#include <axlFieldParametricVolumeTangentVectorCreator.h>
          | axlFieldParametricVolumeTangentVectorCreator::axlFieldParametricVolumeTangentVectorCreator  |
          void  |
          | axlFieldParametricVolumeTangentVectorCreator::~axlFieldParametricVolumeTangentVectorCreator  |
          void  |
          | int axlFieldParametricVolumeTangentVectorCreator::channelCount  |
          void  |
slot   |
          | QString axlFieldParametricVolumeTangentVectorCreator::description  |
          void  |
           const |
virtual   |
          | QString axlFieldParametricVolumeTangentVectorCreator::form  |
          void  |
           const |
inlinevirtual   |
Description of the form for the dialog with the process.
The string use to describe the form is formatted as follows:
"INPUT[:CHANNEL] TYPE LABEL"
"PARAMETER[:CHANNEL] TYPE LABEL"
"OUTPUT [:CHANNEL] LABEL"
 where:
- CHANNEL is a number identifying the rank of an input, see dtkAbstractProcess. Write this value only if the process method setInput uses a channel in its parameters !
- TYPE is either int, double or data.
- LABEL is the input's name.
Here is an example of such a declaration:
      return QString(
           " INPUT:0 data StartPoint \n"
           " INPUT:1 data EndPoint \n"
           " PARAMETER:0 double Radius \n"
           " OUTPUT Cylinder ");
Reimplemented from axlAbstractProcess.
Definition at line 52 of file axlFieldParametricVolumeTangentVectorCreator.h.
          | QString axlFieldParametricVolumeTangentVectorCreator::identifier  |
          void  |
           const |
virtual   |
          | static bool axlFieldParametricVolumeTangentVectorCreator::registered  |
          void  |
static   |
          | void axlFieldParametricVolumeTangentVectorCreator::setInput  |
          dtkAbstractData *  |
          data,  |
          int  |
          channel  |
slot   |
          | void axlFieldParametricVolumeTangentVectorCreator::setParameter  |
          double  |
          data,  |
          int  |
          channel  |
slot   |
          | int axlFieldParametricVolumeTangentVectorCreator::update  |
          void  |
slot   |
The documentation for this class was generated from the following files:
