| addField(axlAbstractField *field) | axlAbstractData | |
| axlAbstractData(axlAbstractData *parent=NULL) | axlAbstractData | |
| axlAbstractData(const axlAbstractData &data) | axlAbstractData | |
| axlAbstractVolume(void) | axlAbstractVolume | |
| axlAbstractVolumeDiscrete(void) | axlAbstractVolumeDiscrete | |
| axlAbstractVolumeDiscrete(unsigned int x, unsigned int y, unsigned int z) | axlAbstractVolumeDiscrete | |
| axlAbstractVolumeDiscrete(const axlAbstractVolumeDiscrete &other) | axlAbstractVolumeDiscrete | |
| axlVolumeDiscrete(void) | axlVolumeDiscrete | |
| axlVolumeDiscrete(const axlVolumeDiscrete &other) | axlVolumeDiscrete | |
| changeFieldName(QString fieldName) | axlAbstractData | |
| clone(void) const | axlVolumeDiscrete | |
| color | axlAbstractData | |
| color(void) const | axlAbstractData | |
| convertDataToQVariant(void) const | axlAbstractData | virtual |
| convertQVariantToData(const QVariantList &data) | axlAbstractData | virtual |
| data(void) const | axlVolumeDiscrete | |
| dimension(void) const | axlAbstractVolume | virtual |
| editable(void) | axlAbstractData | |
| fields(void) | axlAbstractData | |
| getValue(int i, int j, int k) const | axlVolumeDiscrete | virtual |
| axlAbstractVolumeDiscrete::getValue(int indiceGlobal) const | axlAbstractVolumeDiscrete | virtual |
| identifier(void) const | axlVolumeDiscrete | |
| maxValue(void) const | axlVolumeDiscrete | virtual |
| mesh(void) | axlAbstractData | |
| midValue(void) const | axlVolumeDiscrete | virtual |
| minValue(void) const | axlVolumeDiscrete | virtual |
| modifiedField(void) | axlAbstractData | signal |
| modifiedGeometry(void) | axlAbstractData | signal |
| modifiedProperty(void) | axlAbstractData | signal |
| modifiedStructure(void) | axlAbstractData | signal |
| opacity | axlAbstractData | |
| opacity(void) const | axlAbstractData | |
| operator=(const axlVolumeDiscrete &other) | axlVolumeDiscrete | |
| setColor(double r, double g, double b) | axlAbstractData | |
| setColor(const QColor &color) | axlAbstractData | slot |
| setData(void *data) | axlVolumeDiscrete | |
| setDimensions(unsigned int x, unsigned int y, unsigned int z) | axlVolumeDiscrete | virtual |
| setEditable(bool edit) | axlAbstractData | slot |
| setMaxValue(double max_field_value) | axlVolumeDiscrete | |
| setMesh(axlMesh *mesh) | axlAbstractData | |
| setMidValue(double mid_field_value) | axlVolumeDiscrete | |
| setMinValue(double min_field_value) | axlVolumeDiscrete | |
| setOpacity(const double &opacity) | axlAbstractData | slot |
| setShader(const QString &shader) | axlAbstractData | slot |
| setSize(const double &size) | axlAbstractData | slot |
| setUpdateView(bool updateView) | axlAbstractData | |
| setValue(double value, int i, int j, int k) | axlVolumeDiscrete | virtual |
| axlAbstractVolumeDiscrete::setValue(double value, int indiceGlobal) | axlAbstractVolumeDiscrete | virtual |
| shader | axlAbstractData | |
| shader(void) const | axlAbstractData | |
| size | axlAbstractData | |
| size(void) const | axlAbstractData | |
| toAxlMesh(void) | axlAbstractVolume | virtual |
| touchField(void) | axlAbstractData | virtualslot |
| touchGeometry(void) | axlAbstractData | slot |
| touchProperty(void) | axlAbstractData | slot |
| touchStructure(void) | axlAbstractData | slot |
| updateFieldList(QString nameField) | axlAbstractData | |
| updateView(void) | axlAbstractData | |
| volume(void) | axlAbstractVolume | virtual |
| xDimension(void) const | axlVolumeDiscrete | virtual |
| yDimension(void) const | axlVolumeDiscrete | virtual |
| zDimension(void) const | axlVolumeDiscrete | virtual |
| ~axlAbstractData(void) | axlAbstractData | virtual |
| ~axlAbstractVolume(void) | axlAbstractVolume | virtual |
| ~axlAbstractVolumeDiscrete(void) | axlAbstractVolumeDiscrete | virtual |
| ~axlVolumeDiscrete(void) | axlVolumeDiscrete | |
