Developer documentation | Axl-2.5.1
axlAbstractVolumeRational Member List
This is the complete list of members for axlAbstractVolumeRational, including all inherited members.
addField(axlAbstractField *field)axlAbstractData
axlAbstractData(axlAbstractData *parent=NULL)axlAbstractData
axlAbstractData(const axlAbstractData &data)axlAbstractData
axlAbstractVolume(void)axlAbstractVolume
axlAbstractVolumeParametric(void)axlAbstractVolumeParametric
axlAbstractVolumeRational(void)axlAbstractVolumeRational
changeFieldName(QString fieldName)axlAbstractData
coloraxlAbstractData
color(void) const axlAbstractData
convertDataToQVariant(void) const axlAbstractDatavirtual
convertQVariantToData(const QVariantList &data)axlAbstractDatavirtual
dimension(void) const axlAbstractVolumevirtual
editable(void)axlAbstractData
endParam_u(void)axlAbstractVolumeParametricvirtual
endParam_v(void)axlAbstractVolumeParametricvirtual
endParam_w(void)axlAbstractVolumeParametricvirtual
eval(double u, double v, double w)axlAbstractVolumeParametricvirtual
eval(axlPoint *point, double u, double v, double w)axlAbstractVolumeParametricvirtual
eval(double &, double &, double &, double u, double v, double w)axlAbstractVolumeParametricvirtual
eval(double u, double v, double w, int derivs, bool u_from_right=true, bool v_from_right=true, bool w_from_right=true, double resolution=1.0e-12)axlAbstractVolumeParametricvirtual
eval2(double u, double v, double w)axlAbstractVolumeParametricvirtual
fields(void)axlAbstractData
mesh(void)axlAbstractData
modifiedField(void)axlAbstractDatasignal
modifiedGeometry(void)axlAbstractDatasignal
modifiedProperty(void)axlAbstractDatasignal
modifiedStructure(void)axlAbstractDatasignal
normal(axlPoint *normal, double u, double v, double w)axlAbstractVolumeParametricvirtual
normal(double u, double v, double w)axlAbstractVolumeParametricvirtual
normal(dtkDeprecated::dtkVector3D< double > *normal, double u, double v, double w)axlAbstractVolumeParametricvirtual
numSamples_u(void)axlAbstractVolumeParametricvirtual
numSamples_v(void)axlAbstractVolumeParametricvirtual
numSamples_w(void)axlAbstractVolumeParametricvirtual
opacityaxlAbstractData
opacity(void) const axlAbstractData
samples_uaxlAbstractVolumeParametric
samples_u(void) const axlAbstractVolumeParametric
samples_vaxlAbstractVolumeParametric
samples_v(void) const axlAbstractVolumeParametric
samples_waxlAbstractVolumeParametric
samples_w(void) const axlAbstractVolumeParametric
setColor(double r, double g, double b)axlAbstractData
setColor(const QColor &color)axlAbstractDataslot
setDenominator(const QString &denominator)axlAbstractVolumeRationalvirtual
setDomain(const QString &domain)axlAbstractVolumeRationalvirtual
setDomain(const QVector< double > domain)axlAbstractVolumeRationalvirtual
setEditable(bool edit)axlAbstractDataslot
setMesh(axlMesh *mesh)axlAbstractData
setNumAndDenom(QStringList numAndDenom)axlAbstractVolumeRationalvirtual
setNumerator(int index, const QString &numerator)axlAbstractVolumeRationalvirtual
setNumSamples_u(int numSamples)axlAbstractVolumeParametricvirtual
setNumSamples_v(int numSamples)axlAbstractVolumeParametricvirtual
setNumSamples_w(int numSamples)axlAbstractVolumeParametricvirtual
setOpacity(const double &opacity)axlAbstractDataslot
setSamples_u(const int &color)axlAbstractVolumeParametricslot
setSamples_v(const int &color)axlAbstractVolumeParametricslot
setSamples_w(const int &color)axlAbstractVolumeParametricslot
setShader(const QString &shader)axlAbstractDataslot
setSize(const double &size)axlAbstractDataslot
setStripes(int stripes)axlAbstractVolumeParametricvirtual
setSurface(QVector< double > domain, QStringList numAndDenom)axlAbstractVolumeRationalvirtual
setUpdateView(bool updateView)axlAbstractData
shaderaxlAbstractData
shader(void) const axlAbstractData
sizeaxlAbstractData
size(void) const axlAbstractData
startParam_u(void)axlAbstractVolumeParametricvirtual
startParam_v(void)axlAbstractVolumeParametricvirtual
startParam_w(void)axlAbstractVolumeParametricvirtual
stripes(void)axlAbstractVolumeParametricvirtual
toAxlMesh(void)axlAbstractVolumevirtual
touchField(void)axlAbstractDatavirtualslot
touchGeometry(void)axlAbstractDataslot
touchProperty(void)axlAbstractDataslot
touchStructure(void)axlAbstractDataslot
updateFieldList(QString nameField)axlAbstractData
updateView(void)axlAbstractData
volume(void)axlAbstractVolumevirtual
write_denominator(void) const axlAbstractVolumeRationalvirtual
write_domain(void) const axlAbstractVolumeRationalvirtual
write_numerator(unsigned index) const axlAbstractVolumeRationalvirtual
~axlAbstractData(void)axlAbstractDatavirtual
~axlAbstractVolume(void)axlAbstractVolumevirtual
~axlAbstractVolumeParametric(void)axlAbstractVolumeParametricvirtual
~axlAbstractVolumeRational(void)axlAbstractVolumeRationalvirtual
