addField(axlAbstractField *field) | axlAbstractData | |
axlAbstractData(axlAbstractData *parent=NULL) | axlAbstractData | |
axlAbstractData(const axlAbstractData &data) | axlAbstractData | |
axlAbstractField() | axlAbstractField | |
axlAbstractField(QString name, Type type, Kind kind, Support support) | axlAbstractField | |
axlAbstractFieldParametric() | axlAbstractFieldParametric | |
axlAbstractFieldParametricCurve() | axlAbstractFieldParametricCurve | |
axlFieldParametricCurve() | axlFieldParametricCurve | |
Cell enum value | axlAbstractField | |
changeFieldName(QString fieldName) | axlAbstractData | |
color | axlAbstractData | |
color(void) const | axlAbstractData | |
convertDataToQVariant(void) const | axlAbstractData | virtual |
convertQVariantToData(const QVariantList &data) | axlAbstractData | virtual |
Custom enum value | axlAbstractField | |
description(void) const | axlFieldParametricCurve | virtual |
Double enum value | axlAbstractField | |
editable(void) | axlAbstractData | |
end_u(void) | axlFieldParametricCurve | virtual |
fields(void) | axlAbstractData | |
Float enum value | axlAbstractField | |
getFunction(void) | axlFieldParametricCurve | virtual |
identifier(void) const | axlFieldParametricCurve | virtual |
Int enum value | axlAbstractField | |
kind(void) | axlAbstractField | virtual |
Kind enum name | axlAbstractField | |
maxValue(void) | axlAbstractField | virtual |
mesh(void) | axlAbstractData | |
minValue(void) | axlAbstractField | virtual |
modifiedField(void) | axlAbstractData | signal |
modifiedGeometry(void) | axlAbstractData | signal |
modifiedProperty(void) | axlAbstractData | signal |
modifiedStructure(void) | axlAbstractData | signal |
numbersample_u(void) | axlFieldParametricCurve | virtual |
opacity | axlAbstractData | |
opacity(void) const | axlAbstractData | |
Point enum value | axlAbstractField | |
scalar(double u, double v=0., double w=0.) | axlFieldParametricCurve | virtual |
Scalar enum value | axlAbstractField | |
setColor(double r, double g, double b) | axlAbstractData | |
setColor(const QColor &color) | axlAbstractData | slot |
setCurve(axlAbstractData *data) | axlFieldParametricCurve | virtual |
setEditable(bool edit) | axlAbstractData | slot |
setFunction(axlAbstractData *data) | axlFieldParametricCurve | virtual |
setKind(Kind kind) | axlAbstractField | virtual |
setMax(double maxi) | axlAbstractField | virtual |
setMesh(axlMesh *mesh) | axlAbstractData | |
setMin(double mini) | axlAbstractField | virtual |
setOpacity(const double &opacity) | axlAbstractData | slot |
setShader(const QString &shader) | axlAbstractData | slot |
setSize(const double &size) | axlAbstractData | slot |
setSupport(Support support) | axlAbstractField | virtual |
setType(Type type) | axlAbstractField | virtual |
setUpdateView(bool updateView) | axlAbstractData | |
shader | axlAbstractData | |
shader(void) const | axlAbstractData | |
size(void) | axlFieldParametricCurve | virtual |
axlAbstractField::size | axlAbstractData | |
axlAbstractField::size(void) const | axlAbstractData | |
start_u(void) | axlFieldParametricCurve | virtual |
support(void) | axlAbstractField | virtual |
Support enum name | axlAbstractField | |
tensor(double u, double v=0., double w=0.) | axlFieldParametricCurve | virtual |
Tensor enum value | axlAbstractField | |
touchField(void) | axlAbstractData | virtualslot |
touchGeometry(void) | axlAbstractData | slot |
touchProperty(void) | axlAbstractData | slot |
touchStructure(void) | axlAbstractData | slot |
type(void) | axlAbstractField | virtual |
Type enum name | axlAbstractField | |
update(void) | axlFieldParametricCurve | virtualslot |
updated(void) | axlAbstractFieldParametricCurve | signal |
updateFieldList(QString nameField) | axlAbstractData | |
updateView(void) | axlAbstractData | |
Vector enum value | axlAbstractField | |
vector(double u, double v=0., double w=0.) | axlFieldParametricCurve | virtual |
~axlAbstractData(void) | axlAbstractData | virtual |
~axlAbstractField(void) | axlAbstractField | virtual |
~axlAbstractFieldParametric(void) | axlAbstractFieldParametric | virtual |
~axlAbstractFieldParametricCurve(void) | axlAbstractFieldParametricCurve | virtual |
~axlFieldParametricCurve(void) | axlFieldParametricCurve | virtual |
