#include <axlViewDefault.h>
 Public Member Functions | |
| axlViewDefault (void) | |
| ~axlViewDefault (void) | |
| QWidget * | widget (void) |
  Public Member Functions inherited from axlAbstractView | |
| axlAbstractView (void) | |
| virtual | ~axlAbstractView (void) |
| virtual axlAbstractActor * | insert (axlAbstractData *data) |
| virtual QList< axlAbstractActor * > | insertSet (QList< axlAbstractData * > dataSet) |
| virtual void | removeSet (QList< axlAbstractActor * > actorSet) |
| virtual void | removeSetFields (QList< axlAbstractActorField * > actorSet) |
| virtual axlAbstractActor * | actor (dtkAbstractData *data) |
| virtual void | insert (dtkAbstractData *data, axlAbstractActor *actor) |
| virtual void | removeData (dtkAbstractData *data) |
| virtual void | removeField (dtkAbstractData *data) |
| virtual void | activeDefaultLigh (bool useDefaultLight) |
| virtual void | setLight (int i, bool hide, double *position, double *ambiant, double *diffuse, double *specular, int exponent) |
| virtual int | size (void) |
| virtual QString | description (void) const |
| axlViewController * | controller (void) |
| virtual void | setCameraViewDefaut (void) |
| virtual void | setCameraViewNegativeX (void) |
| virtual void | setCameraViewPositiveX (void) |
| virtual void | setCameraViewNegativeY (void) |
| virtual void | setCameraViewPositiveY (void) |
| virtual void | setCameraViewNegativeZ (void) |
| virtual void | setCameraViewPositiveZ (void) |
| virtual void | setParallelCamera (bool parallel) |
| virtual void | setCameraPosition (double x, double y, double z) |
| virtual double * | getCameraFocalPoint (void) |
| virtual void | setCameraFocalPoint (double x, double y, double z) |
| virtual double * | getCameraUp (void) |
| virtual void | setCameraUp (double x, double y, double z) |
| virtual double | getCameraViewAngle (void) |
| virtual void | setCameraViewAngle (double angle) |
| virtual double * | getWorldCameraPosition (void) |
| virtual bool | getAxesVisibility (void) |
| virtual bool | getParallelProjection (void) |
| virtual bool | getBackgroundGradient (void) |
| virtual void | setParallelScale (double parallelScale) |
| virtual double | getParallelScale (void) |
| virtual void | setGrid (bool isGridX, bool isGridY, bool isGridZ) |
| dtkAbstractViewFactory * | getSingletonFactory (void) |
| virtual void | update (void) |
| virtual void | add (dtkAbstractData *data) |
| Use view as input to open a data in axel.  More... | |
| virtual void | updateFieldActor (dtkAbstractData *data) |
| Use view as input to update fields actors on a data.  More... | |
Additional Inherited Members | |
  Public Slots inherited from axlAbstractView | |
| void | onStateChanged (dtkAbstractData *data, int mode) |
| void | showColorMapping (dtkAbstractData *data) |
| void | onShaderChanged (dtkAbstractData *data, QString isophoteShaderXml) |
| void | onControlPointChanged (dtkAbstractData *data) |
| void | onTubeFilterRadiusChanged (dtkAbstractData *data, double radius) |
| void | processIsophoteByShader (dtkAbstractData *data, QString isophoteShaderXml) |
| void | dataChangedByGeometry (dtkAbstractData *data) |
| void | dataChangedByProperty (dtkAbstractData *data, int channel) |
| Modify the right property, which is defined by the channel number :  More... | |
| void | dataChangedByOpacity (dtkAbstractData *data, double opacity) |
| void | dataChangedBySize (dtkAbstractData *data, double size) |
| void | dataChangedByColor (dtkAbstractData *data, double red, double green, double blue) |
| void | onActorVisibilityChanged (dtkAbstractData *data, bool actorVisibility) |
| void | ondataSetRemoved (QList< dtkAbstractData * > dataSetToRemoved) |
| void | onLightPositionChanged (double x, double y, double z) |
| void | onGridResolutionChanged (int resolution) |
| virtual void | onUpdateActorField (QList< axlAbstractData * > axlDataSet, QString fieldName) |
| void | onInterpolationChanded (dtkAbstractData *data, int interpolation) |
| virtual void | onShowAxis (bool show) |
| virtual void | onBackgroundGradientChange (bool gradient) |
| virtual void | setWorldCamera (void) |
| virtual void | setObjectCamera (void) |
| virtual void | setTrackballInteractor (void) |
| virtual void | setJoystickInteractor (void) |
| virtual double * | getBackgroundColor (void) |
  Signals inherited from axlAbstractView | |
| void | inserted (void) |
| void | stateChanged (dtkAbstractData *data, int mode) |
| void | lightPositionChanged (double x, double y, double z) |
| void | insertData (axlAbstractData *data) |
Definition at line 12 of file axlViewDefault.h.
| axlViewDefault::axlViewDefault | ( | void | ) |
Definition at line 14 of file axlViewDefault.cpp.
| axlViewDefault::~axlViewDefault | ( | void | ) |
Definition at line 20 of file axlViewDefault.cpp.
| QWidget * axlViewDefault::widget | ( | void | ) |
Definition at line 27 of file axlViewDefault.cpp.
