Developer documentation | Axl-2.5.1
axlFieldSpatialPointDistanceCreator Class Reference
#include <axlFieldSpatialPointDistanceCreator.h>
Inheritance diagram for axlFieldSpatialPointDistanceCreator:
axlAbstractFieldGenerator axlAbstractProcess
Public Slots
void setInput (dtkAbstractData *data, int channel=0)
void setParameter (double data, int channel=0)
int update (void)
int channelCount (void)
- Public Slots inherited from axlAbstractFieldGenerator
virtual void setInput (dtkAbstractData *data, int channel=0)
virtual int update (void)
Public Member Functions
 axlFieldSpatialPointDistanceCreator (void)
 ~axlFieldSpatialPointDistanceCreator (void)
QString description (void) const
QString identifier (void) const
QString form (void) const
 Description of the form for the dialog with the process. More...
- Public Member Functions inherited from axlAbstractFieldGenerator
 axlAbstractFieldGenerator (void)
virtual ~axlAbstractFieldGenerator (void)
- Public Member Functions inherited from axlAbstractProcess
 axlAbstractProcess (void)
virtual ~axlAbstractProcess (void)
virtual void copyProcess (axlAbstractProcess *process)
virtual bool hasParameters (void)
virtual void setDescription (QString description)
virtual void setIdentifier (QString identifier)
Static Public Member Functions
static bool registered (void)
Additional Inherited Members
- Signals inherited from axlAbstractFieldGenerator
void dataSetFieldsChanged (QList< axlAbstractData * > dataSet, QString fieldName)
Detailed Description
Definition at line 33 of file axlFieldSpatialPointDistanceCreator.h.
Constructor & Destructor Documentation
axlFieldSpatialPointDistanceCreator::axlFieldSpatialPointDistanceCreator ( void  )
Definition at line 37 of file axlFieldSpatialPointDistanceCreator.cpp.
axlFieldSpatialPointDistanceCreator::~axlFieldSpatialPointDistanceCreator ( void  )
Definition at line 46 of file axlFieldSpatialPointDistanceCreator.cpp.
Member Function Documentation
int axlFieldSpatialPointDistanceCreator::channelCount ( void  )
slot
Definition at line 114 of file axlFieldSpatialPointDistanceCreator.cpp.
QString axlFieldSpatialPointDistanceCreator::description ( void  ) const
virtual
Reimplemented from axlAbstractFieldGenerator.
Definition at line 120 of file axlFieldSpatialPointDistanceCreator.cpp.
QString axlFieldSpatialPointDistanceCreator::form ( void  ) const
inlinevirtual
The string use to describe the form is formatted as follows:
"INPUT[:CHANNEL] TYPE LABEL"
"PARAMETER[:CHANNEL] TYPE LABEL"
"OUTPUT [:CHANNEL] LABEL"
where:
  • CHANNEL is a number identifying the rank of an input, see dtkAbstractProcess. Write this value only if the process method setInput uses a channel in its parameters !
  • TYPE is either int, double or data.
  • LABEL is the input's name.
Here is an example of such a declaration:
QString form(void) const
return QString(
" INPUT:0 data StartPoint \n"
" INPUT:1 data EndPoint \n"
" PARAMETER:0 double Radius \n"
" OUTPUT Cylinder ");
Reimplemented from axlAbstractProcess.
Definition at line 54 of file axlFieldSpatialPointDistanceCreator.h.
QString axlFieldSpatialPointDistanceCreator::identifier ( void  ) const
virtual
Definition at line 125 of file axlFieldSpatialPointDistanceCreator.cpp.
static bool axlFieldSpatialPointDistanceCreator::registered ( void  )
static
void axlFieldSpatialPointDistanceCreator::setInput ( dtkAbstractData *  data,
int  channel = 0
slot
Definition at line 54 of file axlFieldSpatialPointDistanceCreator.cpp.
void axlFieldSpatialPointDistanceCreator::setParameter ( double  data,
int  channel = 0
slot
Definition at line 66 of file axlFieldSpatialPointDistanceCreator.cpp.
int axlFieldSpatialPointDistanceCreator::update ( void  )
slot
Definition at line 79 of file axlFieldSpatialPointDistanceCreator.cpp.
The documentation for this class was generated from the following files:
