Developer documentation | Axl-2.5.1
axlAbstractVolumeRational Class Reference
#include <axlAbstractVolumeRational.h>
Inheritance diagram for axlAbstractVolumeRational:
axlAbstractVolumeParametric axlAbstractVolume axlAbstractData
Public Member Functions
 axlAbstractVolumeRational (void)
virtual ~axlAbstractVolumeRational (void)
virtual QString write_domain (void) const
virtual QString write_numerator (unsigned index) const
virtual QString write_denominator (void) const
virtual void setDomain (const QString &domain)
virtual void setDomain (const QVector< double > domain)
virtual void setNumerator (int index, const QString &numerator)
virtual void setDenominator (const QString &denominator)
virtual void setNumAndDenom (QStringList numAndDenom)
virtual void setSurface (QVector< double > domain, QStringList numAndDenom)
- Public Member Functions inherited from axlAbstractVolumeParametric
 axlAbstractVolumeParametric (void)
virtual ~axlAbstractVolumeParametric (void)
virtual axlPoint eval (double u, double v, double w)
virtual void eval (axlPoint *point, double u, double v, double w)
virtual void eval (double &, double &, double &, double u, double v, double w)
virtual void normal (axlPoint *normal, double u, double v, double w)
virtual axlMesh eval (double u, double v, double w, int derivs, bool u_from_right=true, bool v_from_right=true, bool w_from_right=true, double resolution=1.0e-12)
virtual dtkDeprecated::dtkVector3D< double > eval2 (double u, double v, double w)
virtual dtkDeprecated::dtkVector3D< double > normal (double u, double v, double w)
virtual void normal (dtkDeprecated::dtkVector3D< double > *normal, double u, double v, double w)
virtual int numSamples_u (void)
virtual int numSamples_v (void)
virtual int numSamples_w (void)
virtual double startParam_u (void)
virtual double endParam_u (void)
virtual double startParam_v (void)
virtual double endParam_v (void)
virtual double startParam_w (void)
virtual double endParam_w (void)
virtual int stripes (void)
virtual void setStripes (int stripes)
virtual void setNumSamples_u (int numSamples)
virtual void setNumSamples_v (int numSamples)
virtual void setNumSamples_w (int numSamples)
const int & samples_u (void) const
const int & samples_v (void) const
const int & samples_w (void) const
 axlAbstractVolume (void)
virtual ~axlAbstractVolume (void)
virtual int dimension (void) const
virtual axlMeshtoAxlMesh (void)
virtual void * volume (void)
- Public Member Functions inherited from axlAbstractData
 axlAbstractData (axlAbstractData *parent=NULL)
 axlAbstractData (const axlAbstractData &data)
virtual ~axlAbstractData (void)
const QColor & color (void) const
const double & opacity (void) const
const double & size (void) const
const QString & shader (void) const
const bool & editable (void)
const bool & updateView (void)
void setColor (double r, double g, double b)
void addField (axlAbstractField *field)
 Add a field to the field list of the object. More...
bool updateFieldList (QString nameField)
 Check if a field with the same name is already applied on the object. More...
QString changeFieldName (QString fieldName)
axlMeshmesh (void)
 Return the mesh of that object is computed. More...
void setMesh (axlMesh *mesh)
 Set a corresponding mesh for that object. More...
virtual QVariantList convertDataToQVariant (void) const
 Convert an axlAbstractData into a QVariantList that specifies all properties of the axlAbstractData. More...
virtual int convertQVariantToData (const QVariantList &data)
 Modify properties and geometry variables of the axlAbstractData. Return 1 if the modification was sucessfully made. Otherwise return 0. More...
void setUpdateView (bool updateView)
QList< axlAbstractField * > fields (void)
Additional Inherited Members
- Public Slots inherited from axlAbstractVolumeParametric
void setSamples_u (const int &color)
void setSamples_v (const int &color)
void setSamples_w (const int &color)
- Public Slots inherited from axlAbstractData
void touchGeometry (void)
void touchProperty (void)
void touchStructure (void)
virtual void touchField (void)
void setColor (const QColor &color)
void setOpacity (const double &opacity)
void setSize (const double &size)
void setShader (const QString &shader)
void setEditable (bool edit)
- Signals inherited from axlAbstractData
void modifiedGeometry (void)
void modifiedStructure (void)
void modifiedField (void)
void modifiedProperty (void)
- Properties inherited from axlAbstractVolumeParametric
int samples_u
int samples_v
int samples_w
- Properties inherited from axlAbstractData
QColor color
double opacity
double size
QString shader
Detailed Description
Definition at line 28 of file axlAbstractVolumeRational.h.
Constructor & Destructor Documentation
axlAbstractVolumeRational::axlAbstractVolumeRational ( void  )
Definition at line 28 of file axlAbstractVolumeRational.cpp.
axlAbstractVolumeRational::~axlAbstractVolumeRational ( void  )
virtual
Definition at line 33 of file axlAbstractVolumeRational.cpp.
Member Function Documentation
void axlAbstractVolumeRational::setDenominator ( const QString &  denominator)
virtual
Definition at line 76 of file axlAbstractVolumeRational.cpp.
void axlAbstractVolumeRational::setDomain ( const QString &  domain)
virtual
Definition at line 55 of file axlAbstractVolumeRational.cpp.
void axlAbstractVolumeRational::setDomain ( const QVector< double >  domain)
virtual
Definition at line 60 of file axlAbstractVolumeRational.cpp.
void axlAbstractVolumeRational::setNumAndDenom ( QStringList  numAndDenom)
virtual
Definition at line 71 of file axlAbstractVolumeRational.cpp.
void axlAbstractVolumeRational::setNumerator ( int  index,
const QString &  numerator
virtual
Definition at line 65 of file axlAbstractVolumeRational.cpp.
void axlAbstractVolumeRational::setSurface ( QVector< double >  domain,
virtual
Definition at line 81 of file axlAbstractVolumeRational.cpp.
QString axlAbstractVolumeRational::write_denominator ( void  ) const
virtual
Definition at line 50 of file axlAbstractVolumeRational.cpp.
QString axlAbstractVolumeRational::write_domain ( void  ) const
virtual
Definition at line 40 of file axlAbstractVolumeRational.cpp.
QString axlAbstractVolumeRational::write_numerator ( unsigned  index) const
virtual
Definition at line 45 of file axlAbstractVolumeRational.cpp.
The documentation for this class was generated from the following files:
