#include <axlCompositeCurve.h>
Public Member Functions | |
axlCompositeCurve (QObject *parent=0) | |
axlCompositeCurve (bool Case, QObject *parent=0) | |
~axlCompositeCurve () | |
void | setCase (bool Case) |
bool | getCase () |
axlAbstractCurve | get_curve_at_id (int id) const |
axlAbstractCurve * | get_pt_curve_at_id (int id) const |
const axlAbstractCurve & | get_ref_curve_at_id (int id) const |
int | count_curve (void) const |
void | insert_list_curves (const QList< axlAbstractCurve > &data_curves) |
void | insert_list_curves (const QList< axlAbstractCurve * > &data_curve) |
void | insert_curve (axlAbstractCurve *curve, int id_want_inserted) |
void | insert_curve (axlAbstractCurve curve, int id_want_inserted) |
void | append_curve (const axlAbstractCurve &curve) |
void | append_curve (axlAbstractCurve *curve) |
void | append_point (const axlPoint &startPoint, const axlPoint &endPoint) |
void | append_point (axlPoint *startPoint, axlPoint *endPoint) |
axlPoint * | get_start_point () |
axlPoint * | get_end_point () |
void | remove_last_curve () |
void | remove_curve_at_id (int id_want_remove) |
virtual QString | description (void) const |
virtual QString | identifier (void) const |
axlCompositeCurve & | operator= (const axlCompositeCurve &other) |
axlAbstractCurveParametric (void) | |
virtual | ~axlAbstractCurveParametric (void) |
virtual double | startParam (void) |
virtual double | endParam (void) |
virtual axlPoint | eval (double u) |
virtual void | eval (axlPoint *point, double u) |
virtual axlMesh | eval (double u, int derivs, bool from_right=true) |
double | parameterOf (const axlPoint &p) |
virtual double | length (double tolerance) |
virtual int | numSamples (void) |
virtual void | setNumSamples (int numSamples) |
const int & | samples (void) const |
axlAbstractCurve (void) | |
virtual | ~axlAbstractCurve (void) |
virtual int | dimension (void) const |
virtual bool | isPlanar (void) const |
virtual void * | curve (void) |
axlAbstractData (axlAbstractData *parent=NULL) | |
axlAbstractData (const axlAbstractData &data) | |
virtual | ~axlAbstractData (void) |
const QColor & | color (void) const |
const double & | opacity (void) const |
const double & | size (void) const |
const QString & | shader (void) const |
const bool & | editable (void) |
const bool & | updateView (void) |
void | setColor (double r, double g, double b) |
void | addField (axlAbstractField *field) |
Add a field to the field list of the object. More... | |
bool | updateFieldList (QString nameField) |
Check if a field with the same name is already applied on the object. More... | |
QString | changeFieldName (QString fieldName) |
axlMesh * | mesh (void) |
Return the mesh of that object is computed. More... | |
void | setMesh (axlMesh *mesh) |
Set a corresponding mesh for that object. More... | |
virtual QVariantList | convertDataToQVariant (void) const |
Convert an axlAbstractData into a QVariantList that specifies all properties of the axlAbstractData. More... | |
virtual int | convertQVariantToData (const QVariantList &data) |
Modify properties and geometry variables of the axlAbstractData. Return 1 if the modification was sucessfully made. Otherwise return 0. More... | |
void | setUpdateView (bool updateView) |
QList< axlAbstractField * > | fields (void) |
Additional Inherited Members | |
virtual void | onDirectChanged (bool direct) |
void | setSamples (const int &color) |
void | touchGeometry (void) |
void | touchProperty (void) |
void | touchStructure (void) |
virtual void | touchField (void) |
void | setColor (const QColor &color) |
void | setOpacity (const double &opacity) |
void | setSize (const double &size) |
void | setShader (const QString &shader) |
void | setEditable (bool edit) |
void | modifiedGeometry (void) |
void | modifiedStructure (void) |
void | modifiedField (void) |
void | modifiedProperty (void) |
int | samples |
QColor | color |
double | opacity |
double | size |
QString | shader |
Definition at line 21 of file axlCompositeCurve.h.
axlCompositeCurve::axlCompositeCurve | ( | QObject * | parent = 0 | ) |
Definition at line 14 of file axlCompositeCurve.cpp.
axlCompositeCurve::axlCompositeCurve | ( | bool | Case, |
Definition at line 19 of file axlCompositeCurve.cpp.
axlCompositeCurve::~axlCompositeCurve | ( | ) |
Definition at line 24 of file axlCompositeCurve.cpp.
void axlCompositeCurve::append_curve | ( | const axlAbstractCurve & | curve | ) |
Definition at line 85 of file axlCompositeCurve.cpp.
void axlCompositeCurve::append_curve | ( | axlAbstractCurve * | curve | ) |
Definition at line 92 of file axlCompositeCurve.cpp.
Definition at line 100 of file axlCompositeCurve.cpp.
Definition at line 108 of file axlCompositeCurve.cpp.
int axlCompositeCurve::count_curve | ( | void | ) | const |
Definition at line 47 of file axlCompositeCurve.cpp.
virtual |
Definition at line 137 of file axlCompositeCurve.cpp.
axlAbstractCurve axlCompositeCurve::get_curve_at_id | ( | int | id | ) | const |
axlPoint * axlCompositeCurve::get_end_point | ( | ) |
Definition at line 121 of file axlCompositeCurve.cpp.
axlAbstractCurve * axlCompositeCurve::get_pt_curve_at_id | ( | int | id | ) | const |
Definition at line 39 of file axlCompositeCurve.cpp.
const axlAbstractCurve& axlCompositeCurve::get_ref_curve_at_id | ( | int | id | ) | const |
axlPoint * axlCompositeCurve::get_start_point | ( | ) |
Definition at line 117 of file axlCompositeCurve.cpp.
bool axlCompositeCurve::getCase | ( | ) |
Definition at line 35 of file axlCompositeCurve.cpp.
virtual |
Definition at line 155 of file axlCompositeCurve.cpp.
void axlCompositeCurve::insert_curve | ( | axlAbstractCurve * | curve, |
int | id_want_inserted | ||
Definition at line 69 of file axlCompositeCurve.cpp.
void axlCompositeCurve::insert_curve | ( | axlAbstractCurve | curve, |
Definition at line 77 of file axlCompositeCurve.cpp.
void axlCompositeCurve::insert_list_curves | ( | const QList< axlAbstractCurve > & | data_curves | ) |
Definition at line 58 of file axlCompositeCurve.cpp.
void axlCompositeCurve::insert_list_curves | ( | const QList< axlAbstractCurve * > & | data_curve | ) |
Definition at line 52 of file axlCompositeCurve.cpp.
axlCompositeCurve & axlCompositeCurve::operator= | ( | const axlCompositeCurve & | other | ) |
Definition at line 160 of file axlCompositeCurve.cpp.
void axlCompositeCurve::remove_curve_at_id | ( | int | id_want_remove | ) |
Definition at line 131 of file axlCompositeCurve.cpp.
void axlCompositeCurve::remove_last_curve | ( | ) |
Definition at line 125 of file axlCompositeCurve.cpp.
void axlCompositeCurve::setCase | ( | bool | Case | ) |
Definition at line 30 of file axlCompositeCurve.cpp.
