscrete | ( | const axlVolumeDiscrete & | other | ) |
Definition at line 61 of file axlVolumeDiscrete.cpp.
axlVolumeDiscrete::~axlVolumeDiscrete | ( | void | ) |
Definition at line 79 of file axlVolumeDiscrete.cpp.
axlVolumeDiscrete * axlVolumeDiscrete::clone | ( | void | ) | const |
Definition at line 84 of file axlVolumeDiscrete.cpp.
void * axlVolumeDiscrete::data | ( | void | ) | const |
Definition at line 120 of file axlVolumeDiscrete.cpp.
virtual |
Reimplemented from axlAbstractVolumeDiscrete.
Definition at line 236 of file axlVolumeDiscrete.cpp.
QString axlVolumeDiscrete::identifier | ( | void | ) | const |
Definition at line 102 of file axlVolumeDiscrete.cpp.
virtual |
Definition at line 198 of file axlVolumeDiscrete.cpp.
virtual |
Definition at line 191 of file axlVolumeDiscrete.cpp.
virtual |
Definition at line 166 of file axlVolumeDiscrete.cpp.
axlVolumeDiscrete & axlVolumeDiscrete::operator= | ( | const axlVolumeDiscrete & | other | ) |
Definition at line 89 of file axlVolumeDiscrete.cpp.
void axlVolumeDiscrete::setData | ( | void * | data | ) |
Definition at line 107 of file axlVolumeDiscrete.cpp.
virtual |
Definition at line 157 of file axlVolumeDiscrete.cpp.
void axlVolumeDiscrete::setMaxValue | ( | double | max_field_value | ) |
Definition at line 229 of file axlVolumeDiscrete.cpp.
void axlVolumeDiscrete::setMidValue | ( | double | mid_field_value | ) |
Definition at line 222 of file axlVolumeDiscrete.cpp.
void axlVolumeDiscrete::setMinValue | ( | double | min_field_value | ) |
Definition at line 217 of file axlVolumeDiscrete.cpp.
virtual |
Definition at line 245 of file axlVolumeDiscrete.cpp.
virtual |
Definition at line 127 of file axlVolumeDiscrete.cpp.
virtual |
Definition at line 137 of file axlVolumeDiscrete.cpp.
virtual |
Definition at line 147 of file axlVolumeDiscrete.cpp.
