Developer documentation | Axl-2.5.1
axlAbstractFieldGenerator Class Reference
#include <axlAbstractFieldGenerator.h>
Inheritance diagram for axlAbstractFieldGenerator:
axlAbstractProcess axlFieldParametricCurveTangentVectorCreator axlFieldParametricNormalVectorCreator axlFieldParametricSurfaceTangentVectorCreator axlFieldParametricVolumeTangentVectorCreator axlFieldSpatialCoordinatesCreator axlFieldSpatialPointDistanceCreator
Public Slots
virtual void setInput (dtkAbstractData *data, int channel=0)
virtual int update (void)
Signals
void dataSetFieldsChanged (QList< axlAbstractData * > dataSet, QString fieldName)
Public Member Functions
 axlAbstractFieldGenerator (void)
virtual ~axlAbstractFieldGenerator (void)
virtual QString description (void) const
- Public Member Functions inherited from axlAbstractProcess
 axlAbstractProcess (void)
virtual ~axlAbstractProcess (void)
virtual void copyProcess (axlAbstractProcess *process)
virtual bool hasParameters (void)
virtual QString identifier (void) const
virtual void setDescription (QString description)
virtual void setIdentifier (QString identifier)
virtual QString form (void) const
 Description of the form for the dialog with the process. More...
Detailed Description
Definition at line 34 of file axlAbstractFieldGenerator.h.
Constructor & Destructor Documentation
axlAbstractFieldGenerator::axlAbstractFieldGenerator ( void  )
Definition at line 27 of file axlAbstractFieldGenerator.cpp.
axlAbstractFieldGenerator::~axlAbstractFieldGenerator ( void  )
virtual
Definition at line 32 of file axlAbstractFieldGenerator.cpp.
Member Function Documentation
void axlAbstractFieldGenerator::dataSetFieldsChanged ( QList< axlAbstractData * >  dataSet,
QString  fieldName
signal
void axlAbstractFieldGenerator::setInput ( dtkAbstractData *  data,
int  channel = 0
virtualslot
Definition at line 36 of file axlAbstractFieldGenerator.cpp.
int axlAbstractFieldGenerator::update ( void  )
virtualslot
Definition at line 42 of file axlAbstractFieldGenerator.cpp.
The documentation for this class was generated from the following files:
