Developer documentation | Axl-2.5.1
axlViewDefault Member List
This is the complete list of members for axlViewDefault, including all inherited members.
activeDefaultLigh(bool useDefaultLight)axlAbstractViewvirtual
actor(dtkAbstractData *data)axlAbstractViewvirtual
add(dtkAbstractData *data)axlAbstractViewvirtual
axlAbstractView(void)axlAbstractView
axlViewDefault(void)axlViewDefault
controller(void)axlAbstractView
dataChangedByColor(dtkAbstractData *data, double red, double green, double blue)axlAbstractViewslot
dataChangedByGeometry(dtkAbstractData *data)axlAbstractViewslot
dataChangedByOpacity(dtkAbstractData *data, double opacity)axlAbstractViewslot
dataChangedByProperty(dtkAbstractData *data, int channel)axlAbstractViewslot
dataChangedBySize(dtkAbstractData *data, double size)axlAbstractViewslot
description(void) const axlAbstractViewinlinevirtual
getAxesVisibility(void)axlAbstractViewvirtual
getBackgroundColor(void)axlAbstractViewvirtualslot
getBackgroundGradient(void)axlAbstractViewvirtual
getCameraFocalPoint(void)axlAbstractViewvirtual
getCameraUp(void)axlAbstractViewvirtual
getCameraViewAngle(void)axlAbstractViewvirtual
getParallelProjection(void)axlAbstractViewvirtual
getParallelScale(void)axlAbstractViewvirtual
getSingletonFactory(void)axlAbstractView
getWorldCameraPosition(void)axlAbstractViewvirtual
insert(axlAbstractData *data)axlAbstractViewvirtual
insert(dtkAbstractData *data, axlAbstractActor *actor)axlAbstractViewvirtual
insertData(axlAbstractData *data)axlAbstractViewsignal
inserted(void)axlAbstractViewsignal
insertSet(QList< axlAbstractData * > dataSet)axlAbstractViewvirtual
lightPositionChanged(double x, double y, double z)axlAbstractViewsignal
onActorVisibilityChanged(dtkAbstractData *data, bool actorVisibility)axlAbstractViewslot
onBackgroundGradientChange(bool gradient)axlAbstractViewvirtualslot
onControlPointChanged(dtkAbstractData *data)axlAbstractViewslot
ondataSetRemoved(QList< dtkAbstractData * > dataSetToRemoved)axlAbstractViewslot
onGridResolutionChanged(int resolution)axlAbstractViewslot
onInterpolationChanded(dtkAbstractData *data, int interpolation)axlAbstractViewslot
onLightPositionChanged(double x, double y, double z)axlAbstractViewslot
onShaderChanged(dtkAbstractData *data, QString isophoteShaderXml)axlAbstractViewslot
onShowAxis(bool show)axlAbstractViewvirtualslot
onStateChanged(dtkAbstractData *data, int mode)axlAbstractViewslot
onTubeFilterRadiusChanged(dtkAbstractData *data, double radius)axlAbstractViewslot
onUpdateActorField(QList< axlAbstractData * > axlDataSet, QString fieldName)axlAbstractViewvirtualslot
processIsophoteByShader(dtkAbstractData *data, QString isophoteShaderXml)axlAbstractViewslot
removeData(dtkAbstractData *data)axlAbstractViewvirtual
removeField(dtkAbstractData *data)axlAbstractViewvirtual
removeSet(QList< axlAbstractActor * > actorSet)axlAbstractViewvirtual
removeSetFields(QList< axlAbstractActorField * > actorSet)axlAbstractViewvirtual
setCameraFocalPoint(double x, double y, double z)axlAbstractViewvirtual
setCameraPosition(double x, double y, double z)axlAbstractViewvirtual
setCameraUp(double x, double y, double z)axlAbstractViewvirtual
setCameraViewAngle(double angle)axlAbstractViewvirtual
setCameraViewDefaut(void)axlAbstractViewvirtual
setCameraViewNegativeX(void)axlAbstractViewvirtual
setCameraViewNegativeY(void)axlAbstractViewvirtual
setCameraViewNegativeZ(void)axlAbstractViewvirtual
setCameraViewPositiveX(void)axlAbstractViewvirtual
setCameraViewPositiveY(void)axlAbstractViewvirtual
setCameraViewPositiveZ(void)axlAbstractViewvirtual
setGrid(bool isGridX, bool isGridY, bool isGridZ)axlAbstractViewvirtual
setJoystickInteractor(void)axlAbstractViewvirtualslot
setLight(int i, bool hide, double *position, double *ambiant, double *diffuse, double *specular, int exponent)axlAbstractViewvirtual
setObjectCamera(void)axlAbstractViewvirtualslot
setParallelCamera(bool parallel)axlAbstractViewvirtual
setParallelScale(double parallelScale)axlAbstractViewvirtual
setTrackballInteractor(void)axlAbstractViewvirtualslot
setWorldCamera(void)axlAbstractViewvirtualslot
showColorMapping(dtkAbstractData *data)axlAbstractViewslot
size(void)axlAbstractViewvirtual
stateChanged(dtkAbstractData *data, int mode)axlAbstractViewsignal
update(void)axlAbstractViewvirtual
updateFieldActor(dtkAbstractData *data)axlAbstractViewvirtual
widget(void)axlViewDefault
~axlAbstractView(void)axlAbstractViewvirtual
~axlViewDefault(void)axlViewDefault
