addField(axlAbstractField *field) | axlAbstractData | |
axlAbstractData(axlAbstractData *parent=NULL) | axlAbstractData | |
axlAbstractData(const axlAbstractData &data) | axlAbstractData | |
axlEllipsoid(QObject *parent=0) | axlEllipsoid | |
axlEllipsoid(axlPoint *center, axlPoint *semiX, axlPoint *semiY, axlPoint *semiZ, QObject *parent=0) | axlEllipsoid | |
axlEllipsoid(const axlPoint ¢er, const axlPoint &semiX, const axlPoint &semiY, const axlPoint &semiZ, QObject *parent=0) | axlEllipsoid | |
axlEllipsoid(const axlEllipsoid &other) | axlEllipsoid | |
calculateXY(void) | axlEllipsoid | slot |
calculateXZ(void) | axlEllipsoid | slot |
calculateYZ(void) | axlEllipsoid | slot |
center | axlEllipsoid | |
center(void) const | axlEllipsoid | |
changeFieldName(QString fieldName) | axlAbstractData | |
color | axlAbstractData | |
color(void) const | axlAbstractData | |
convertDataToQVariant(void) const | axlEllipsoid | virtual |
convertQVariantToData(const QVariantList &data) | axlEllipsoid | virtual |
description(void) const | axlEllipsoid | virtual |
editable(void) | axlAbstractData | |
fields(void) | axlAbstractData | |
identifier(void) const | axlEllipsoid | virtual |
mesh(void) | axlAbstractData | |
modifiedField(void) | axlAbstractData | signal |
modifiedGeometry(void) | axlAbstractData | signal |
modifiedProperty(void) | axlAbstractData | signal |
modifiedStructure(void) | axlAbstractData | signal |
modifyCenter(double *center) | axlEllipsoid | |
modifyCenterX(double x) | axlEllipsoid | |
modifyCenterY(double y) | axlEllipsoid | |
modifyCenterZ(double z) | axlEllipsoid | |
modifySemiX(double *semiX) | axlEllipsoid | |
modifySemiXX(double x) | axlEllipsoid | |
modifySemiXY(double y) | axlEllipsoid | |
modifySemiXZ(double z) | axlEllipsoid | |
modifySemiY(double *semiY) | axlEllipsoid | |
modifySemiYX(double x) | axlEllipsoid | |
modifySemiYY(double y) | axlEllipsoid | |
modifySemiYZ(double z) | axlEllipsoid | |
modifySemiZ(double *semiZ) | axlEllipsoid | |
modifySemiZX(double x) | axlEllipsoid | |
modifySemiZY(double y) | axlEllipsoid | |
modifySemiZZ(double z) | axlEllipsoid | |
onCenterChanged(axlPoint *center) | axlEllipsoid | slot |
onSemiXChanged(axlPoint *semiX) | axlEllipsoid | slot |
onSemiYChanged(axlPoint *semiY) | axlEllipsoid | slot |
onSemiZChanged(axlPoint *semiZ) | axlEllipsoid | slot |
opacity | axlAbstractData | |
opacity(void) const | axlAbstractData | |
operator<<(QDebug dbg, axlEllipsoid line) | axlEllipsoid | friend |
operator<<(QDebug dbg, axlEllipsoid &line) | axlEllipsoid | friend |
operator<<(QDebug dbg, axlEllipsoid *line) | axlEllipsoid | friend |
operator=(const axlEllipsoid &other) | axlEllipsoid | |
semiX | axlEllipsoid | |
semiX(void) const | axlEllipsoid | |
semiY | axlEllipsoid | |
semiY(void) const | axlEllipsoid | |
semiZ | axlEllipsoid | |
semiZ(void) const | axlEllipsoid | |
setCenter(axlPoint *center) | axlEllipsoid | |
setColor(double r, double g, double b) | axlAbstractData | |
setColor(const QColor &color) | axlAbstractData | slot |
setEditable(bool edit) | axlAbstractData | slot |
setMesh(axlMesh *mesh) | axlAbstractData | |
setOpacity(const double &opacity) | axlAbstractData | slot |
setSemiX(axlPoint *semiX) | axlEllipsoid | |
setSemiY(axlPoint *semiY) | axlEllipsoid | |
setSemiZ(axlPoint *semiZ) | axlEllipsoid | |
setShader(const QString &shader) | axlAbstractData | slot |
setSize(const double &size) | axlAbstractData | slot |
setUpdateView(bool updateView) | axlAbstractData | |
setValues(axlPoint *center, axlPoint *semiX, axlPoint *semiY, axlPoint *semiZ) | axlEllipsoid | |
shader | axlAbstractData | |
shader(void) const | axlAbstractData | |
size | axlAbstractData | |
size(void) const | axlAbstractData | |
touchCenter(axlPoint center) | axlEllipsoid | |
touchField(void) | axlAbstractData | virtualslot |
touchGeometry(void) | axlAbstractData | slot |
touchProperty(void) | axlAbstractData | slot |
touchSemiX(axlPoint semiX) | axlEllipsoid | |
touchSemiY(axlPoint semiY) | axlEllipsoid | |
touchSemiZ(axlPoint semiZ) | axlEllipsoid | |
touchStructure(void) | axlAbstractData | slot |
updateFieldList(QString nameField) | axlAbstractData | |
updateView(void) | axlAbstractData | |
~axlAbstractData(void) | axlAbstractData | virtual |
~axlEllipsoid(void) | axlEllipsoid | |
